Now the wait
TNJoe
TNJoe Posts: 9
edited August 2012 in Electronics
Well, I dove into the plasma realm this evening and ordered a 50" Panasonic GT50. After getting ahold of the remote at the store and playing with some setttings I was sold. It seemed like everytime I went to the store it was set to Standard mode, not real impressive. THX Cinema is where it's at!!! I must've even turned my wife away from LED, especially since she gave the go-ahead. Come on Aug 18th!!!!
I'd be interested in anyones thoughts or setup hints that work for you, if you have any.
Post edited by TNJoe on
    gudnoyez Posts: 8,204
    edited August 2012
    It will be worth the wait. Panasonic makes a solid product. Enjoy your new Panny.
  • GlennDog
    GlennDog Posts: 3,158
    edited August 2012
    I can't speak to the plasma but i've got a couple point-and-shoots, and they work very well, no probs
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • breal74
    breal74 Posts: 324
    edited August 2012
    I bought the GT65 a little over a month ago and the THX modes are where it is at! The picture quality is phenominal. If you are going to wall mount and run cables behind the wall I would go to Monoprice to order what you need. You will save a ton of dough and the quality is great. Other than that, congrats and sit back and enjoy!
    EndersShadow Posts: 17,749
    edited August 2012
    I moved from a 56" Panasonic DLP to a 60" ST30 in May of this year and haven't looked back. No real setup tips because its pretty easy lol. I would suggest checking for a firmware update via ethernet and then just leave it connected for that too. I messed with a couple settings and turn off some of the enhancements but I forget what they are.
    Just go through the menu and disable anything that adds to the source image and you should be fine.
    You will enjoy it for sure. I know I LOVE mine :biggrin:
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2012
    breal74 wrote: »
    That is the mode my LG Plasma stays in.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • gce
    gce Posts: 2,158
    edited August 2012
    TNJoe wrote: »
    Check out the AVS Forum and look for "Dnice" he has breakin and custom setups for these. I have a 55VT30 and went thru the steps he laid out for calibration and the set looks fantastic! He is a calibrator and helps out people with Plasmas over there.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • breal74
    breal74 Posts: 324
    edited August 2012
    breal74 wrote: »
    . That should have said P65GT50. I also suggest disabling the internet pop up adds that appear when you first turn it on. Enjoy!
  • mesquitehead
    mesquitehead Posts: 312
    edited August 2012
    Picked up th ST 65" Panny plasma this spring and could not be happier. Look up the burn in procedure and proper settings (By Dnice) and I think you will be very pleased. We now have a 50", 42" and a 65" trio of panny plasmas in the house and I am 100% happy with all of them! Here you go Picked up th ST 65" Panny plasma this spring and could not be happier. Look up the burn in procedure and propper settings (By Dnice) and I think you will be very pleased. We now have a 50", 42" and a 65" trio of panny plasmas in the house and I am 100% happy with all of them! Here you go http://www.avsforum.com/t/1403635/official-panasonic-gt50-series-discussion-thread-no-street-price-talk/360#post_21920785
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • TNJoe
    TNJoe Posts: 9
    edited August 2012
    Aarrgghh!!!! I had my tv delivered yesterday and it came in cracked. :sad: Now I wait another week.
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited August 2012
    That sucks man, sorry.... do still hope you enjoy it when you get a good one.
