Changing Speaker Cables
geoff check out the place pep mentioned.I'm considering that same thing now as well......Thank you very much Tommy 2 Tone!!!!
I looked into the Kwik 12 from Kimber, they have the bulk roll but it looks pretty expensive. I'm going to do some searching around to see if I can find it cheaper.Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels -
EditLiving Room
Fronts: RTi A7's
Surrounds: Rti A3
I've terminated miles of Kimber Kables , if you need any help , you can send your wire , ends and shrink wrap to me and I'll build them for yeah. I suggest Kimber Banana ends. They do however have a wonderful Spade , I had them and they are the only Spades I actually liked.I am buying a bulk run at a signifigant savings it would cost me 3-4 times as much as to get a precompleted set.Dan
The Kwik 12 is a great sounding wire. Worth the money if you wanna swing it.I'm considering that same thing now as well......Thank you very much Tommy 2 Tone!!!!
I looked into the Kwik 12 from Kimber, they have the bulk roll but it looks pretty expensive. I'm going to do some searching around to see if I can find it cheaper.Dan
Got it thanks! Is there a minimum on the bulk? 100', 50' or 25'? Or can it be custom lenth order?Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
Ill find out. i only need 24 feet lol. going with 3 8ft runs. Dan thanks for the offer i always appreciate your adviseLiving Room
Fronts: RTi A7's
Surrounds: Rti A3
Thanks, found some 50' spools.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2
