Rotel RMB-1095, overkill? How much should i pay?
z28chrismac
z28chrismac Posts: 7
edited December 2012 in Electronics
I recently came across an opportunity to make an offer for a used Rotel RMB-1095 amp. From my research I have found that they sell new for around $2000, so I was thinking of making an offer of 1K. What do you guys think? Ideally I am looking for three numbers
1) a price number that is way too much
2) an average selling price
3) a number or below that would be a steal, can't pass up
Thanks,
Chris
Main: 2x t90e's (monitor 60's)
Center: csi3
Sub: psw650
Surround:2x klipsch sf-1
Receiver: yamaha rx-a1000
Setup: bi-amped mains, 5.1
___________________
350" 1080p 3D Mitsubishi projector
AVR: Yamaha RX-V2700
Mains: T90e's (bi-amped)
Center: CSiii
Surrounds: 2x T90e's
Subs: 2x PSW650
Post edited by z28chrismac on
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Thanks,
    Chris
    Center: csi3
    Sub: psw650
    Sounds like you have it figured out Chris. I have seen em go as low as 650 and as much as 1700 used, so your 1K offer is a good one, if you really want it?? Good luck
    Waste of money imho, your speakers are easy to drive and you have a subwoofer supporting the bottom end. Put that coin into upgrading the speakers for best bang for your buck in SQ.
  • pearsall001
    pearsall001 Posts: 5,384
    If you can grab that RMB-1095 for 1K...by all means snag it. You have to keep in mind that this is one crazy hobby & at some point you'll move on to other speakers. With the 1095 in the chain you don't have to worry about what speakers you pick up...the 1095 will have no problem powering them. Bottom line...there's no such thing as "Too much power".
  • mantis
    mantis Posts: 17,637
    tonyb wrote: »
    Agreed at this point , better speakers would yield better results.
    Also agree as the RMB1095 is a awesome amp and most likely the last one you'll ever need for speakers up to about 10k. Even then it still shines.
    Price wise 1k is a great price. This amp holds it's value as amps don't really ever go bad. They last a very long time unless they get a voltage spike or to many brown outs. I can't stress enough about having good surge / voltage stabilization / line conditioning. Maybe look into the Panamax 5400 first , then move onto building the rest of your system.
    I'd also suggest changing out the surround to matching polks or swap out the front 3 if you like the Klipsch sound better. Either way it's important to have the same brand and series speakers all the way around. I never mix and match speakers unless I absolutely have to due to placement issues , even then I don't wanna.
    Dan
  • jephdood
    jephdood Posts: 1,691
    $1k for a 1095 is just a little high, IMO. I'd shoot for ~$800. But, for Monitor 60's? Nah, don't waste your money.
    "I did not slap you. I high-fived your face."
  • z28chrismac
    Thanks, I'll see if he will let it go for <1k...
    ___________________
    Center: CSiii
    Subs: 2x PSW650
  • mufsoman
    mufsoman Posts: 640
    I bought mine for $900. I would start a bit lower and work your way up though...
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
    Atmos: Polk OWM3 x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • cfrizz
    cfrizz Posts: 13,415
    ^This. That's a terrific price for a Rotel 1095. It will drive your speakers now and in the future to their full potential which is the most important fact, not whether others think your current speakers are worth the upgrade of the amp. My 22 year old RTA-8Ts that I paid 600.00 for are being driven by a 5 channel 405wpc Sunfire amp and have never sounded better. Don't let others put false limitations on your gear. Try it out, my guess is you will never go back to just having a receiver drive your speakers.
  • xftman
    xftman Posts: 153
    I regretted I did not go for a rotel 1095 for $800 mint condition. instead go for Emo XPA-5 new for $769.
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • Willow
    Willow Posts: 11,339
    I think there is a 1095 in the FM for 950. But if I recall he is in south FLA
  • michael1947
    michael1947 Posts: 775
    Get the amp, solid piece and you can ad a processor and speakers as they become available at reasonable prices.:arrowu:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • xftman
    xftman Posts: 153
    Does anyone how is the Emo return policy? Thinking return my 2 weeks xpa-5 assume the Rotel 1095 for $800 still available. I will have to talk to the seller (I know he never list on sale which is a good sign) but would like to know the return policy from Emo.
    thanks
    MAIN:
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • nguyendot
    nguyendot Posts: 3,594
    It's a great amp. I still have mine but it sits on a rack doing nothing......Until another day when I have a bigger house.
    Main Surround -
