B&K Components AV5125 - 5 Channel Amplifier
MKZ
MKZ Posts: 1,068
edited January 2013 in For Sale (FS) Classifieds
B&K Components AV-5125 - 5 Channel Amplifier - 9/10 - $550 + Shipping From NY
SPECIFICATIONS:
Power rating: 8 ohms 125 watts @ 1 kHz/ 4 ohms 185 watts @ 1 kHz
Frequency response 5 Hz - 45 kHz
Input sensitivity 1.0 Volts
THD (S+N) 0.09 % @ 1 kHz
Input impedance 33.2 k ohms
Damping factor 150
Current (peak to peak) 30 Amps
Slew rate 14 V / )sec
Dynamic headroom 1.4 dB
S/N (A-weighted) 95 dB
Voltage gain 28
Line voltage 120/220/240 VAC switchable
Dimensions (O.A.) 17"(w) X 16"(d) X 5.75"(h)
Weight 43 lb
Power consumption 1220 watts max
12.2 Amps max current draw
125 watts @ no input
Replacement fuses Line -12 Amp/250 Volt Slow Blow
Rails - 4 Amp/250 Volt Slow Blow
AV5125 User Manual
Includes: Original box, original packaging and original power cord.
Post edited by MKZ on
  • shawn474
    shawn474 Posts: 3,052
    edited July 2012
    Buy from MKZ with confidence. I purchased his B&K AV5000 a few years ago and it was packaged great and was as described. It still lives on my shelf to this day and is on amp duty using my pio elite vsx-21txh as a pre. Top notch seller here guys.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • MKZ
    MKZ Posts: 1,068
    edited July 2012
    Thanks Shawn. You have a very good memory. :)
  • MKZ
    MKZ Posts: 1,068
    edited August 2012
  • nhhiep
    nhhiep Posts: 877
    edited August 2012
    does anyone know the actual power of this thing? I find it strange that BK rate many of their stuffs at 1khz.
  • jimbo1421
    jimbo1421 Posts: 772
    edited August 2012
    Is this AV5125 a common ground amp?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • mantis
    mantis Posts: 17,557
    edited August 2012
    nhhiep wrote: »
    It's a full 125 watts into a 8 ohm load from 20hz to 20khz no problem. B&K 's amps are very strong and sound fantastic. It will drive 4 ohm load speakers at 185 watts all channel driven 20 to 20.
    If you need a power amp and you have a medium to large room , this amp will not disappoint. I've owned and Installed them for over a decade and never once came up short in the power department.
    Not to mention they are sweet sounding amps , Arguably the best in class.
    Dan
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited August 2012
    mantis wrote: »
    I like this one here!!
  • MKZ
    MKZ Posts: 1,068
    edited August 2012
    Thanks for the answer Dan.
  • tophatjohnny
    edited August 2012
    Wonder if it would sound any better that my new HK PA 5800?? Anyone here heard both?????
  • MKZ
    MKZ Posts: 1,068
    edited October 2012
  • MKZ
    MKZ Posts: 1,068
    edited November 2012
    Still available.
  • MKZ
    MKZ Posts: 1,068
    edited January 2013
