OFFICIAL "INTEREST" THREAD -- Polk Terminal Cup Replacement, Aluminum Round Vintage
VR3
A lot of members have asked me about aluminum terminal cups for their vintage Polks.
I do not plan on stocking these and this would be something I would do with 10 pairs sold at a time so we can consider this the "first batch"
This is how it would go -
Phase 1) Have ten confirmed pairs
Phase 2) Ship off a terminal cup to my CNC shop for exact measurements and tooling.
Phase 3) Collect payment for terminal cups
Phase 4) Receive terminal cups, ship to you guys!
Specs of the terminal cups -
4 Binding post connections for bi-wire - for those that do not have BI-Wire SDA, you can install binding post that are not used or put 1/4" plugs in the holes
Neutrik NL2 cut out for the SDA (can be purchased along with the terminal cups)
Brushed aluminum, 1/8" thick
Laser Etched Polk Audio, +/-/SDA
I should be able to do these for $25.00 each + shipping - will fit in a flat rate box so $6.50 Shipping + Paypal fees
If you need NL2 connections, binding post, NL2 connectors for a cable or nice wire for the SDA cable that can all be talked about through email - Vr3Mods@gmail.com
So far I have the following wanting to do this -
1 Pair - Davemuell
2 Pair - Moose68Bash
1 Pair - Davemuell
Post edited by VR3 on
FYI, anyone using plugs will have to seal those to prevent air leaks.Political Correctness'.........defined
President of Club Polk -
Can you post a pic or drawing of what the cups would look like? I've seen pics of the binding post plates you do for your Xover work, which I prefer to the size/shape of the stock plastic cups.
Thanks!
edit: never mind, I just saw the other thread :redface:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
It will be a drop in replacement to the stock terminal cup... No cabinet modifications- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
i'm in
6 to go!
=]- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
bump- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Only 6 more to go -
Here is a picture of the regular plate for an idea of the look -
http://vr3mods.com/DIY_3ZRV.php- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I am in for a pair for my 1.2TLs. Would it be possible to add two binding posts for the SDA? I use a binding post for my SDA cable.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
I would have to order 20 identical plates.
the NL2 connection is superior in every way. It would be fairly easy and inexpensive to change your cable over. I have access to NL2 connections and can include them with the plates for under $20.00- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What I meant to say is if you could add one or two Binding Post Holes for the SDA Connection. This is assuming there can be room for an additional two binding posts on VR3s modified Terminal Plate.
I am currently using a binding post for my SDA Connection and my cable connections are all copper connected spades. Nutrik does not use copper in their connectors. They use Nickel. At this time, I do not wish to make changes to my current connections.
Thanks!Statistics show that 98% of us will die at some point in our lifetime.
I could always drill holes for you or you could put a plate over the nl2 to mount a binding post- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sounds good.
Where do I sign up for a pair?Statistics show that 98% of us will die at some point in our lifetime.
Here, we need 5 more pairs! Spread the word! :]- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Testing
Testing
Testing -
PolkMaster1 wrote: »I am currently using a binding post for my SDA Connection and my cable connections are all copper connected spades. Nutrik does not use copper in their connectors. They use Nickel. At this time, I do not wish to make changes to my current connections.
You may want to rethink that.SpeakON 8-pole (and 4 pole) yields less contact resistance than 5-way binding posts even if those be cold-forged to the non-plated Cardas patented binding posts
I now use Neutrik NLT4FX-BAG connectors for my SDA cable connections and wish I had done so years ago.Political Correctness'.........defined
Still needing 5 more pairs to be spoken for!
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Still needing 5 more folks...
Imaginge this.. but round... says Polk Audio in the classic logo across the top- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
We need 3 more pairs to be commutes to...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Committed*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey, put me down for two pair.SDA SRS 3.1TL, Adcom GFP710 (preamp), GFA5400 amplifier, Pro-Ject TT
SDA SRS (circa 1988), Integra DHC 60.3 (HT preamp) Adcom GFA555 II, CS400i (center), Monitor 4.6 II (rears) Adcom GFA2535 & Oppo BDP-103, TCL 55R617 55" 4K Display, RTA 15TL (crossovers by VR3), Adcom GFP710 pre & GFA545 II amplifier, NAD C545BEE. AppleTV 4K
Other Polks not in service currently; SDA2a, SDA CRS+, SDA SRS 2.3, Monitor 4.6 II, Monitor 5jr+ -
One more pair! I am waiting on confirmation from Phil to send his cup to the CNC shop... Once I receive the green light I will get the ball rolling!
thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey,
Let's do it!
PhilFamily Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
I've really been back and forth asking if I really need these... I'll probably regret not picking up a pair down the road.
F it! I'll take a pair. It will make up for the pair of original plates I couldn't use. -
Trey,
Will the hole sizes accomidate Larry binding post cup "rings" and the hex bolts that go in them? That is, what screw hole sizes to attach the binding post plates to them?
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Trey,
I thought such an item didn't exist? Just the custom rings he made for his rectangular plate and DK's.
I guess I should ask, will these be surface or be of a recessed design like the current cups? -
These will be an exact drop in replacement of the stock cups. They will be a "Plate" - no rounded edges. Please see my Vr3 plate above for reference!
I will have the ball rolling on these, will email the CNC shop right now!
Once I receive final pricing from the CNC shop I will PM everyone final pricing and payment info!
Thanks!
Also, although we have ten pairs spoken for - if you would like to order a set the CNC shop will make more!
Let me know!
Here is the current list I have for those wanting a pair -
1 Pair (2) - Davemuell
2 Pair (4) - Moose68Bash
1 pair (2) – SDA2Mike
1 pair (2) – Polkiemaster1
2 pair (4) – Denzel
1 pair (2) – Drenis
2 pair (4) – Michael1947
Will be sending off the terminal cup Monday!
