B&K Components AV5125 - 5 Channel Amplifier
MKZ
B&K Components AV-5125 - 5 Channel Amplifier - 9/10 - $550 + Shipping From NY
SPECIFICATIONS:
Power rating: 8 ohms 125 watts @ 1 kHz/ 4 ohms 185 watts @ 1 kHz
Frequency response 5 Hz - 45 kHz
Input sensitivity 1.0 Volts
THD (S+N) 0.09 % @ 1 kHz
Input impedance 33.2 k ohms
Damping factor 150
Current (peak to peak) 30 Amps
Slew rate 14 V / )sec
Dynamic headroom 1.4 dB
S/N (A-weighted) 95 dB
Voltage gain 28
Line voltage 120/220/240 VAC switchable
Dimensions (O.A.) 17"(w) X 16"(d) X 5.75"(h)
Weight 43 lb
Power consumption 1220 watts max
12.2 Amps max current draw
125 watts @ no input
Replacement fuses Line -12 Amp/250 Volt Slow Blow
Rails - 4 Amp/250 Volt Slow Blow
AV5125 User Manual
Includes: Original box, original packaging and original power cord.
SPECIFICATIONS:
Damping factor 150
Voltage gain 28
Weight 43 lb
AV5125 User Manual
Post edited by MKZ on
Buy from MKZ with confidence. I purchased his B&K AV5000 a few years ago and it was packaged great and was as described. It still lives on my shelf to this day and is on amp duty using my pio elite vsx-21txh as a pre. Top notch seller here guys.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Thanks Shawn. You have a very good memory.
bump
does anyone know the actual power of this thing? I find it strange that BK rate many of their stuffs at 1khz.
Is this AV5125 a common ground amp?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
It's a full 125 watts into a 8 ohm load from 20hz to 20khz no problem. B&K 's amps are very strong and sound fantastic. It will drive 4 ohm load speakers at 185 watts all channel driven 20 to 20.does anyone know the actual power of this thing? I find it strange that BK rate many of their stuffs at 1khz.
If you need a power amp and you have a medium to large room , this amp will not disappoint. I've owned and Installed them for over a decade and never once came up short in the power department.
Not to mention they are sweet sounding amps , Arguably the best in class.Dan
I like this one here!!It's a full 125 watts into a 8 ohm load from 20hz to 20khz no problem. B&K 's amps are very strong and sound fantastic. It will drive 4 ohm load speakers at 185 watts all channel driven 20 to 20.
Not to mention they are sweet sounding amps , Arguably the best in class."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Thanks for the answer Dan.
Wonder if it would sound any better that my new HK PA 5800?? Anyone here heard both?????"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
bump
Still available.
ttt.
