Changing Speaker Cables
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Geoff4rfc wrote: »
    I'm considering that same thing now as well......Thank you very much Tommy 2 Tone!!!!
    I looked into the Kwik 12 from Kimber, they have the bulk roll but it looks pretty expensive. I'm going to do some searching around to see if I can find it cheaper.
    geoff check out the place pep mentioned.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Edit
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • mantis
    mantis Posts: 17,327
    edited January 2013
    tommyt21 wrote: »
    I am buying a bulk run at a signifigant savings it would cost me 3-4 times as much as to get a precompleted set.
    I've terminated miles of Kimber Kables , if you need any help , you can send your wire , ends and shrink wrap to me and I'll build them for yeah. I suggest Kimber Banana ends. They do however have a wonderful Spade , I had them and they are the only Spades I actually liked.
    Dan
  • mantis
    edited January 2013
    Geoff4rfc wrote: »
    The Kwik 12 is a great sounding wire. Worth the money if you wanna swing it.
    Dan
  • Geoff4rfc
    Geoff4rfc Posts: 2,811
    edited January 2013
    tommyt21 wrote: »
    Got it thanks! Is there a minimum on the bulk? 100', 50' or 25'? Or can it be custom lenth order?
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Ill find out. i only need 24 feet lol. going with 3 8ft runs. Dan thanks for the offer i always appreciate your advise
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • Geoff4rfc
    edited January 2013
    mantis wrote: »
    Thanks, found some 50' spools.
