Best AVR for RTiA7 .. Suggestions needed !!
infexXxious
infexXxious Posts: 6
edited September 2012 in Electronics
Need a good AVR which can power up my RTiA7 the best ....
Budget : 900$ Max nothing more than that
Brands : Onkyo , Denon , Marantz , Harmon kardon
Room Size : No idea its like you can say big
Use :Will be using 100% only for movies
Looking for a 7.1 AVR ... this is my first ever HT Setup and been like a week on the internet searching for the best AVR But found ntn :( Finally got thru this forum and i hope i will find the best AVR here ....
Bein confused a lot cause people say that the RTiA7 really needs some good power from the AVR ...
And i don't want to use a Pre out amp ...
My other speaker and subs are :
Front Floor Standing Speaker RTiA7
Center Channel Speaker CSiA6
Surround speakers F/XiA6
DSW PRO 660WI
So please suggest me the best AVR for my RTiA7 on that budget ...Few said the denon 2113 will be a good buy
Post edited by infexXxious on
  • chumlie
    chumlie Posts: 8,658
    No love for Pioneer ? SC series.
  • infexXxious
    chumlie wrote: »
    No my friend ...i was looking only for Onkyo , Denon , Marantz & Harmon kardon !!
  • pdxfj
    pdxfj Posts: 376
    If you don't want to use a two or three channel amp to power your fronts (best option), then you'll want something along the lines of the Onkyo 3008/3009 or similar. An AVR that size has separate transformers for the internal amps. Be prepared to pay a bit extra for all of that.
    Another option is to get a smaller AVR and use the leftover cash for an amp. You can pick up an Onkyo TX-NR717 from http://www.accessories4less.com for $500 and spend the rest on an amp.
    I'm only using Onkyo as an example. The other brands you suggest would work fine as well. You'll discover most people here will strongly suggest using an external amp when possible.
  • tommyt21
    tommyt21 Posts: 685
    chumlie wrote: »
    I agree thats what I run mine with those ice amps push alot of juice
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
    F1nut Posts: 52,298
    A used Pioneer SC-xx
  • infexXxious
    How about Denon AVR-2313CI ? Marantz SR5007 ?
  • B Run
    B Run Posts: 1,888
    Sorry man I know they're not on the list but I'd go Pioneer SC or Yamaha RXA just personal preferences after owning LOTS of avr's. The Marantz from accessories for less is a nice one, I had an Onkyo 3008 and would definitely recommend the Pioneer over it.
  • gce
    gce Posts: 2,158
    If you look at my sig you'll see that I have the same speakers you have. I'm running a 5.1 setup and my Yamaha does just fine.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • mantis
    mantis Posts: 17,637
    The Pioneer Elite SC models are the best in the bussiness for power and pure sound quality , nothing sounds better or gives you more power In IMO.
    Dan
  • jkg123
    jkg123 Posts: 114
    I would make sure you get something with Pre-outs incase you want to add a separate amp later
  • jkg123
    jkg123 Posts: 114
    Are you considering used at all?
  • jkg123
    jkg123 Posts: 114
    Because if you are, a Denon AVR-3311 can be had for a little less then $900
  • EDUBAG
    EDUBAG Posts: 403
    i had the RTIA7 with the csi4 and rti4 as surrounds and my pioneer elite vsx23, did a good job with them. however the sc line is a much better line. i would say that you will not be sorry with an sc37. if going with marantz i would say sr6006 or sr6007. i am not familiar with onkyo or harman kardon as far as receivers go.
    good luck
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • roost28
    roost28 Posts: 39
    Any of theses brands are good, but i would skip the onkyo unless you have it in a well ventilated spot, they run pretty hot. just get something that has at least 120w per channel and that has pre outs so you can add an amp later if you want.Me personally i am a yamaha guy the new aventage line are fantastic! espeacially for movies:cheesygrin:
    samsung un40eh5300
    yamaha rx-a3010
    oppo bdp-105
    rtiA7, front
    csiA4, center
    rtiA1, front presence
    rtiA1, surrounds
    PSW 505, sub
  • badchad
    badchad Posts: 348
    I'm in the same boat as the OP.
    roost28 wrote: »
    Do you think I'd even notice small differences in power at the lower-end Yamahas? I'm deciding between the RX-A810 and X-A1010. Seems like the only major difference is about 10W of power and a few hundred bucks. Seems like I'd be better off going with the A810 and saving the case toward an external amp.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • pdxfj
    pdxfj Posts: 376
    Funny thing about the heat issues with the Onkyo AVR's is my 808 use to run hot enough to burn you. Since upgrading electrical service to my house and running a dedicated 20A circuit for the TV and such, the 808 runs much, much cooler. It still gets rather warm but not the blast furnace it was before.
    Plus the heat and HDMI issues are not so common in the 3008 and higher models since they used a different chip-set.
    In the end grab what you want but, to future proof yourself get something with pre-outs so you can add an amp later if you so choose.
  • roost28
    roost28 Posts: 39
    badchad wrote: »
    between the 810 and 1010 probably not,but i believe the 1010 does have a slightly better amp sec. are you going to add an amp right away? why not step up to the 2010 and then you get a lot more like hqv.
    samsung un40eh5300
    yamaha rx-a3010
    oppo bdp-105
    rtiA7, front
    csiA4, center
    rtiA1, surrounds
    PSW 505, sub
  • spock 2054
    spock 2054 Posts: 163
    pdxfj wrote: »
    I had an Onkyo 806, then upgraded to a 709 because of the 3D pass through capability. The 709 ran as hot as the 806. Returned the 709 after I found txnr809 for a crazy price on Warehouse Deals. That unit runs as cool as a cucumber, even under stress.
    +1 on the pre-out option and external amp. The A7's will sound better with more power. Your best bet would be to prowl CL or fleabay for clean used gear - even though your don't want to use a pre out, it's a good suggestion to look for an AVR with that option.
    http://www.accessories4less.com/index.php
    Factory refurbs could be an option. You get a warranty and on some items on the a4L site, free shipping.
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • badchad
    badchad Posts: 348
    roost28 wrote: »
    I probably could, but the upper-tier receivers seem to offer a ton of features that I don't need. I'm planning a very basic, 7.1 setup for home theater. I don't need all the networking bells and whistles, "smart" features, etc.
    Really, the only thing I wanted was more power, so that I may not require another amp.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • jbooker82
    jbooker82 Posts: 1,627
    I guess you shouldn't ask this question on a pioneer forum. hahahaha.
    Take a look at www.accessories4less.com they sell refurbished Denon, Onkyo, and Marantz recievers. I like my Onkyo and if I was looking to get a new one I would take a look at the TX-NR818 it is the current model so your getting the latest in technology. They TX-NR809 is last years, and the TX-NR808 is two years old. I have the 808 and am happy with it. You need to get at least an Onkyo TX-NR7xx to get analog pre outs. That way if you want to try an external amplifier out you at least have the option, and ability to.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • roost28
    roost28 Posts: 39
    badchad wrote: »
    what is your budget?
    samsung un40eh5300
    yamaha rx-a3010
    oppo bdp-105
    rtiA7, front
    csiA4, center
    rtiA1, surrounds
    PSW 505, sub
    badchad wrote: »
    So don't use them. Buying a receiver isn't like buying a car where you get to choose your options. More power is usually associated with the upper end of a receiver line, and that comes with lots of bells and whistles that some may not want/need/ or use.
    The only other option I can see is looking at a receiver thats a tad bit older, that has the current surround formats but before all the gimmicky stuff was added on.
  • kemetblk
    kemetblk Posts: 1
    The Marantz SR6006 can be found on clearance for less than $700 (my local BB has 3 left). I'm using one to power my RTiA9's and it does great. Doesn't mean I'm not keeping an eye out for an amp later on though. :wink:
    AVR: Marantz SR6006
    Fronts: RTi A9
    Center: CSi A6
    Surrounds: Speakercraft AIMWIDE 3
    Sub: SVS PB12-NSD
    Samsung PN58C8000, SCI-ATL 8240HDC, Samsung BD-P2550, Toshiba HD-A30, WDTV Live SMP, PS3 320GB, Xbox 360 120GB, Belkin PureAV PF60 powercenter, Harmony One
  • gp4jesus
    gp4jesus Posts: 2,019
    To my fraternal A7 owner
    badchad wrote: »
    ...Seems like the only major difference is about 10W of power and a few hundred bucks.
    At the risk of stirring the pot, be careful just glancing at the numbers.
    Belles rated @ 100 WPC/8ohms
    Hafler XL-280 145 WPC/8ohms.
    Here's the catch: Belles is rated 30 ampres peak/ch vs 10 (I think) for the Haf. Belles has a much larger transformer and over double the PS filtering. The Belles has a much more authoritative bottom end in spite of the 45 WPC difference.
    At the risk of stirring a different pot, you won't see this on the Polk site. Below the sub LP filter frequency (125hz) the mids and subs are in parallel; your AVR/amp see a 4 ohm load something most AVRs have trouble with.
    Go figure.
    Tony
    *all connected w/Premiere ICs
