Now the wait
TNJoe
Well, I dove into the plasma realm this evening and ordered a 50" Panasonic GT50. After getting ahold of the remote at the store and playing with some setttings I was sold. It seemed like everytime I went to the store it was set to Standard mode, not real impressive. THX Cinema is where it's at!!! I must've even turned my wife away from LED, especially since she gave the go-ahead. Come on Aug 18th!!!!
I'd be interested in anyones thoughts or setup hints that work for you, if you have any.
Post edited by TNJoe on
It will be worth the wait. Panasonic makes a solid product. Enjoy your new Panny.Home Theater
I can't speak to the plasma but i've got a couple point-and-shoots, and they work very well, no probs
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I bought the GT65 a little over a month ago and the THX modes are where it is at! The picture quality is phenominal. If you are going to wall mount and run cables behind the wall I would go to Monoprice to order what you need. You will save a ton of dough and the quality is great. Other than that, congrats and sit back and enjoy!
I moved from a 56" Panasonic DLP to a 60" ST30 in May of this year and haven't looked back. No real setup tips because its pretty easy lol. I would suggest checking for a firmware update via ethernet and then just leave it connected for that too. I messed with a couple settings and turn off some of the enhancements but I forget what they are.
Just go through the menu and disable anything that adds to the source image and you should be fine.
You will enjoy it for sure. I know I LOVE mine :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Check out the AVS Forum and look for "Dnice" he has breakin and custom setups for these. I have a 55VT30 and went thru the steps he laid out for calibration and the set looks fantastic! He is a calibrator and helps out people with Plasmas over there.Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I bought the GT65 a little over a month ago. That should have said P65GT50. I also suggest disabling the internet pop up adds that appear when you first turn it on. Enjoy!
Picked up th ST 65" Panny plasma this spring and could not be happier. Look up the burn in procedure and proper settings (By Dnice) and I think you will be very pleased. We now have a 50", 42" and a 65" trio of panny plasmas in the house and I am 100% happy with all of them! Here you go Picked up th ST 65" Panny plasma this spring and could not be happier. Look up the burn in procedure and propper settings (By Dnice) and I think you will be very pleased. We now have a 50", 42" and a 65" trio of panny plasmas in the house and I am 100% happy with all of them! Here you go http://www.avsforum.com/t/1403635/official-panasonic-gt50-series-discussion-thread-no-street-price-talk/360#post_21920785"Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce -
Aarrgghh!!!! I had my tv delivered yesterday and it came in cracked. :sad: Now I wait another week.
That sucks man, sorry.... do still hope you enjoy it when you get a good one.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
