Old Gasoline what to do with it.
  • gdb
    gdb Posts: 6,012
    edited February 2012
    It doesn't
  • BeefJerky
    BeefJerky Posts: 1,320
    Libertyc wrote: »
    Stabilizer won't fix it. Put it on craigs list.
    Stabilizer will stabilize NEW fuel, but it will not renew old fuel.
    exalted512 wrote: »
    i didnt know stabil works after the fact. Thanks John.
    -Cody
    gdb wrote: »
    It doesn't
    Exactly. However, Jstas will never admit that he is wrong.
    I'm also voting that you sell on Craigslist.
  • gdb
    gdb Posts: 6,012
    I wonder what they'll use on the Walking Dead when all the gas gets too old. Diesel? :lol:
  • gdb
    gdb Posts: 6,012
    disneyjoe7 wrote: »
    So does anyone feel its ok to mix like 10 gallons to 4 gallons old, in my 4runner? Or just asking for trouble?
    One other possibility that I forgot to mention is to add some "octane booster", it's the stuff that I used to use in an old muscle car that hated the new lower octane gas. One bottle should revive it to a useable state, maybe two.
    http://www.amazon.com/104-Regular-Octane-Boost-16/dp/B000LNUIUI/ref=zg_bs_15718861_13
  • WilliamM2
    WilliamM2 Posts: 4,811
    gdb wrote: »
    How will boosting the octane revive it? If the gas is old enough it will varnish, and that will gum up carbs and injectors, and stick to the insides of the tank. If it's not removed it can mix with the new gas you put in the tank, and still gum up the carbs.
    If it hasn't varnished, I would just mix a gallon or two at a time with fresh gas when you fill up, as suggested above.
  • gdb
    gdb Posts: 6,012
    You say tomato, I say tomato.....wait..... it Varnishing occurs inside lines,carbs etc. from sitting over time. I have never seen a tankfull turn to varnish, and probably never will when the gas is only 2 yrs. old. If it were mine....I'd take it to the proper collection center for safe disposal or, if only a small amount, I'd kill weeds with it. Give it to the Gator's for a bonfire !:lol:
  • WilliamM2
    gdb wrote: »
    I've seen it varnish and gum up the carbs in motorcycles stored for the winter, 5 months tops. I've also seen much older gas that didn't.
  • gdb
    gdb Posts: 6,012
    That's my point, where it's in a small confine with the addition of air you will get varnish, in a tank that's sealed....not so much.:wink:
  • gdb
    gdb Posts: 6,012
    I've had countless occaisions where the gas in the float-bowl wouldn't start a Kohler engine but, after dumping the bowl and letting in the gas from the tank (also oldish) , bada bing, ignition and lift-off ! 48 years in a farm setting with many, many fuel tanks to deal with I've been able to manage OK.:wink:
  • malvrich
    malvrich Posts: 49
    If you decide not to use it, just take it down to your neighborhood snappy lube and they'll dispose of it properly.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I seen gasoline turn Carbs to crap were I needed to clean them out, but being fuel injected what happens? No air can enter near the injectors so I doubt that varnish is an issue, but more of an octane problem maybe?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
