Whinning noise damage speakers?
POLKHT
POLKHT Posts: 138
edited December 2012 in Troubleshooting
I need some help. Does anyone know if the whinning noise caused by my amps capacitors discharging after being turned off damage my speakers? Thanks in advance.
Post edited by POLKHT on
    edited November 2012
    Shut the pre amp off first, amp last, so no sound hits the speakers. Might be time to do some refurbishing on that amp.
  • Msabot1
    Msabot1 Posts: 2,098
    Absolutely! Sounds like a equipment power supply! Whining during operation or just at shutoff with no input signal?
  • POLKHT
    POLKHT Posts: 138
    tonyb wrote: »
    Thats exactly how I turn off my system. The pre first, then the amp goes off. It just came back from the shop. Had to replace the biases to fix a heat issue. It may have to go back.
    So, will the whinning cause damage to my speakers?
    Thanks.
  • shawn474
    shawn474 Posts: 3,052
    I just leave my amp on at all times.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • BigGilles
    BigGilles Posts: 6
    Helo,
    yes this noise can cause a BIG problems with the tweeters and the crossovers, :eek: and the rest, may be not,:rolleyes: BUT.... actually fix this amplifier, it is not a good idea to use this device,
    Take care !
    have a nice day !
  • drgalexo
    drgalexo Posts: 159
    Sounds like someting maybe out of phase. Is the whinning very loud?
  • 20hz
    20hz Posts: 636
    I get that to but mine is when the sub amp gets turned on LOL sure its not from a significant other ?
    Someone will have a awnser just make sure you turn it off as tonyB suggests or look into a panamax a/c switch box .
    regardless if its louder than talking volume you will damage your tweeters ( fix asap )
  • POLKHT
    POLKHT Posts: 138
    The amp was recently repaired. Had all the 3 bias and 3 diodes replaced to fix a heating issue. I took it back to the shop and was told that there was nothing wrong with it. Turns out this only happens with my B&W speakers, no noise when my Polks, Energy or Paradigm speakers are hook up. Very weird. Anyone have any similar issues?
  • lanchile
    lanchile Posts: 560
    POLKHT wrote: »
    That sounds like power supply caps discharging, maybe that amp has not output relays to "mask" thumps at turn off/on. this is normal for many amps (design), you will hear it louder with speakers with high SPL.
    I had a few amps with this thumps noise too, I remember one of them was an Adcom. Check amp if it has output relays/soft start and if it does not...probably it is normal. if thumps are not too loud, I would not worry too much. Just get a digital meter and check voltages at the speaker terminals to know how much voltage are those thumps. also check for dc offset!!!
    PS:Turn off source first. other way you will hear the music fading out with "static" sound
    Make it simple...Make it better!
  • POLKHT
    POLKHT Posts: 138
    I agree, it might be the caps discharging. I also turn off the pre/receiver first, then the amp.
    The odd thing is that I only hear the whine from the B&W's, not the other brands of speakers I have tried. Why is it just the B&W's that whine?
  • lanchile
    lanchile Posts: 560
    POLKHT wrote: »
    Higher SPL?
  • Speedskater
    Speedskater Posts: 495
    tonyb wrote: »
    The standard pro-audio turn-on / turn-off procedures are:
    Turn-on: First mic pre-amps then processors and console and finally power amps.
    Turn-off: First power amps then processors and console and finally mic pre-amps.
  • DracoAmericanus
    DracoAmericanus Posts: 112
    is there a protect relay that may not be opening up at shut own, i have seen them stick closed
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
