IOS 6 Sucks Bigtime on the IPad
BlueFox
BlueFox Posts: 15,250
edited October 2012 in The Clubhouse
This upgrade is terrible. It is impossible to type. The response is terrible. Scrolling the screen goes white instead of smoothly going by. I am going to have to use my laptop for posting, and the IPad for reading. apple stock should tank due to this POs. Even the magnifying glass is missing for trying to edit. Pos pos pos pos
Post edited by BlueFox on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited September 2012
    I thought they weren't going to release it for that model.
    I assume you have the original ipad? That thing is a dinosaur...
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I'm in the middle of the update on my iPhone 4. I hope it doesn't screw it up too bad. I thought I would wait out the masses for the upgrade to the 5. $200
    for a 1/2 inch is pretty steep........:cheesygrin:
  • BlueFox
    I have the latest model with max memory. It is a few months old. I am on my laptop now since the Ipad sucks so bad with IOS6. Time to get onto Apple and other blogs and let them know just how bad this thing is.
    As you type other bizzare key options appear. Unbelievable. No testing at all done for this release. Jobs is turning in his grave.
  • nspindel
    nspindel Posts: 5,343
    Something is wrong. I upgraded to iOS 6 on my iPad (latest model) and it's perfect. Not experiencing anything that you're describing. Have it on my iPhone 4 and its just fine there too. Do a backup, then do a full factory refresh. Then restore from the backup.
  • B Run
    B Run Posts: 1,888
    Same here, I love the update for my 4s and iPad. Sorry you're having issues but i'd try a reset first too, it's really better.
  • polk500
    polk500 Posts: 1,171
    I have to agree ;I have the three and mind works perfectly as well. Backup and reset should fix it for ya.
    Cheers Roger
  • BlueFox
    Okay. I did the reset and that fixed the bizarre keyboard operation. Now I cannot login to Yahoo, but on the laptop it is fine. Apple really fracked up with this release. There are more issues here than just Maps.
  • BlueFox
    Man-o-man. What a nightmare. I went into Safari and deleted all cookies, history, and web data. Now I can log into Yahoo. Hopefully, I am back to where I was before upgrading. The funny part is my IPad is about as close to stock as you can get. I have added 2-3 apps, and bought one book. Yet, the upgrade went all fubar. I guess that is why I have always been a great QA engineer. All this wierd stuff happens to me. :rolleyes:
  • AsSiMiLaTeD
    It sounds like a fluke to me, glad it's coming together for you thought.
  • Saftgeek
    Saftgeek Posts: 114
    Just updated and it is working flawlessly...
    -Saftgeek
  • Dennis Gardner
    Mine is good with the iPhone 4. The only issue is iTunes won't seem to let me move app icons within its program. No biggie though. I am thankful that the OS upgrades don't kill the earlier hardware versions as often and a Windows upgrade does on my PC. With Windows, each OS seems to take a new PC.
  • maximillian
    maximillian Posts: 2,149
    My iPod Touch 4G seems to work OK. It does seem a little slower but nothing bad. The worst thing however is iTunes. Did the backup and restore but for some reason it didn't restore my music - all 3700+ songs. After messing with it a while it finally "found" the songs from my NAS. Then 3 hours later to resync all the songs. How stupid that it would have to delete all of them and then put them back on.
    I hate iTunes.
  • mantis
    mantis Posts: 17,561
    I upgraded to IOS6 for the IPhone 4s and I have no issues so far. If anything my phone seems faster,But I'll keep and eye out. Sorry your having trouble with your iPad.
    Dan
  • Strong Bad
    Strong Bad Posts: 4,278
    iPhone 4 and iPad 3 both working flawless with it.
    No excuses!
  • BlueFox
    I reset the iPad yesterday and it worked fine for a while. Now the same problem is back. Trying to scroll up or down on a thread is slow and causes the screen to go blank, and then it catches up. Nowhere near as smooth as when it correctly works. The worst part is trying to reply to a post. You need to tap and tap before the keyboard pops up. Then the keypad is FUBAR. It constantly switches between upper and lower case. There is a few second delay before a character appears in the test box, and weird keys appear when a key is pressed.
    Interestingly, this only happens on this site. So far other sites are okay.
    IOS 6 is a piece of junk.
  • nwohlford
    nwohlford Posts: 700
    Have you set the style for this site as widescreen. I used to get weird behavior with iDevices before doing that.
  • BlueFox
    nwohlford wrote: »
    That seems to have made a difference. Why that would affect the keyboard working is unclear. I just went and posted on stereophile forum, and it was okay. Thanks for the tip. Hope it keeps working for more than a day. :biggrin:
  • astar13656
    astar13656 Posts: 164
    I'm downloading it now for my 4s, keeping my fingers crossed it works ok.
  • markmarc
    markmarc Posts: 2,309
    We've been running a handful of iPad II 16gig at school on IOS6 and after a full day of use not one problem.
    Former Staff Member TONEAudio
    2 Ch. System
  • Upstatemax
    Upstatemax Posts: 2,800
    I've had it on my iPad from the day it was launched and its been perfectly fine. I put it on my iPhone yesterday and also zero issues.
    However, my iPhone still refuses to find my home wifi... It will find any other wifi network, JUST not my home wifi. My iPad finds it fine, same with my wife's iPhone. Just to be clear, my iPhone did not find it before the update as well.
  • bruss
    bruss Posts: 1,039
    what are the benefits of going to IOS 6 on IPAD2?
  • BlueFox
    Bug fixes, better performance, new default apps, Siri, and just stay current. It has been working okay, after reseting, and going to wide-screen mode. But it was really FUBAR for a while last Friday.
  • maximillian
    I was on iOS 4.2. Some games needed a higher version so I upgraded. I haven't noticed better performance on my iPod Touch 4. It seems *slightly* slower actually. I tried to add YouTube from the AppStore today and the AppStore app crashed like 5 times. I rebooted the device and finally got it to work. Not sure why exactly. My device was jailbroken so I lost some functionality (no for pirating). Can no longer link my Bluetooth GPS device.
  • pdxfj
    pdxfj Posts: 376
    why not try Chrome on your ipad? I downloaded it to mine and it handles things much, much better than Safari.
    Haven't upgraded to 6 yet.. will wait for a bit.. let others figure out the bugs.
  • DMara
    DMara Posts: 1,434
    What it's like to own an Apple product: http://theoatmeal.com/comics/apple :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • adb3da
    adb3da Posts: 507
    I hate how they removed YouTube from iOS 6. I downloaded Jasmine for iPad but it's not nearly as good as the old integrated app.
  • AsSiMiLaTeD
    DMara wrote: »
    Couldn't help yourself could ya...
  • DMara
    DMara Posts: 1,434
    A co-worker sent me the link. It's quite hilarious to me, so yep, I got to post it here :biggrin: Frankly I couldn't care less about any iPhone/iPad/iPod or Android device since my phone is a Blackberry and my current laptop is a Dell ultrabook, both provided by my company, and they serve me adequately. I'm glad I don't have to spend my money on those devices, so more dough for me to buy audio/video stuff :lol:
    Living room:
    Bedroom:
    Other rooms:
  • Sherardp
    Sherardp Posts: 8,038
    Updated the 2nd/3rd gens yesterday with zero hiccups.
  • badchad
    badchad Posts: 348
    Works like a dream on my iphone 5, although this is the first time I've used ios.
    I'd try hard resetting...if that's even possible.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
