OT - automobile performance products
124»
  • Steve@3dai
    Steve@3dai Posts: 983
    edited April 2004
    You can resurface slotted rotors. I don't know about drilled though. It's just that Napa can't do it, you have to take it to some kind of speed shop.
    Alcon makes some mean setups, they do the Prodrive kit for the Subarus, and they are awesome. At the same time, Brembo does the kit on the new Subaru WRX STi and that thing stops like an animal. Of course, it dusts it's wheels in like 2 days, hahaha.
    Good set of pads and stainless steel brakelines will be fine for hard street/autocross use. If you plan on taking your Saab to the track, then I would look into a big brake kit. Make sure it's DESIGNED for you car, because of brake bias and such.
    Subaru WRC team uses Pirelli, that doesn't mean I'd use their tires. Michelin makes some awesome tires, but for a price.
    The Yokohama AVS Sports are really freaking good tires as well, great rain performance and sticks like glue in the dry.
    LSi 9/C/FX
    Arcam AVR-200
  • Sami
    Sami Posts: 4,634
    edited April 2004
    Originally posted by neomagus00
    why wouldn't the calipers function well before warm-up? i understand that this is true for race pads, but i was not aware that it was true for calipers as well.
    But what would happen with race calibers and OEM pads? :p
    since you are going to be deactivating the abs (i don't know why you would do this, but it's your car) the issue of tire traction does not enter the argument.
    Several reasons:
    1) ABS isn't necessarily the best option on a track and you also might want to lock the wheels at times
    2) less complicated system, making ABS work with aftermarket calibers might be a PITA
    3) lots of weight saved
    I live in Texas so extreme weather isn't a problem and this car isn't a daily driver so ABS isn't a big deal. Besides it's an AWD (but still getting traction under hard acceleration is a huge problem, I guess it comes hand in hand with all that horsepower :D).
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    sami,
    what kind of car do you have and what type have of performance upgrades have you done?
    in your opinion, what do you think provided you the most performance for the dollar?
    thanks
    -Cody
  • Sami
    Sami Posts: 4,634
    edited April 2004
    I have a 1992 Nissan Skyline GT-R. If you have followed Group A racing in its heyday, you might be familiar with the car. Or N1 racing.
    Engine is still stock (internals) but with some bolt-ons that have about doubled the stock 320hp. Goal for road racing use is about 550(a)whp. The most gain for the dollar you get by just unrestricting the airflow as the car came pretty detuned from factory. Simply raising boost and improving airflow will get the car to around 400hp. Aftermarket turbos, cams, exhaust, intakes, standalone engine management, it's a long list of mods but those are the major ones. But I would say adjustable coilovers probably is the best performance upgrade for the dollar.
  • exalted512
    edited April 2004
    sounds pretty sweet
    do you have pics or a cardomain site?
    -Cody
  • Sami
    Sami Posts: 4,634
    edited April 2004
    I have pics and videos up at http://sami.kallio.com
  • Steve@3dai
    edited April 2004
    I wouldn't consider cams a "bolt on" :)
    LSi 9/C/FX
    Arcam AVR-200
  • Sami
    Sami Posts: 4,634
    edited April 2004
    Well, still a minor mod... :)
    When we get to the engine internals next year, that's when I consider it to be a modified engine. Probably will only go with a slightly larger bore (~2.7l) and forged pistons, don't really need mega power from the engine so I should be safe even with what I have now.
  • Steve@3dai
    edited April 2004
    Who's going to be doing the work up there? CTC joined with Wasabi, and there is Alamo Motorsports.
    I use FIS personally, but that's just because they are mostly a scooby shop. Plus, they have a AWD dyno :)
    LSi 9/C/FX
    Arcam AVR-200
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    i dunno...
    i didn't think about track use, that makes sense
    I live in Texas...
    damn texans...
    suspension - u said this was a good upgrade for the dollar; how do u feel about eibach?
    anyone into autocross? if so, how do i go about getting involved?
  • Sami
    Sami Posts: 4,634
    edited April 2004
    No more CTC for me and Alamo doesn't have a good rep. There is a race shop that normally doesn't do street cars that I'm talking with.
  • Systems
    Systems Posts: 14,872
    edited April 2004
    i dunno...
    Those calibers would chew up the OEM pads almost instantly, leaving you with two metal surfaces against each other. That's a situation where you would need to be replacing the discs as well...
    damn texans...
    Oh please, do not call me a Texan, I only live here. I'm a Finn. :)
    I know a lot of Toyo guys use them for their Supras but I have no opinion one way or another about them. For SAAB I would first look at Bilstein coilovers and see what the other SAAB owners think about them. I think Tein makes some for SAAB as well. It all depends on how much you want to spend and how hardcore you want to get. Good suspension setup isn't very comfortable for daily use although I'm starting to dislike my A4 more and more. Suspension feels way too soft after driving the GT-R.
    Having a suspension and steering that gives you a lot of feedback of the track surface and what is happening there, is vital. When the surface is great, it makes driving very enjoyable. When the surface is bad, it makes things unconfortable. Track = great time. Bad streets with potholes and speed bumbs = places you start to avoid. Also majority of the Texas roads are horrible, made with concrete blocks instead of smooth asphalt, it's like riding in a train, cloonk --- cloonk --- cloonk.
    It's a tradeoff and on a street car, especially daily driven, you are probably going to make compromises. You might not need, or even want, the top of the line race suspension parts but go with the softer, more comfortable setup. You will suffer in track performance but it is more liveable, cheaper and in some real life situation even better performing.
    While the 9-5 isn't the best possible autocross car (if you want to be competitive), it still is a lot of fun. I personally don't go to ones as the GT-R needs a lot of room to strecth its legs, autox is the playground for tiny cars and shifter carts. What they lose in power they gain in lightness. I hardly ever get out of second gear on those tracks, GT-R was made for high speed tracks. A few private sessions are in the schedule to tune the car however, perfect for that. For organized autocross events find the local SCCA club and go to their events:
    http://www.scca.org (go to "Solo")
    Testing
    Testing
    Testing
  • Sami
    Sami Posts: 4,634
    edited April 2004
    Oh, the above is my post in case you're wondering, forgot to sign in before I wrote it. :)
  • exalted512
    edited April 2004
    if youre not proud to be a Texan, we dont want your here anyway:D
    -Cody
  • Sami
    Sami Posts: 4,634
    edited April 2004
    -Cody
    The thing is that I am not a Texan. If you were living in Europe it wouldn't make you European. :)
  • neomagus00
    edited April 2004
    ok, you're cleared now :p
    why would the race calipers cook oem pads more quickly, assuming the same rates of braking etc.?
    hmm... neither Tein nor Bilstein carries Saab stuff. comfort isn't so important - as long as i can still feel my butt after half an hour, i'm good.
    sami, what are the most beneficial (highest gain-to-price ratio) upgrades to airflow? i'm assuming air filter first, but from there on in i'm clueless.
    and thanx for the autox info; actually, my local chapter/division thing has been cancelled for this year, due to a lack of proper leadership and a loss of pavement :(. i'll look around for another nearby division tho.
  • Sami
    Sami Posts: 4,634
    edited April 2004
    When you would be using those calibers to their maximum, it would only take one or two stops until the OEM pads would be gone. Like making tires out of eraser rubber.
    It depends on the car. My car was so restricted from the factory to meet the Japanese "gentleman agreement" that simply opening the exhaust flow provided huge gains (downpipe, exhaust). With the stock settings you probably won't see that big gains in todays cars, it all depends on what else you do to the engine. But like I said, it depends on the car, some have more room to improve than others.
  • neomagus00
    edited April 2004
    hmm... yes, that makes sense. eraser rubber is roughly the consistency of soft racing tires though, no?
    What is the Japanese 'gentleman agreement'?
    and you mentioned turbo boost - how does one go about raising this? typically, that is, i realize it may be different on different vehicles.
    air filter - effective upgrade? if so, urethane foam/sponge or multilayer (k&n style)? brand rec's? style of intake rec's?
  • Sami
    Sami Posts: 4,634
    edited April 2004
    To avoid hp wars, they agreed to not make anything with over 280ps. In reality many do but they still advertise 280ps.
    Boost controller, aftermarket ECU. You might also want to look into standalone engine management systems (replacement for ECU) which will become necessary if you want to get considerably more power out of the engine. This will let you program your engine functions, most importantly fuel delivery. Once you get more airflow into the engine, you will have to increase fuel injection as well. Tuning becomes very important as you don't want to run neither too lean (too much oxygen compared to fuel) nor too rich (too much fuel compared to oxygen). Both have their disadvantages but running too lean is way more dangerous.
    Usually it is very cost effective. What brand, again that is best answered by the SAAB guys. What you might want to do is find a place that lets you dyno for cheap. Take it there after each mod and see how much extra power you're getting, if any. Usually with turbo cars exhaust modifications are also a source for relatively cheap power.
  • neomagus00
    edited April 2004
    how much is a typical dyno? i was under the impression that they didn't come cheap.
    you said 280ps... what is ps?
    exhaust - those really obnoxious exhaust things, do they actually do anything? please say no, i do not want one of those on my car, but if it gives me power i might have to. when you say exhaust mods, what precisely do you mean? like which parts?
  • Sami
    Sami Posts: 4,634
    edited April 2004
    You can find places that have "public days" and will let you do a run or two for relatively cheap, $20-50.
    PS = Pferdest
  • neomagus00
    edited April 2004
    are these pipes something i could make myself? or would i have to buy something premade? i am fairly skilled in typical DIY stuff, and i am willing to learn to do this.
    my turbo is quite small, so there's very little lag, but a relatively small boost. in what way does changing the ecu settings alter the effectiveness of the turbo? ie how exactly would changing some of those settings help?
    lastly, the obnoxious exhaust things to which i was referring are the mufflers that make a car sound like an angry lawnmower on steroids - are the noisemaker ones performance-oriented, as in do they actually help? i apologize for any confusion.
  • Sami
    Sami Posts: 4,634
    edited April 2004
    If you have a welding machine then you can do it yourself. It would, of course, be beneficial if you had been educated in hydraulics.
    The way your ECU is, you can't change a thing. You would have to buy a pre-programmed ECU (can't change that one either unless you have a prommer) or standalone.
    ECU for turbo cars, the main source for power is increasing the boost (and matching the fuel flow). For NA cars they do very little by just increasing the fuel injection.
    Ok, I see what you mean. Sound to some is THE purpose. For performance, it depends. Some exhausts are louder than others and you would definately be increasing the volume over the stock exhaust...
    My car is extremly loud, for a small 6 cylinder. I can do what the bikers do, set off car alarms. LOL. Partly because of exhaust mods but also because of other engine mods (cams in particular). Some say nothing can beat the low rumble of a V8 but they probably haven't heard a turboed I-6 going past 8000rpms. Still nothing compared to the sound a top F1 engine makes revving at almost 20krpm. :)
  • neomagus00
    edited April 2004
    actually, i do know a bit about it and can readily learn more... what parts specifically would i be able to replace on my own? the pipe from engine->muffler, for example?
    in precisely what way is the boost increased? i'm not understanding how the ecu says 'hey, give me more pressure', cause isn't it just based upon rpms (and temp)?
    mmm... f1... i may be going to france this summer to see a race there, which would be absolutely amazing... i've seen the indy race the past couple years, and it was awesome. i even got to drive a lap on the track beforehand (they only let you go 35 tho, which was kinda boring).
    earlier, you mentioned cams. is this a custom thing, or are there companies that make them? either way, how much did you pay (not looking into this now, but it's good to know).
    actually, on the DIY note, is there anything at all that I personally can do to increase performance? assume fair access to equipment and a pretty good diy knowledge. the exhaust pipe has been mentioned, anything else?
  • Sami
    Sami Posts: 4,634
    edited April 2004
    From the turbos to exhaust (pre- and downpipes) and the rest of exhaust piping.
    You control boost by controlling the wastegate on the turbo. If you know hydraulics, you know what a wastevalve is. Turbo wastegates operate a little differently though, they open up periodically and by changing the duration they are open (cycle), you can control boost.
    Lets say your turbos can get up to 1bar of boost efficiently. You only want to use 0.5bar so you will let the excess air flow out through the wastegate and maintain 0.5bar pressure.
    I paid $500 each for two cams (DOHC engine) from HKS. Not sure if any company makes them for 9-5.
    There's a lot you could do. A boost controller is fairly easy to make. I would suggest you take a look at what you want to do with the engine, study how it works and then see what you could do yourself. I'd still buy most of the stuff unless they are ridiculously expensive or not available at all. You have to remember that you're not only paying for the manufacturing of the parts but for R&D that goes into them.
    Cams, if you have a CNC machine, know the specs and have access to right type of material, nothing is stopping you from making them yourself. Or design your own custom cams. You just would be getting into area where it is very important you know what you are doing. If you're not, I wouldn't experiment with an expensive engine.
