Best 5 or 6 ch. Power Amp. To Push POLK RTi A9 5.2 System? (UNDER $1000.00)
AVTONY2510
AVTONY2510 Posts: 31
edited May 2012 in Troubleshooting
Fronts = Polk RTi A9
Center = CSi A6
Rears = FXi A4
(2) Powered Subs
WHAT IS THE BEST SET-UP, BI-AMP. or BI-WIRE THEM?
I'M USING AN ONKYO TX-NR1008 RECEIVER W/PRE-OUTS AS MY PROCESSOR...
LOOKING TO SPEND $550.00 (USED) & $850.00 (NEW)
THANKS IN ADVANCE FOR THE HELP...
Post edited by AVTONY2510 on
    edited May 2012
    A 5 channel amp for 850 is going to be hard to find, no impossible...but hard. Why not use a 2 channel amp for the 9's and let the receiver handle the rest ?
    With that, you don't need to bi-amp them or bi-wire them, just leave the metal straps on in the back of the speaker and hook up to either the top or bottom posts and away you shall go. Also, gave ya plenty of Amp manufacturers in the other thread. You can also check on Audiogon.com.
  • bklynNupe
    bklynNupe Posts: 728
    edited May 2012
    tonyb wrote: »
    Agreed, your going to need a lot of power for those a9's. For HT, that csi a6 is also very power hungry. You could get a 3-channel for the just the fronts and center or a just a 2-channel for the fronts. The Onkyo can handle the rears.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
