Is this tweeter damaged? (Craigslist)
goofyGAguy
Hi. Does the tweeter dome of the speaker on the right appear to have been pushed in far enough to cause any damage? Thanks.
http://images.craigslist.org/5Ga5Fa5H43G83Ke3o5c8uba8a1eef78d9190c.jpg
My humble setup...
...is no more.
...is no more.
Looks pretty bad to me - I would expect it still makes sound but that the dispersion of the HF would be affected. I would call polk and get a price on a replacement and offer that much less perhaps...2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
I agree. However get the modle # of the tweet i may have a replacement for you. If they are rt25's or use the same tweet i have a pair of those.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Hard to tell. Maybe, maybe not. You need to hear it and also POP it out. This can be done in most cases. There are a number of techniques people have used on this site, to right pushed in tweets from light tape to suction. Do a search. Find what is best for you and pull it out. Then give it a very very very good listen!
usually not but get a good deal on the polks and buy a tweeter off ebay or if polk has them get a nice new one . I bet it may sound differant if its cloth try pulling the dome carefully with a safety pin , you could probebly find a tweeter on this forumn also .goofyGAguy wrote: »Hi. Does the tweeter dome of the speaker on the right appear to have been pushed in far enough to cause any damage? Thanks.
http://images.craigslist.org/5Ga5Fa5H43G83Ke3o5c8uba8a1eef78d9190c.jpg -
i like using tape2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
soundfreak1 wrote: »I agree. However get the modle # of the tweet i may have a replacement for you. If they are rt25's or use the same tweet i have a pair of those.
Thanks. The speakers in question are the RT15. I pulled a tweeter from some that I own and the tweeter is marked as follows:
S20SND2
90116My humble setup...
...is no more.
Not rhe same as mine, however u may be able to pop out the center as mentioned by op
tjere are several ways to do it. But put your ears on thwm and see ( or hear) how they sound .chances are ypu same it or at worst find a replacement from polk.or an original here. How much ia tje guy selling thwm for?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Piece of tape, funtac or the like will pull that right out.
goofyGAguy wrote: »He's asking $30 for the pair.
I'd get them!--Gary--
