Is this tweeter damaged? (Craigslist)
goofyGAguy
goofyGAguy Posts: 545
edited September 2012 in Speakers
Hi. Does the tweeter dome of the speaker on the right appear to have been pushed in far enough to cause any damage? Thanks.
http://images.craigslist.org/5Ga5Fa5H43G83Ke3o5c8uba8a1eef78d9190c.jpg
My humble setup...
...is no more. :cry:
  • ambiophonics
    ambiophonics Posts: 729
    Looks pretty bad to me - I would expect it still makes sound but that the dispersion of the HF would be affected. I would call polk and get a price on a replacement and offer that much less perhaps...
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • soundfreak1
    soundfreak1 Posts: 3,414
    I agree. However get the modle # of the tweet i may have a replacement for you. If they are rt25's or use the same tweet i have a pair of those.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Hard to tell. Maybe, maybe not. You need to hear it and also POP it out. This can be done in most cases. There are a number of techniques people have used on this site, to right pushed in tweets from light tape to suction. Do a search. Find what is best for you and pull it out. Then give it a very very very good listen!
    cnh
  • 20hz
    20hz Posts: 636
    usually not but get a good deal on the polks and buy a tweeter off ebay or if polk has them get a nice new one . I bet it may sound differant if its cloth try pulling the dome carefully with a safety pin , you could probebly find a tweeter on this forumn also .
    goofyGAguy wrote: »
  • falconcry72
    falconcry72 Posts: 3,580
    i like using tape
  • goofyGAguy
    Thanks. The speakers in question are the RT15. I pulled a tweeter from some that I own and the tweeter is marked as follows:
    S20SND2
    90116
    My humble setup...
  • soundfreak1
    Not rhe same as mine, however u may be able to pop out the center as mentioned by op
    tjere are several ways to do it. But put your ears on thwm and see ( or hear) how they sound .chances are ypu same it or at worst find a replacement from polk.or an original here. How much ia tje guy selling thwm for?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • goofyGAguy
    He's asking $30 for the pair.
    My humble setup...
  • Joe08867
    Joe08867 Posts: 3,919
    Piece of tape, funtac or the like will pull that right out.
  • halo71
    halo71 Posts: 4,645
    goofyGAguy wrote: »
    I'd get them!
    --Gary--
  • transmaster
    transmaster Posts: 424
    No brainer $30 bucks go for it.
    Radio Station W7ITC
