OFFICIAL "INTEREST" THREAD -- Polk Terminal Cup Replacement, Aluminum Round Vintage
VR3
VR3 Posts: 29,386
edited February 2014 in DIY, Mods & Tweaks
A lot of members have asked me about aluminum terminal cups for their vintage Polks.
I do not plan on stocking these and this would be something I would do with 10 pairs sold at a time so we can consider this the "first batch"
This is how it would go -
Phase 1) Have ten confirmed pairs
Phase 2) Ship off a terminal cup to my CNC shop for exact measurements and tooling.
Phase 3) Collect payment for terminal cups
Phase 4) Receive terminal cups, ship to you guys!
Specs of the terminal cups -
4 Binding post connections for bi-wire - for those that do not have BI-Wire SDA, you can install binding post that are not used or put 1/4" plugs in the holes
Neutrik NL2 cut out for the SDA (can be purchased along with the terminal cups)
Brushed aluminum, 1/8" thick
Laser Etched Polk Audio, +/-/SDA
I should be able to do these for $25.00 each + shipping - will fit in a flat rate box so $6.50 Shipping + Paypal fees
If you need NL2 connections, binding post, NL2 connectors for a cable or nice wire for the SDA cable that can all be talked about through email - Vr3Mods@gmail.com
So far I have the following wanting to do this -
1 Pair - Davemuell
2 Pair - Moose68Bash
Post edited by VR3 on
«134
    F1nut Posts: 51,673
    edited December 2012
    FYI, anyone using plugs will have to seal those to prevent air leaks.
  • drumminman
    drumminman Posts: 3,396
    Can you post a pic or drawing of what the cups would look like? I've seen pics of the binding post plates you do for your Xover work, which I prefer to the size/shape of the stock plastic cups.
    Thanks!
    edit: never mind, I just saw the other thread :redface:
    VR3 Posts: 29,386
    It will be a drop in replacement to the stock terminal cup... No cabinet modifications
  • sda2mike
    sda2mike Posts: 3,131
    VR3 Posts: 29,386
    6 to go!
    VR3 Posts: 29,386
    bump
    VR3 Posts: 29,386
    Only 6 more to go -
    Here is a picture of the regular plate for an idea of the look -
    http://vr3mods.com/DIY_3ZRV.php
  • PolkMaster1
    PolkMaster1 Posts: 847
    I am in for a pair for my 1.2TLs. Would it be possible to add two binding posts for the SDA? I use a binding post for my SDA cable.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
    VR3 Posts: 29,386
    I would have to order 20 identical plates.
    the NL2 connection is superior in every way. It would be fairly easy and inexpensive to change your cable over. I have access to NL2 connections and can include them with the plates for under $20.00
  • PolkMaster1
    What I meant to say is if you could add one or two Binding Post Holes for the SDA Connection. This is assuming there can be room for an additional two binding posts on VR3s modified Terminal Plate.
    I am currently using a binding post for my SDA Connection and my cable connections are all copper connected spades. Nutrik does not use copper in their connectors. They use Nickel. At this time, I do not wish to make changes to my current connections.
    Thanks!
    VR3 Posts: 29,386
    I could always drill holes for you or you could put a plate over the nl2 to mount a binding post
  • PolkMaster1
    Sounds good.
    Where do I sign up for a pair?
    VR3 Posts: 29,386
    Here, we need 5 more pairs! Spread the word! :]
  • Systems
    Systems Posts: 14,873
    Is this a Karma?
    In please! Attachment not found.
    Testing
    Testing
    Testing
    F1nut Posts: 51,673
    You may want to rethink that.
    SpeakON 8-pole (and 4 pole) yields less contact resistance than 5-way binding posts even if those be cold-forged to the non-plated Cardas patented binding posts
    I now use Neutrik NLT4FX-BAG connectors for my SDA cable connections and wish I had done so years ago.
    VR3 Posts: 29,386
    Still needing 5 more pairs to be spoken for!
    Thanks!
    VR3 Posts: 29,386
    edited January 2013
    Still needing 5 more folks...
    Imaginge this.. but round... says Polk Audio in the classic logo across the top
    VR3 Posts: 29,386
    edited January 2013
    We need 3 more pairs to be commutes to...
    VR3 Posts: 29,386
    edited January 2013
    Committed*
  • Denzel
    Denzel Posts: 78
    edited January 2013
    Trey, put me down for two pair.
    SDA SRS 3.1TL, Adcom GFP710 (preamp), GFA5400 amplifier, Pro-Ject TT
    SDA SRS (circa 1988), Integra DHC 60.3 (HT preamp) Adcom GFA555 II, CS400i (center), Monitor 4.6 II (rears) Adcom GFA2535 & Oppo BDP-103, TCL 55R617 55" 4K Display, RTA 15TL (crossovers by VR3), Adcom GFP710 pre & GFA545 II amplifier, NAD C545BEE. AppleTV 4K
    Other Polks not in service currently; SDA2a, SDA CRS+, SDA SRS 2.3, Monitor 4.6 II, Monitor 5jr+
    VR3 Posts: 29,386
    edited January 2013
    One more pair! I am waiting on confirmation from Phil to send his cup to the CNC shop... Once I receive the green light I will get the ball rolling!
    thanks
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited January 2013
    Trey,
    Let's do it!
    Phil
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    I've really been back and forth asking if I really need these... I'll probably regret not picking up a pair down the road.
    F it! I'll take a pair. It will make up for the pair of original plates I couldn't use.
  • headrott
    headrott Posts: 5,496
    edited January 2013
    Trey,
    Will the hole sizes accomidate Larry binding post cup "rings" and the hex bolts that go in them? That is, what screw hole sizes to attach the binding post plates to them?
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    headrott wrote: »
    Trey,
    I thought such an item didn't exist? Just the custom rings he made for his rectangular plate and DK's.
    I guess I should ask, will these be surface or be of a recessed design like the current cups?
    VR3 Posts: 29,386
    edited January 2013
    These will be an exact drop in replacement of the stock cups. They will be a "Plate" - no rounded edges. Please see my Vr3 plate above for reference! :)
    I will have the ball rolling on these, will email the CNC shop right now! :)
    VR3 Posts: 29,386
    edited January 2013
    Once I receive final pricing from the CNC shop I will PM everyone final pricing and payment info!
    Thanks! :)
    VR3 Posts: 29,386
    edited January 2013
    Also, although we have ten pairs spoken for - if you would like to order a set the CNC shop will make more!
    Let me know!
    Thanks!
    VR3 Posts: 29,386
    edited January 2013
    Here is the current list I have for those wanting a pair -
    1 Pair (2) - Davemuell
    2 Pair (4) - Moose68Bash
    1 pair (2) – SDA2Mike
    1 pair (2) – Polkiemaster1
    2 pair (4) – Denzel
    1 pair (2) – Drenis
    2 pair (4) – Michael1947
    Thanks!
    VR3 Posts: 29,386
    edited January 2013
    Will be sending off the terminal cup Monday! :)
