IOS 6 Sucks Bigtime on the IPad
BlueFox
This upgrade is terrible. It is impossible to type. The response is terrible. Scrolling the screen goes white instead of smoothly going by. I am going to have to use my laptop for posting, and the IPad for reading. apple stock should tank due to this POs. Even the magnifying glass is missing for trying to edit. Pos pos pos pos
Post edited by BlueFox on
I thought they weren't going to release it for that model.
I assume you have the original ipad? That thing is a dinosaur... -
I'm in the middle of the update on my iPhone 4. I hope it doesn't screw it up too bad. I thought I would wait out the masses for the upgrade to the 5. $200
for a 1/2 inch is pretty steep........:cheesygrin:HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I have the latest model with max memory. It is a few months old. I am on my laptop now since the Ipad sucks so bad with IOS6. Time to get onto Apple and other blogs and let them know just how bad this thing is.
As you type other bizzare key options appear. Unbelievable. No testing at all done for this release. Jobs is turning in his grave.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Something is wrong. I upgraded to iOS 6 on my iPad (latest model) and it's perfect. Not experiencing anything that you're describing. Have it on my iPhone 4 and its just fine there too. Do a backup, then do a full factory refresh. Then restore from the backup.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Same here, I love the update for my 4s and iPad. Sorry you're having issues but i'd try a reset first too, it's really better.
I have to agree ;I have the three and mind works perfectly as well. Backup and reset should fix it for ya.
Cheers Roger -
Okay. I did the reset and that fixed the bizarre keyboard operation. Now I cannot login to Yahoo, but on the laptop it is fine. Apple really fracked up with this release. There are more issues here than just Maps.Lumin X1 file player, Westminster Labs interconnect cable
Man-o-man. What a nightmare. I went into Safari and deleted all cookies, history, and web data. Now I can log into Yahoo. Hopefully, I am back to where I was before upgrading. The funny part is my IPad is about as close to stock as you can get. I have added 2-3 apps, and bought one book. Yet, the upgrade went all fubar. I guess that is why I have always been a great QA engineer. All this wierd stuff happens to me. :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
It sounds like a fluke to me, glad it's coming together for you thought.
Just updated and it is working flawlessly...
-Saftgeek -
Mine is good with the iPhone 4. The only issue is iTunes won't seem to let me move app icons within its program. No biggie though. I am thankful that the OS upgrades don't kill the earlier hardware versions as often and a Windows upgrade does on my PC. With Windows, each OS seems to take a new PC.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
My iPod Touch 4G seems to work OK. It does seem a little slower but nothing bad. The worst thing however is iTunes. Did the backup and restore but for some reason it didn't restore my music - all 3700+ songs. After messing with it a while it finally "found" the songs from my NAS. Then 3 hours later to resync all the songs. How stupid that it would have to delete all of them and then put them back on.
I hate iTunes. -
I upgraded to IOS6 for the IPhone 4s and I have no issues so far. If anything my phone seems faster,But I'll keep and eye out. Sorry your having trouble with your iPad.Dan
I reset the iPad yesterday and it worked fine for a while. Now the same problem is back. Trying to scroll up or down on a thread is slow and causes the screen to go blank, and then it catches up. Nowhere near as smooth as when it correctly works. The worst part is trying to reply to a post. You need to tap and tap before the keyboard pops up. Then the keypad is FUBAR. It constantly switches between upper and lower case. There is a few second delay before a character appears in the test box, and weird keys appear when a key is pressed.
Interestingly, this only happens on this site. So far other sites are okay.
IOS 6 is a piece of junk.Lumin X1 file player, Westminster Labs interconnect cable
Have you set the style for this site as widescreen. I used to get weird behavior with iDevices before doing that.
That seems to have made a difference. Why that would affect the keyboard working is unclear. I just went and posted on stereophile forum, and it was okay. Thanks for the tip. Hope it keeps working for more than a day. :biggrin:Lumin X1 file player, Westminster Labs interconnect cable
I'm downloading it now for my 4s, keeping my fingers crossed it works ok.
We've been running a handful of iPad II 16gig at school on IOS6 and after a full day of use not one problem.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
I've had it on my iPad from the day it was launched and its been perfectly fine. I put it on my iPhone yesterday and also zero issues.
However, my iPhone still refuses to find my home wifi... It will find any other wifi network, JUST not my home wifi. My iPad finds it fine, same with my wife's iPhone. Just to be clear, my iPhone did not find it before the update as well. -
what are the benefits of going to IOS 6 on IPAD2?
Bug fixes, better performance, new default apps, Siri, and just stay current. It has been working okay, after reseting, and going to wide-screen mode. But it was really FUBAR for a while last Friday.Lumin X1 file player, Westminster Labs interconnect cable
I was on iOS 4.2. Some games needed a higher version so I upgraded. I haven't noticed better performance on my iPod Touch 4. It seems *slightly* slower actually. I tried to add YouTube from the AppStore today and the AppStore app crashed like 5 times. I rebooted the device and finally got it to work. Not sure why exactly. My device was jailbroken so I lost some functionality (no for pirating). Can no longer link my Bluetooth GPS device.
why not try Chrome on your ipad? I downloaded it to mine and it handles things much, much better than Safari.
Haven't upgraded to 6 yet.. will wait for a bit.. let others figure out the bugs. -
What it's like to own an Apple product: http://theoatmeal.com/comics/apple :biggrin:Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
I hate how they removed YouTube from iOS 6. I downloaded Jasmine for iPad but it's not nearly as good as the old integrated app.
Couldn't help yourself could ya...What it's like to own an Apple product: http://theoatmeal.com/comics/apple :biggrin: -
AsSiMiLaTeD wrote: »Couldn't help yourself could ya...
A co-worker sent me the link. It's quite hilarious to me, so yep, I got to post it here :biggrin: Frankly I couldn't care less about any iPhone/iPad/iPod or Android device since my phone is a Blackberry and my current laptop is a Dell ultrabook, both provided by my company, and they serve me adequately. I'm glad I don't have to spend my money on those devices, so more dough for me to buy audio/video stuff
Living room:
Bedroom:
Other rooms:
Updated the 2nd/3rd gens yesterday with zero hiccups.Shoot the jumper.....................BALLIN.............!!!!!
Works like a dream on my iphone 5, although this is the first time I've used ios.
I'd try hard resetting...if that's even possible.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103
