Help with receiver wiring
myoung84
myoung84 Posts: 13
edited April 2012 in Electronics
I should have my new system in this week and have some quick questions on wiring.
1. My receiver has speaker A and B outputs. My Monitor50 speakers have a jumper that's removable for bi-amping. Can I remove this jumper and wire them independently from the Speaker A and B outputs on the receiver?
2. My receiver is capable of 7.1 but for now I will be running a 5.1 setup and upgrading to 6.1 or possibly 7.1 later. I have surround and surround back outputs. Which do I wire my existing rear speakers to for now?
Pioneer VSX-921
Polk Series II Monitor50 front
Polk Series II CS1 center
Polk Series II Monitor30 rear
Polk PSW-111 sub
  • colddirt
    colddirt Posts: 30
    edited April 2012
    I'm certainly no expert, but I don't think that will do anything.........Biamping with a receiver accomplishes nothing - I believe you need separate amplifiers to biamp. I'm sure someone will correct me if I'm wrong!
  • myoung84
    myoung84 Posts: 13
    edited April 2012
    I just clarified in the manual that this is not possible...
  • Marty913
    Marty913 Posts: 760
    edited April 2012
    For the surrounds you would initially wire the surrounds and set the receiver accordingly for 5.1. For 7.1 you would connect the back surrounds.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
