Cracked DVDs from Netflix
jimbo1421
jimbo1421 Posts: 772
edited May 2012 in Music & Movies
Hello
I have occasionally received disks from Netflix that were cracked almost all the way across and obviously unplayable. But I have also received disks with very small cracks radiating from the center hole. These can vary from less than 1/16" to more than 1/4". I usually return them unplayed and request a replacement which Netflix sends promptly. Am I being too cautious? I wonder how much of a crack a DVD or Blu-ray player can tolerate? Will the centrifugal forces at high RPMs (as much as 1530 RPMs) cause these small cracks to propagate and blow apart the DVD inside my Blu-ray player? Has anyone had this happen to them? I assume a disintegrating DVD would destroy the device.
Any thoughts?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
  • gdb
    gdb Posts: 6,012
    edited May 2012
    I never pondered those points. It's not like a steel flywheel cutting off your legs at least !:lol:
  • unc2701
    unc2701 Posts: 3,587
    edited May 2012
    I can't speak for DVDs, but I had a CD crack from the center hole all the way to the edge and somehow still be playable. We're talking clear through- think split washer. Was in a dorm at the time and had to show this to everyone... it was amazing.
    Backburner:Krell KAV-300i
  • gimpod
    gimpod Posts: 1,793
    edited May 2012
    gdb wrote: »
    Maybe not but have you ever seen one disintegrate at high speed! A whole bunch of little bits of sharp plastic going everywhere very fast, it could take out an eye or two plus cut you up pretty bad, like ER bad.
    To the OP I would NEVER put a cracked disk (no matter how small the crack) in a drive you'd just be asking for trouble.
  • jimbo1421
    edited May 2012
    gimpod wrote: »
    You have seen this? The drive tray didn't contain the shrapnel?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • gimpod
    gimpod Posts: 1,793
    edited May 2012
    jimbo1421 wrote: »
    Jim
    Yes but not in a drive also I wouldn't count on that plastic door on the drive to contain jack, you can pop those off pretty easy. !! WARNING !! do not try this at home, but if you do DON'T be in the same room. Years ago just for **** and giggles I chucked up a new blank CD in a high speed dremal cranked it up to 20,000 rpm, left the room and plugged it in the CD exploded immediately. I think I was picking bits of plastic out the walls for weeks.
