PCB Board repair sealant
pitdogg2
pitdogg2 Posts: 27,244
edited October 2012 in DIY, Mods & Tweaks
I need to know what anyone here would use to seal a PCB after repairs have been made. As most of you know you need to scrape off the green lacquer to get to the traces. What have you used to seal the area? I have tried nail polish but the thermal expansion and contraction will not allow the polish to stay more than a week or so. Is there a epoxy or something that would work long term that will not cost more than a few dollars. I have seen some stuff I googled PCB repair but it was close to 200.00 and way more than I want to spend.
Also keep in mind it may need to also come off so we have that to think of also.
Post edited by pitdogg2 on
