home theater speakers for my bed room.
Ok i ordered this home theater system,
Yamaha YHT-695BL $490
it comes on monday, however my friend is telling me to return it and buy a receiver separate and order polk speakers instead.
he also says a 2.1 or 3.1 would suit me better for the way my bedroom is vs's a 5.1.
sorry for dirty room =\.
he suggests just getting this setup,
Polk Audio Monitor30 or Polk Audio Monitor50 (2) or Polk Audio Monitor60 (2)
Polk Audio CS1 Series II
Polk Audio PSW Series PSW10
however i was thinking of just purchasing this,
Polk Audio Monitor70 (2)
Polk Audio CS2 Series II
and just going 3.0 instead of 3.1? heard the 70's had good bass without a sub but im not sure if the recievers im looking at can even power them properly, ONKYO TX-NR616 & YAMAHA RX-V473BL
system will only be used for movies, tv shows no music, just seeing what you think would be best considering my room layout with 3.0, 3.1 and 5.1 choices. thanks
Post edited by skuzzzzy on
For your room size, I would go for a good bookshelfs and a subwoofer. Maybe instead of monitor series, go with RTiA1, they are currently on sale at newegg with free headphones - http://www.newegg.com/Product/Product.aspx?Item=N82E16882290152
For the subwoofer, go with the PSW505, if you want to stick with polkaudio or I recommend getting BIC F12 for little less.Music Room:
Paradigm Signature S8
Paradigm Signature C5
Paradigm Signature S2
Receiver - Onkyo tx-nr809
Amplifier - Adcom 5802
Office system:
Fronts - Polk RTI A7 (Trey Mod)
Center - Polk CSI A6 (Trey Mod)
Rears - Polk FXI A6
Sub - BIC F12
Receiver - SONY STR-DG1000
Amp - Carver TFM-35 -
You can pull anything off if you want to. I had a 7.1 and 7.2 set up in a bedroom. Of course it wasn't ideal, but it can be done and still sound decent.
That said, the 70's are a good choice, but to get the bass you're talking about, they need power. I demoed mine for sale using an XPA-2, 300w power amp. The buyer said he didn't feel bad not having a sub right away because of the bass they were putting out. I told him be aware, if they didn't sound the same in his set up, that the power had a lot to do with it.
It all depends on what you're after, some are happy with HTIB's, others only through separates.
I tried both, the HTIB in my opinion is worthless for the true "Home Theater" feel.
With separates, you're not limited to what you can implement, providing your AVR is equipped with pre-outs. That's important when you want to start adding extra power.
Your choice for a 3.0 is a good place to start, I'd just look at something bigger for the AVR for down the road, like the 709.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I would recommend these: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290252&Tpk=polk%20rti6Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
I think max i would spend on a receiver is $400, only reason i was looking at $500 yamaha one is because it comes with $100 giftcard i could use towards my center.
I dont ever plan on adding a amp so if thats going to be a problem then let me know, im not sure what im going for, ive never had a home theater and dont want to start off with a crappy one then need to upgrade later. -
your saying go 2.1 not 3.1? -
I'd at least go with 3.1. Since you're doing mostly movies, most of your dialogue comes through the center channel.
Keep it small, get your 616 and if you can get the RTiA1's (or 3's) and a CSiA4, you'll have a killer little bedroom set up.
BTW, welcome to the forum, we'll get your money spent faster than a speeding bullet :biggrin:Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
HTguru1982 wrote: »I would recommend these: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290252&Tpk=polk%20rti6
There you go, equivalent to the RTiA3, those and the CSiA4 or probably the CSi3 for less $$Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Here's the CSiA4 http://www.ebay.com/itm/CSi-A4-CSiA4-BLACK-Center-Channel-Speaker-Polk-Audio-/360458637534?pt=Speakers_Subwoofers&hash=item53ed0250de It's a refurb, but still comes with a warranty, the price is good, it's a match for the RTi6 and should sound nothing but great in your bedroom.
Let us know which way you end up going. Good luck here brother.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780082
this must be the best speaker deal in all of audio world right now (
). I drove to frikkin Ohio to buy mine, because i was told from Klipsch alone that those are discontinued! Sound more powerful and more pleasant than the A7s even just fed from a receiver. And the looks! - i wish i could take them to the club with me. I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
jeremymarcinko wrote: »But as in all things your perception is your reality. -
I actually think that you will be fine with 2.1 in your bedroom. I just went from 2.1 (NHT sb1s and an AV123 x-sub) to 3.1 adding back in an old def tech center and it maybe helps with some movies. I would say, however, that it is more important to get solid bookies and a solid sub than a center in your application. If you have the extra coin, sure get a center. But you don't really need it.
I think that those rti6's and the psw505 would be an excellent bedroom setup.
Welcome to Club Polk!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
And no, you will not be satisfied with the bass the m70s put out without a pretty powerful external amp. I talked my buddy into getting them without a sub until he can save up for one and I think he's been a little disappointed (he's just powering them with a pioneer vsx 1021). The bass is pretty weak...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@skuzzzzy - yes, if I were you I would invest in less speakers but higher quality. Specially if you don't want to buy extra amplification and just power everything through A/V receiver. For me high quality 2.1 is much better then underpowered lower quality 5.1 for anything including movies and music.
If you are on budget, try looking for used gear. For $500 you can get good used A/V receiver, but nothing worth looking at new.Music Room:
Office system:
Rears - Polk FXI A6
Sub - BIC F12
I think the most pressing issue is the furniture arrangement in your room. The way it's set up right now is so that you and your g/f have to sort of tilt/turn your heads while watching season 3 of sex and the city on blu ray. You've probably already seen seasons 1 and 2 so many times that you didn't bother to buy them.
I would move the bed over about 5 more feet away from the curtains so that it's centered in the room. Then center the entertainment center to align withe bed. Make a couple of DIY stands for the L/R Rear speakers and find a new place for the workdesk and you have yourself a home theater.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
I just want to add one more point, but this time about the Monitor 70s. It's true that they're underpowered without major external amplification. But even when connected to my 75W/chann receiver they project very well, IMO. The bass would be nonexistent were it not for the Audyssey dynamic volume and dynamic EQ. Mine is currently set to dynamic volume "Day," and the bass is definitely there and then some. Of course the sub goes deeper, but I turn it on just to feel like it was worth it to buy it. Mostly I'm watching rock concerts and the Monitor 70s playing at full range more than adequately suffice for that purpose.
Like others have said, a pair of nice bookshelf speakers with a sub pulling low-end duty would probably sound better. But I think the problem with that is that a sub could piss off whoever is next door or in the next room in a bedroom type of situation. I don't know if that's something you would have to deal with or not. You could end up having to switch off the sub and wishing that you had gotten a beefy pair of towers instead. Again, that would be with the Audyssey calibration. From what I've read on other forums, Audyssey does a better job of improving the low-end region in comparison to, say, Yamaha's YPAO. That's of course someone's subjective opinion which I read on an internet forum. It is not empirical data.
Have you considered a wall mount for the tv?Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
Actually even though everyone suggested regular monitor speakers, i was just too in love with towers to not get them. so i went ahead and ordered the m70's =\.
Would had ordered the m60's but wanted them to match the center for look wise, thought it would look weird to have a center bigger then my fronts and i deffiently wanted the cs2 from reading online how much better it is then the cs1.
went with the yamaha over the onkyo since all the bad reviews (read they fixed the issues with latest firmware update) but didnt want to play the rma game incase they didnt.
comes with $100 giftcard so ill either be buying m30's for the rear or selling the giftcard to get like $80 back, will see if i want 5.1 after i get them if not ill stay 3.1.
And yes i do plan to wallmount a tv but not this one, after i pay off my newegg card for this system i plan to upgrade to a 60" plasma. -
if i could i would, but my dresser is there =\
http://img513.imageshack.us/img513/9596/img20120707235450.jpg -
Why go with plasma when there is LED? Sure the plasma is more attainable from a financial standpoint, but unless you plan on outfitting a guerilla unit for the apocalypse, a man only needs one AK-47 assault rifle. You could put the other one on gunbroker and then put that money towards a tv that is not only considerably more efficient, but also less likely to suffer screen burn, if at all.
Personally, I would move the dresser to the other side of the bed and then angle it against the corner to give you more space between it and the bed. There would be that unused space behind it as a result of its being angled, but a negligible amount of space at that.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
I would get a soundbar 6000. comes with wireless sub. great for bedroom.
plasma has better PQ then led and no backlight issues.
plasmas dont "burn-in" unless you leave it on the same image for like days.
My ak's are going up in value every year, plasmas go down. -
Didn't know that about plasmas. Very interesting.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
Also....forgot to congratulate you for pulling the trigger on those items. I'm no audiophile, but I think that's money well spent. Being as that you went with a Yammy, I think a YPAO vs Audyssey discussion would be in order. The small room acoustics confronting your home theater might present obstacles in the calibration process. That is, it might call for additional tweaking / fine-tuning.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
led's have backlighting issues like that. as far as i know you need to spend like 2.5k-3k to get a led tv thats almost on par with a 1-1.5k plasma and even then its still not as good.
plasmas do have image retention but it quickly goes away and never bothered me on my plasma. -
thanks, i just hope too much money wasnt wasted since i decided to go by how something looked vs's best setup for my room. -
I haven't had an issue like that with my LED, but I'll be on the lookout for it. I guess there's always the chance it will happen at some point if not already.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
you should be golden if its not already like that. not saying all have that issue just most will not as bad as this picture usually though. -
If the backlighting issues happen from the onset as your comment implies, then wouldn't that fall within the returnable item time frame?Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
you could play the rma game but it might be a bunch of rmas.
almost any of the newer leds are going to have it unless you have like a 2.5-3k led then chances are better.
issue is mostly because of new edgelit leds models, cheaper to make then local dimming. -
In the first place go clean up your room,what are you a child.Your thinking of plunking hundreds of $s w/a room looking like that.Now I know this the Polk side of things but the Klipsch h/d 500 smalls w/ 8 in powered sub would be perfect for a bedroom(comes w/ mounting kit for all).Right now for my h/t I use them w/ a Yamaha rx-v665 which continually clipped until I changed out into fresh air to let the thing breathe and it's been fine ever since at any volume.I also had a piece of cr-p Sharp htib and will never do that again for any room.Sorry for the rant just noticed that your name is Skuzzzzy...2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »In the first place go clean up your room,what are you a child.Your thinking of plunking hundreds of $s w/a room looking like that.Now I know this the Polk side of things but the Klipsch h/d 500 smalls w/ 8 in powered sub would be perfect for a bedroom(comes w/ mounting kit for all).Right now for my h/t I use them w/ a Yamaha rx-v665 which continually clipped until I changed out into fresh air to let the thing breathe and it's been fine ever since at any volume.I also had a piece of cr-p Sharp htib and will never do that again for any room.Sorry for the rant just noticed that your name is Skuzzzzy...
not sure how my room being messy is any concern of yours.
but just for your info,
i cleaned my room and moved tv to infront of my bed so hopefully you'll beable to sleep good tonight and not have to worry about my mess.
cords are still a mess, fixing all cords when i setup home theater. -
I'm just curious how you're going to position the mains.
Can you bring your bed away from the window, put your dresser along that wall in front of the window?
Then you'd have room to put the Rt main in the corner by sliding the TV stand over a bit.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
