Changing Speaker Cables
tommyt21
tommyt21 Posts: 685
edited January 2013 in Speakers
This is not a thread ment to start a fight but asking a legit question regarding speaker cables. I am asking only those with EXPERINCE in changing out speaker cables.
I was not a big believer in swapping cables hence the reason I was trying to sell 145 feet of Audioquest Hyperlitz f-18's. Since no one showed interest I decided what the heck and I swaped out my Center Channels Blue Jeans cable for the Audioquest Cable. There was a enormous audible difference, however I'm still not sure which cables I like better the blue jeans had way better bass, and the Audioquest had no bass, felt bright yet much more detail in the top. This experince has led me to decide to actually go out on a limb and try even another set of cables. I have now used Monoprice, Blue jeans and Audioquest. Between Blue Jeans and Monoprice cables there was not as big of a difference as there was between the Bluejeans and the Audioquest (talking audible difference, not saying which is better). My price range is little under $300 bucks.
Thinking strongly about Signal Cables Ultra with the Bi-Wire
Any other suggestions?
Thomas
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    edited December 2012
    Hmmmmmm, try taking a look at this................hey whats up Tommy 2 Tone?????
    http://www.musicdirect.com/c-647-speaker-cables.aspx?gclid=CN7YxOKcwLQCFUdxQgodIXsAQw
    F1nut Posts: 52,371
    Did you let the Audioquest cable burn in for at least 200 hours?
    The Blue Jean and Signal cable are both made from Belden wire, so they will sound pretty close. I can't remember about Monoprice, but it probably is too.
    These will be an upgrade from the above, http://app.audiogon.com/listings/speaker-mit-matrix-18-speaker-interface-8-ft-pair-2012-12-02-cables-75205-village-tx
  • markmarc
    markmarc Posts: 2,309
    Concur with F1, let them burn in for a while. Also, different cables can be affected in different ways by proximity to power cords. Although not easy try to have a clean run from amp to speakers with as much distance as possible from power cords.
    Former Staff Member TONEAudio
    2 Ch. System
    EndersShadow Posts: 17,753
    Check out Kimber Kable. They have some good stuff. The 4VS is within your budget with the possibility of getting 3 cables. Kimber's 8VS and 4TC are also possible if you dont go bi-wire and dont need more than 6 feet of length. Not sure if you could get all 3, but you should be able to get a pair for under 300. Both AudioAdvisor and NeedleDoctor are the only authorized internet dealers. They will make custom length's as well so you are not stuck with the standard lengths.
    I moved from MIT EXp2 to Kimber Kable 8VS internal bi-wire and really liked it. Good stuff! steveinaz runs 4TC IIRC.
    Some thoughts for you: bi-wire costs a little bit more than standard though so I wouldn't go that route as not all speakers can use bi-wire cable. This could matter if you end up deciding to sell the cables.
  • tommyt21
    tommyt21 Posts: 685
    Jessie, the Audioquest is like 20 year old cable i got it from my Medical Director, it should be completly burned in. I might be able to mail you some if you want to check them out your self. They are the flat version. You think the Signal will be simlar to my Bluejeans?
    Thanks every one I guess I'll keep looking before I pull the trigger on somethin. Enders I was looking at the Kimber also but thats at the top of my price range.
    Whats up Geoff.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    tommyt21 wrote: »
    Whats up Geoff.
    You may need to spend that much to really get a good set of cables that will make a audible difference. Plus good cables will work good regardless of the speakers or amps you use.
  • jbooker82
    jbooker82 Posts: 1,627
    Lasareath wrote: »
    I really don't know what ratio everyone else is at
    About where your at. 1K for my RTi's and 400 for my AudioQuest Type 8's.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 52,371
    Got ya. Thanks, but I'm good. :smile:
    Yep, both are Belden.
    Did you check out the link I posted?
  • BlueFox
    BlueFox Posts: 15,250
    tommyt21 wrote: »
    There's your problem. The electrons are either used up, or worn out.
  • cristo
    cristo Posts: 231
    For speaker cables to change, they've got to want to change or you're wasting your time. No one sided arguments, interventions, or persistent
    persuasions will work.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • ravaneli
    ravaneli Posts: 530
    lol, i have some experience too, but i think its fair if the op doesn't want me in to stay out.
    Happy New Year!
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • tommyt21
    tommyt21 Posts: 685
    I did I have heard alot about the MIT's Thats a good price too. I think I may stroll down to the HiFi shop to Demo some different Cables.
    Ravioli, I dont have the best ears, however I heard a audible difference, my brother in law heard a difference and so did my wife, who could care less about my constant tinkering. I did not say one was better than the other just that cables do influence audible differences in the signal they carry to your speakers.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • ErasmusBDragon
    ErasmusBDragon Posts: 113
    Installed tara labs space and time speaker cables in my bedroom system and it made a megadifference.
  • Geoff4rfc
    cristo wrote: »
    That cracked me up and yes!!!!!! IF it doesn't WANT to change, all the money in the world won't make a difference :mrgreen:
    ravaneli wrote: »
    Happy New Year!
    tommyt21 wrote: »
    What the heck did I miss here?? Was another ravitrolli quote deleted?
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    what do you guys think about the kimber kables 4&8 vs series mind you im 90/10 ht
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    edited January 2013
    tommyt21 wrote: »
    Well I like em a LOT personally. I went with 8VS internally bi-wired so I could bget the equivalent of 2 4VS connectors at the speaker end for my LSI's. I still havent gotten the center channel speaker cable yet, but its on my list shortly. I like them better than the MIT EXp2's I had but I did not run them both at the same time. I sold the MIT stuff and then a month later went to Kimber 8VS. The 8VS is VERY flexible and looks really nice as well behind my rack :smile:.
    I would suggest using their banana's as they are quite nice and by no means cheap and they dont cost any extra whereas the other spades add quite a bit to the cost.
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Enders i found a place that sells it at a great price if you do the diy kit
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    edited January 2013
    tommyt21 wrote: »
    Sells the wire without the connectors? I didnt think they had any other authorized distributors but for local hi-fi stores and AudioAdvisor and NeedleDoctor.....
  • Systems
    Systems Posts: 14,872
    edited January 2013
    Percy Audio has the VS REALLY cheap at the moment, on sale, by the foot, no termination.
    I built a 10 foot pair about 3 weeks ago for a guy.
    Testing
    Testing
    Testing
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    The place was called speakerlabs im going to check out the place pepsters talking about first
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • mantis
    mantis Posts: 17,656
    edited January 2013
    I suggest Type 4 from Audioquest , 4vs or 8Pr from Kimber Kable. Both are very good cables and should fit your budget well. I looked over your system and I believe either of these would be a nice fit. I'm leaning towards Kimber as you already are using the PPJ's.
    Dan
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2013
    Have you tried MIT AVT s2/s3 cables?
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Im going to go diy with the 8vs from the place pepster recommended you just cant beat the price. Funny thing is i just sold my pbjs to Viperz, however i do plan on getting some heros
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    edited January 2013
    I am going to keep that place for reference as I would love to get another set of 8VS for my home office setup but cant afford em right now and dont really need em terminated......
  • mantis
    edited January 2013
    tommyt21 wrote: »
    Hero's mate extremely well with 8TC. Don't even bother to terminate Kimber unless you have some Wire experience. They are difficult to terminate.
    Dan
    edited January 2013
    mantis wrote: »
    I agree, they look like they suck, although maybe Pepster will terminate em for ya :biggrin::razz::wink:
    As a FYI I have heard rumors there is a 12VS in the works. They would also be a pretty cool option and personally they would work great internally bi-wired.
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    I was thinking bare with tinned tips and pretty heat shrinking along with maybe some Techflex...
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • mantis
    edited January 2013
    tommyt21 wrote: »
    Why? Why not just buy them terminated? Kimber has wonderful spade and banana terminations.
    Dan
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    I am buying a bulk run at a signifigant savings it would cost me 3-4 times as much as to get a precompleted set.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • Geoff4rfc
    edited January 2013
    I'm considering that same thing now as well......Thank you very much Tommy 2 Tone!!!!
    I looked into the Kwik 12 from Kimber, they have the bulk roll but it looks pretty expensive. I'm going to do some searching around to see if I can find it cheaper.
