Help with receiver wiring
myoung84
I should have my new system in this week and have some quick questions on wiring.
1. My receiver has speaker A and B outputs. My Monitor50 speakers have a jumper that's removable for bi-amping. Can I remove this jumper and wire them independently from the Speaker A and B outputs on the receiver?
2. My receiver is capable of 7.1 but for now I will be running a 5.1 setup and upgrading to 6.1 or possibly 7.1 later. I have surround and surround back outputs. Which do I wire my existing rear speakers to for now?
Pioneer VSX-921
Polk Series II Monitor50 front
Polk Series II CS1 center
Polk Series II Monitor30 rear
Polk PSW-111 sub
Pioneer VSX-921
Polk PSW-111 sub
I'm certainly no expert, but I don't think that will do anything.........Biamping with a receiver accomplishes nothing - I believe you need separate amplifiers to biamp. I'm sure someone will correct me if I'm wrong!
I just clarified in the manual that this is not possible...
For the surrounds you would initially wire the surrounds and set the receiver accordingly for 5.1. For 7.1 you would connect the back surrounds.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
