End Caps Done!
13»
  • musky1963
    musky1963 Posts: 275
    edited March 2012
    I found that the hangar bolts can be pulled/tilted a little side to side, if needed to fit into the mating holes in the cabinets. Being coarse thread, they grab and go where they want to. Another option is to slightly elongate or drill a slightly larger hole in the cabs.
    Jeff
  • headrott
    headrott Posts: 5,496
    edited March 2012
    Allright, got all the caps finished. i only took pictures of the tops though as the bottoms look the same but inverted.:wink::razz: Anyway, pics are below. What do you guys think? Sorry that I am not the greatest photographer in the world either.:redface::lol: Gonna get on doing a write up of how they sound with the Clarity cap ESA's and Duelund resistors too.
    Greg
    F1nut Posts: 51,952
    edited March 2012
    Looks nice, Greg.
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2012
    Gorgeous Greg.
    SCompRacer Posts: 9,121
    edited March 2012
    Those do look great Greg! High marks for Jeff's work!
  • unclebiskabobka
    unclebiskabobka Posts: 109
    edited March 2012
    Beautiful work, gentlemen!
    TV - LG 42" LED
    Receiver - Pioneer VSX-521
    Front speakers - Polk Monitor 40's Series II
    Center - Polk Monitor CS1 Series II
    Surround - Polk Audio OWM3
    Subwoofer - JBL L8400P
    "I was born with music inside me. Music was one of my parts. Like my ribs, my kidneys, my liver, my heart. Like my blood. It was a force already within me when I arrived on the scene. It was a necessity for me-like food or water."
    ~Ray Charles~
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2012
    I think all model Polk originals are just 1" thick, but that may have just been a cost control decision to keep raw material and machine settings constant.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited March 2012
    Curly (tiger) maple end caps and side strips for my SDA SRS's:
    Figure 1. Curly maple end caps awaiting installation.
    Figure 2. I have never been a fan of any type of oak finish.
    Figure 3. Exotic curly maple is a more appropriate finish for a vintage flagship loudspeaker.
    Figure 4. Curly maple cap and the oak cap it replaced.
    Figure 5. Curly maple and original oak side strip.
    Figure 6. The exotic tiger strip figuring of the curly maple end caps is a much better compliment to the other wood finishes in my home.
    Figure 7. Even in this low resolution picture, the iridescent, three-dimensional appearance of the curly
    figuring is easily seen.
    Figure 8. Closeup of side strip figuring.
    Figure 9. Front/top/side view after installation.
    Figure 10. "Tiger" striping along front edge.
    Installation details coming in a separate thread.
  • thsmith
    thsmith Posts: 6,082
    edited March 2012
    Gorgeous !
    F1nut Posts: 51,952
    edited March 2012
    Even in this low resolution picture, the iridescent, three-dimensional appearance of the curly figuring is easily seen.
    This is due, in no small part, to the fact he uses an Aniline dye instead of a pigmented stain such as the type used by Polk on the original caps. The other part is how the wood is cut. Had Polk used dyed quartersawn oak instead of stained flatcut they would have had the same iridescent, 3-D appearance.
  • DarqueKnight
    edited March 2012
    I know quartersawing reduces the amount of retrievable lumber from a log. Is there a significant cost difference between flat cut and quartersawn and between Aniline dye and pigmented stain?
    But I still wouldn't have liked it. I looked up some examples of quatersawn oak.
  • musky1963
    edited March 2012
    Sorry, I can't agree with that. I have used quartersawn and curly oak, rather figured, and it doesn't 3-D nearly as well as maple. Pictures really cannot capture the effect well either. I have some mottled maple that would blow your mind. It looks like drops of water......... hard to explain.
    Jeff
    F1nut Posts: 51,952
    edited March 2012
    There is most definitely a price difference. Whether one thinks it is significant I'll leave up to the individual.
    There is also a cost difference between pigmented wiping stains and dyes. The cost difference varies even between the types of dye. There is one dye I use that is made in Italy. It's not cheap at all, but it's a concentrate, so depending on the application the actual cost per item can be quite reasonable.
    Those aren't the best examples. It looks like clear coated flooring without a dye, so the "pop" isn't going to be there. However, you still might not like it. Personally, I don't care much for oak.
    F1nut Posts: 51,952
    edited March 2012
    musky1963 wrote: »
    We'll have to disagree to a point. While a ribbon stripe tends to show the 3-D effect a little better, I've seen some old growth oak flake that'll make you think you're on LSD.
  • george daniel
    george daniel Posts: 12,096
    edited March 2012
    I want some. :wink:
  • brgman
    brgman Posts: 2,859
    edited March 2012
    I want some. :wink:
    Oak or LSD?
    I’M OFFENDED!!!!
  • Malbec
    Malbec Posts: 558
    edited March 2012
    http://talaricohardwoods.com/quality.htm
    Speaking of old growth quartersawn white oak. Check the link above.
    I have a Stickley bow arm Morris chair that I lounge in and I can sit there and stare at the ray flecks for hours.
  • angelzSRSSDA1.2
    angelzSRSSDA1.2 Posts: 12
    edited April 2012
    How much would a regular basic stock looking set will go for. I have SRS SDA
  • angelzSRSSDA1.2
    edited April 2012
    I'm thinking even a old used pair would be better then granite ones
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited April 2012
    As some of you may guess from my signature I have several sets of speakers stored for me because I am lucky enough to have patient family members holding them for me out of state.
    When I saw the difference the end caps made for several other members (thanks DK and others for the photos as installed), I decided I needed to order them while I could and have them waiting.
    I contacted Musky since he was volunteering his services and ordered a set.
    Received them the other day, and family reports that they were wrapped exceptionally well and beautiful to look at. Of course i am still trying to explain exactly what they are. (non audio type family for sure) But they have got used to me and strange boxes showing up on there doorsteps with promises that I will someday get all the crap out of their houses!!
    So if anyone was thinking of doing I say go for it. Musky was a pleasure to work with and I thank him for his patience and making the offer in the first place.
    Happy trails,
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • musky1963
    edited April 2012
    Thanks Nate. I hope you will enjoy them! I have another set ready and also a set of curly oak..........if anyone is interested. Jeff
    Jeff
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited April 2012
    Jeff,
    I sent you an email.
    Halen
  • muncybob
    muncybob Posts: 3,262
    edited May 2012
    Jeff, I also sent you an email a few days ago. As I mentioned we are not in a hurry but just wanted to be sure you received it.
    Yep, my name really is Bob.
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited May 2012
    Jeff -
    I also sent an email a few days back having some interest in your work. Hit me back if you did not get it.
    Thanks much!!!
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • PolkMaster1
    edited May 2012
    I am sure someone can answer this question -
    If the end and side-caps are faded, but are in good condition, meaning that there is no physical damage, why not just restain them instead of having to cut new peices of wood? Are there finish or treatment issues when compared to a newly cut and unstained wood equivalent?
  • DarqueKnight
    edited May 2012
    Of course there is no problem with restaining the original caps and side strips. In my case, there was nothing wrong with the finish on my wood trim. I just don't like oak...so no amount of restaining was going to fix that.
