LSiW - Powered Home Audio Subwoofer
The cherry on j and r's looks more like rosewood or something. Priced at $999.
Why didn't they include the specs? How low can she go?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
http://www.polkaudio.com/home/library/downloads/catalog2004/2004Catalog_LSi_Insert.pdf
Specs are near the bottom. I was disappointed to see the 400 watt power rating is at 2 ohms. Overall range is listed down to 20hz with a -3 db rating at 30hz. -
The PSW650 listed -28 hz at -3db. It's 165 watt power rating doesn't list ohms or THD level.
Could be both drivers are 4 ohm and wired in parallel. Each driver is seeing 200 watts continuous - not bad for a 10" unit.
F3 at 30 Hz makes sense for that size vented enclosure using 10" drivers. If it were a few inches bigger in dimension all around, Polk might have been able to squeeze another 5 Hz out of it."What we do in life echoes in eternity"
SVS -
