PSW111 or PSW505
I can get my hands on a used PSW111 for $130 or a used PSW505 for $150. Do these sound like good deals? Which would be a better choice? I will be hooking it up to an Integra DTR30.3 with RTi25s and a CSi3 up front and New Advents for surrounds. I will be using more for music then for HT.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
  • dorokusai
    dorokusai Posts: 25,576
    edited September 2012
    PSW111 hands-down for music as it's real quick and digs deep enough for music. The PSW505 is a HT specific subwoofer and sounds a bit fat and loose when pushed to the limit. The PSW111 should be a pretty seamless transition with your RTi25 whereas the PSW505 will just be big bass.
    For music? It will add more punch and low end rumble but I prefer a faster subwoofer for music, something punchy and tight which the PSW505 is not. Just my observation and it's your money and needs that may not reflect mine.
    Good luck. Let us know what you choose.
    Mark
  • teekay0007
    teekay0007 Posts: 2,289
    If you do go the 505 route, you might as well wait for Newegg to drop their price to $200 (shipped) again, which they do on a semi-regular basis. That extra $50 gets you NEW over used and a full 5-year warranty from Polk.
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited October 2012
    dorokusai wrote: »
    ... The PSW505 is a HT specific subwoofer and sounds a bit fat and loose when pushed to the limit. ... the PSW505 will just be big bass.
    For music? It will add more punch and low end rumble but I prefer a faster subwoofer for music, something punchy and tight which the PSW505 is not. ...
    These have been my observations as well. I don't even use it for a lot of bassier heavy techno stuff like Daft Punk because it's too damn sluggish. And the A9's do fine on their own.
    Is a decent rumbler for HT, but even then with too much volume it looses punch quickly.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Tankman
    Tankman Posts: 419
    edited October 2012
    +2,I agree with both,I have two of the PSW505's they do put out good bass for HT,for music?"dorokusai"is spot on with his post about the PSW505.They are a great buy for the money.I am looking into one of Polk's upper end sub's to upgrade soon.For music don't need them at all with the LSi-15's.
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    Must be open season on spammers.
  • Easy Runnin
    Easy Runnin Posts: 501
    edited October 2012
    hanks for the advise Teekay. I checked Newegg and the PSW111 was on sale for $149 with free shipping! The next day it was back to $299. I think maybe the person updating the website for Columbus day made a mistake and I was there at the right time.
    I've had it for a couple weeks now and I like it. Since I added the sub I swapped out the advents with an old pair of paradigms bookshelves I had in zone 2. HT sounds really good, but I'm still tweaking the music. Audyssey is by no mean perfect.
    One thing I noticed is the picture on newegg shows a separate LPE in,but the one I received does not have a separate LPE in. Is the separate LPE something that was recently added or something recently removed? Is this something to be concerned about?
