Plasma or LCD?
onebadchad
Buying a new TV, 55 inch im looking at, just looking for opinions, pros or cons between plasma and LCD.
Hello Kitty am/fm CD player
Post edited by onebadchad on
Plasma has better blacks but also isnt as bright as LCD (which tend to do well in VERY BRIGHT rooms). Plasma has better off axis viewing angles than LCD. Plasmas normally are cheaper per inch from 55" over.
LCDs work great in a bright room where your planning on keeping windows open 24/7, but IMHO Plasma is just overall better if you can deal with a bit of glare.
Check out my setup in the system showcase of my 60" Plasma. I have a window right next to it we normally have open and get some glare from the window behind the couch, but at night its normally not an issue."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
onebadchad wrote: »Buying a new TV, 55 inch im looking at, just looking for opinions, pros or cons between plasma and LCD.
LCD Blacks are better I think... both are good but when they go bad time for a new one.. unlike DLP'S just change the bulb
and it like buying a new TV.
I have a 60" DLP HD and Love it.. not many people like changing bulbs every 3 years. DLP's Prices are better. I only paid $1500 brand New. I think LCD or LED 60" would cost close to $4,000 if not more. sure you could always buy used. but come to think of it Prices are coming down.PolkAudioClyde -
Better picture on the Plasma IMO.
My last purchase was a plasma. I went to a couple of electronics stores, and just started looking at the sets. Different stores use different lighting levels, but they all seem to use factory pre sets, so it's a fairly even comparison. We all have different tastes, and if you're worried about glare from a window, shine a flashlight at an angle towards a screen to simulate it a little. Did that also.
LCD Blacks are better I think....
In general dollar for dollar Plasma's do better blacks. With a LCD or LED( LED is still a LCD) the liquid crystals have to block the back lighting. The crystals in the LCD still allow a little light through. This causes lighter colord blacks, or even a real dark blue / purple black color. The high end LED's probably do just as good as a plasma because they have local diming. So when the TV needs to produce black in a certian area it can shut the LED's off behind that area. That way the crystals dont have to try to block a bright white light.
Your going to pay a lot more for a LED with local dimming vs. a plasma.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Then you have to worry about the wierd motion that some LCD tv's make.AVR: Onkyo Tx-NR808
Rear: FXI A4
Yup, my dad has one of those TV's with a AWESOME 120hz refresh rate. I tried to play Halo online 2 times couldnt do it. Went through the entire manual and couldnt figure out how to make it actually look right. Even my wife said with movies they look too cartoonish to be worth the money."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have a really nice Samsung LED LCD and it is a really good set
But my TV room is very bright and a plasma would not work well in there
The one thing that you need to consider is how much light the room gets
If it gets alot of natural light during the day a plasma will suck with all the bright light
A plasma in the right room definitely offers the best picture by far over a LED LCD, it is a much warmer life like picture from what I have experienced with flat panels -
Plasma by far has the better picture, more natural looking. They do look better in a darker room but not bad in a lighter room. The newer ones are getting better in lighter rooms. You have a wider angle of view then an LCD. I'd go with a VT50 Panasonic.Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Panasonic Plasma GT series, thank me laterSpeakers: SDA-1C (most all the goodies)
60" Plasma
Go Plasma.
_____________________________________________________________________________________
AVR: Denon AVR-3805, AMP: Parasound Model 2250, Front: Polk RTIA7, Center: Polk CSIA6, Surrounds: Polk FXIA6, Sub: Polk DSW PRO660WI_____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Sorry. For the reasons stated above by others. I don't need to repeat them.
DAC: Bricasti M1SE
I would be totally cool with the ST series from this year. The ST from this year has the panel as good as the GT from last year. The GT from this year has a panel as good as the VT from last year.
I am rocking the ST60 from last year and have no regrets besides I couldnt find the extra 200 for the ST65 :biggrin:."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Just asking here.I was once told that Plasma does not have same playing life time of a lcd.If one was an avid tv watcher this could
be problematic if this is true. Again this is not an opinion and could be just plane misinformed.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Not true. There all roughly the same. You'll want a new one anyhow long before they wear out.
leftwinger57 wrote: »Just asking here.I was once told that Plasma does not have same playing life time of a lcd.If one was an avid tv watcher this could
Panasonic: States in new specifications that new plasma TVs and monitors are good to 100,000 to half life.
Sony: Now out of the plasma market. Does not list a figure for LCD lineup.
Samsung: Lists 100,000 hours for plasma lineup.
LG: States 100,000 hours for both plasma and LCD.
Sharp LCD panels: States 100,000 hour life.Anaheim Hills CA,
I prefer plasma.
LCD for my everyday tv
Plasma for my Saturday night movies and sports!!! -
Costco had a stupidly cheap 1080p Panasonic plasma on display last weekend. Looked like it was in the 50"-60" size range (not sure), for less than $700.00 That's about one half of what I had to pay approximately three years ago. Costco also provides an additional year of warr. coverage. Edit: Looks like it's a 50", on sale thru 9/29 for $599.00 + $100 if shipped. That's cheap 1080p viewing !:eek:
So if you watched your tv 24 hrs a day it would hit its half life in 11 years, or if you just watched it 12hrs it would be 22 years. I imagine I would get a new tv due to technology upgrades before I hit the half life.AVR: Onkyo Tx-NR808
Rear: FXI A4
Plasma for a dark room and lcd for a lit up room. Some of the higher end plasma TV's have a pretty decent anti glare on them compared to some of the cheaper counterparts they are still prone to showing light cracks in the room. My personal preference is my plasma in the media room compared to the LCD in the main part of the house. -
I don't know if anyone else has this problem when viewing movies on an LCD, but when I see a movie special fx/CGI, it just looks weird to me. I remember over a year ago, I was at Best Buy just looking around. They had Night At the Museum playing on a bunch of sets. It was so distracting seeing Ben Stiller supposedly looking at some computer generated character. Like the angle was off. He wasn't looking in the spot where the character was supposed to be. The plasma sets don't have that problem when I view them.
I'm still a huge plasma guy. Love my VT and only thing I would change is going bigger. The Panny ST's are very nice and so are the GT's.
LCD/LED still don't have the right look to me.
OLED that will be different, however street price on the 55" is stated to be around 7-8K so not really what most people will be getting right away -
Have a new Panny 65" Plasma, and love it. There is a large picture window 90 degrees from it with no problem. This set replaced a SONY 55". Night and day diff. Love the new set.
I've had a 50in Toshiba for well over 5 yrs now and have never had a problem with it. I think the picture is more true to life than LCD. The only negative is the glare in a sunny room
My led-lcd puts off a lot less heat than the plasmas do, that's one of my favorite things about it. In a small room, it's good to take that into consideration as well.TV - LG 42" LED
Receiver - Pioneer VSX-521
Front speakers - Polk Monitor 40's Series II
Center - Polk Monitor CS1 Series II
Surround - Polk Audio OWM3
Subwoofer - JBL L8400P
"I was born with music inside me. Music was one of my parts. Like my ribs, my kidneys, my liver, my heart. Like my blood. It was a force already within me when I arrived on the scene. It was a necessity for me-like food or water."
~Ray Charles~ -
Gotta go with the plasma here. Having had LCD's before, the plasma is heads & shoulders better in my opinion.
Heres a little reading for you. http://plasmatvbuyingguide.com/plasmatvreviews/plasma-vs-lcd.html
Yep that is the cartoon affect.AVR: Onkyo Tx-NR808
Rear: FXI A4
