Plasma or LED?
mu1166
mu1166 Posts: 172
edited February 2013 in Electronics
I'm caught between getting a new Panasonic Plasma (not sure if the ST or GT would suit me better) or a Samsung LED (7000 or 8000 series). Also looking at the Samsung 7000 Series Plasma. I think I may have some problems with glare due to placement with windows (6' wide windows). I don't know what the off axis viewing will be like with the LED tv.
I'm looking to get a 60" for the wall placement location.
Attached is a quick drawing of the location of the TV in the room.
AVR: Pioneer Elite SC-67
Mains: Polk LSiM707
Center: Polk LSiM706c
Rear: Polk LSiM702F/X
Sub: SVS PC12 Ultra
TV: Panasonic VIERA TC-P60GT50
DVD: Xbox 360
NMT: Popcorn Hour C-200
Post edited by mu1166 on
«1345
  • mu1166
    mu1166 Posts: 172
    edited December 2012
    Forgot the attachment.
    Living Room.pdf
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • thsmith
    thsmith Posts: 6,082
    Panny Plasma GT. I am biased, after the POS and the treatment from Crapsung I will never own ANYTHING THEY MAKE, even if what they make is the best ever made of what ever it might be.
    I have a 65" GT and love it. A friend of mine sells Panny Plasma for Panasonic, GT vs VT he felt the GT was a better value. Good enough for me and I hve never looked back.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Plasma definitely. Many leds now have reflective screens too. Lg 60pa6500 I bought last fall it is fantastic for under a grand.
  • oleon621
    oleon621 Posts: 178
    The Panasonic ST series is probably your best bang for the buck I believe. If your all about picture quality then plasma is the only way to go. There's only once LCD that I can personally vouch for and that's the LN52A650 calibrated(i own it) and its amazing. Better than several of the high end LCD/LED TV's out there. Its old in age but definitely made with picture quality in mind.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • mu1166
    mu1166 Posts: 172
    I do want a good picture quality (who doesn't). I am very worried about the glare from the windows in my living room area. I was leaning towards the Samsung LED models for this reason. I know that the Plasma will give me the picture quality.
    I guess I'm just really concerned for the amount of possible glare on the Plasma with the East and South windows in that room.
    I plan on having the TV calibrated after a little break in period.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • Upstatemax
    Upstatemax Posts: 2,851
    I love my Samsung plasma...
    I've owned a few Samsung TV's all over my house and purchased my father a 52" Samsung LCD TV 5 years ago that's still going strong.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Do your homework before buying a Samsung TV. I and others here and elsewhere have had very bad luck with them. I know there are at least a couple threads on here, one of which I started so you may want to have a look at those, especially if you're looking at a Sammy plasma.
    F1nut Posts: 52,298
    Panasonic plasma.
  • AsSiMiLaTeD
    thsmith wrote: »
    EXACTLY, I'm glad I'm not the only one who feels this way. I actually just got rid of the last Samsung product I owned a couple months back, and never again.
  • nhhiep
    nhhiep Posts: 877
    which brand do you like? having both Samsung LCD and Pany Plasma. If I am going to get a TV now.
    Plasma = Pany
    LCD/LED = Samy
    I don't like the clay effect with LCD.
  • mantis
    mantis Posts: 17,637
    Figure out a way to control the light in your room. No display does well with direct sunlight.
    Plasma is still the very best picture quality you can get. No motion blur like the LED's have not to mention they look like pop up books , very fake looking.
    Panasonic makes the best Plasmas on the market. Both he ST and GT are excellent models , get the GT if you can afford it. The ST is a stellar performer at it's price point so if you can't swing the GT , you'll be tickled pink with the ST.
    Dan
  • Dimehead
    Dimehead Posts: 31
    Without question, LED LCDs are the brightest TVs you can buy. Some models are capable of well over 100 footlamberts. To put that in perspective, in a movie theater you're lucky if you get 5. CCFL LCDs are a close second.
    Plasmas just aren't that bright. It's all relative, though, as plasmas are still likely way brighter than old-school CRT tube TVs. So plasmas aren't "dim," but they aren't nearly as bright as LCDs.
    The question is, do you need that light output? In a dark room, 100 footlamberts will be searingly bright, and could cause eye fatigue. In a bright room (daytime/sunlight) a plasma might be hard to see.
    Plasmas are better if you have people sitting off to the side like I see here in you layout.
    I myself Like the LED better. I have my PC hooked up to mine and it's awesome as to where plasmas don't work as well as the new LED LCD TV's do. Just my opinion. Good luck !!!
    Front Stage
    Polk Audio MM6501 Door's
    Polk Audio MM5251 Kick Panels
    Back: Polk Audio MM651
    Sub : 2x Polk Audio MM1240dvc
    Front's : Soundstream Reference 700s
    Back : Polk Audio PA D200.2
    SUB : Soundstream Referencre 1000s 1ohm
    Alpine 3331 EQ
    Alpine cda-9856 Receiver
  • Willow
    Willow Posts: 11,339
    Love my Panny plasma beats most of the tvs I have seen at other peoples places
  • Sherardp
    Sherardp Posts: 8,038
    The only thing that beats a plasma is a 4K projector......Hmmm. Luckily I have both, so yeah plasma my friend.
  • gce
    gce Posts: 2,158
    Panasonic plasma, get one while they last cuz I hear Panasonic is going to quit making Plasma's.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
    EndersShadow Posts: 17,749
    Panasonic Plasma:
    I have a similar setup and got a Panasonic ST60 (yours would be a newer model than mine) and LOVE it. Glare isnt that bad at all (I get more glare from the window BEHIND the couch than the one next to it) and viewing angles are STELLAR compared to my 56" DLP.
    Also I couldnt play online games on my dad's LCD due to it just not tracking right compared to the controller. I know lots of folks have this issue with lag and there wasnt a way to turn off the 120hz refresh rate (which was causing the issues i believe). I also noticed that the movies just looked weird, like everything was too smooth. My wife even noticed and commented on it and that means its BAD when she can see it :biggrin:
    Here are some pics.
  • tommyt21
    tommyt21 Posts: 685
    Go Panny Plasma. Skip Samsung most of them are just giant mirrors anyway and if you have trouble with light in your room a glossy screen is just going to make it worse.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • badchad
    badchad Posts: 348
    In that size range, I'd probably get some curtains and go with a plasma.
    I made the decision to opt for an extra 5" of screen real estate, and went with a 70" LED. After calibrating, the differences between my old plasma are very subtle and probably won't be noticed by the vast majority of casual viewers. In my personal opinion, I found the differences regarding picture quality to be somewhat overstated (e.g., the total superiority of plasma).
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • steveinaz
    steveinaz Posts: 19,546
    Love my 58" Panasonic plasma. Cal'd using DVE, been great ever since.
  • cstmar01
    cstmar01 Posts: 4,424
    I own a Panny VT25 50" in the bedroom and a 55" ST50 in the living room. You can't beat the picture quality for them. I have a window to the side in my bedroom and there is glare in the morning as it faces the sun rise so I just close a curtain and all is well.
    The other sits in front of my windows but I have lights right next to the screen and don't have problems with glare. I would not go with an LED/LCD ever as I just don't care for it. I think they do not have the color and blacks that Plasma can have.
    My ST is also better in terms of picture than my older VT line from 2010.
    Also it is not true that they are stopping production of plasmas. They were talking about decreasing the amount as sales were down (don't understand that one) but that was it, not that they were going to kill off the plasma.
    and Sharp IMO looks like garbage still even calibrated, just no. So no I don't agree that the merits of plasma are overstated.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Tint your windows.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • ErasmusBDragon
    ErasmusBDragon Posts: 113
    Very satisfied with a Samsung 50" LED. Directv was great with it; now using cable.
  • mu1166
    mu1166 Posts: 172
    Not much love for Samsung's here. Have that really had that many problems with them?
    I own 2 Samsung dlp's which have never given me any problems at all.
    I see all the love for the Panasonic Plasma. Anyone have any experience with the Samsung Plasma?
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
    mu1166 wrote: »
    From all the research I did I came to the following conclusion:
    Plasma = Panasonic > Samsung
    LCD = Samsung > Panasonic
  • disneyjoe7
    I have a co-worker which started to work on flat screens and told me a lot about tv brands....
    LG
    Samsung
    S*ck
    Panasonic rules.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • rpf65
    rpf65 Posts: 2,127
    Bought a Panny plasma the week after the Superbowl last year. Got it for 60% off, because they were getting ready for the new model line. I love this TV. The only glare I experience is for about 10 minutes, when the sun is in the perfect position, and the front door is open. Probably the white walls that are more of the cause.
  • jbooker82
    jbooker82 Posts: 1,627
    I would be in more favor of a LED/LCD if they didnt have the cartoon motion. When your watching a real football game and the people come maching out on the field and it looks like a PS3 / XBox360 Madden Football game it isnt right.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Polkie2009
    Polkie2009 Posts: 3,834
    I've been looking at various customer reviews on LCD/LED and plasma tvs over at Amazon. Seems like the brands I really liked ,such as Samsung,Toshiba, Panasonic,Vizio, and a few others, the customer service the last couple of years have been treating their customers like crap when they have one of the newer tvs that no longer work. And I'm talking about tvs that are less than 6 months old, some even a few weeks old. The companies don't want to honor their warranty, say it's not their problem. That lack of customer appreciation tells me not to spend my hard earned money with them. And yes, SAMSUNG IS THE WORST AT THIS.:evil:
  • Upstatemax
    mu1166 wrote: »
    I've owned my Samsung plasma for three years with zero issue. When I was looking for a new tv I checked out both Panny and Samsung plasma screens and I liked the Samsung picture better...
    The Panny technically had a better black level that I found to be hardly noticeable, but the Samsung had better color reproduction to me...
    Almost everyone I know has a Samsung plasma or LCD/LED and I have not heard of or seen a single problem with one of them. LG on the other hand, absolute crap...
  • janmike
    janmike Posts: 6,146
    Love my Panny Plasma and would purchase another.
    Michael ;)
    NORTH of 60°
