Anybody find the quality of Adele - 21 atrocious?
Serendipity
Serendipity Posts: 6,975
edited February 2013 in The Clubhouse
Seriously - I can't stand this CD because my ears hurt from the ringing, ear-piercing highs and "swirly" mids in which you can't even tell the percussion instruments behind her voice. I don't even know WHAT instruments are being played, as they are so screechy and noisy. I heard this being played over the PA in a record store at the mall and I had to leave the store. It's no better in the car either unless you turn the treble all the way down and keep the bass set to half way to make it listenable. At home let's just say it sounds like fingernails on a chalkboard.
For those who have this CD - can you stand listening to it at 0db on your pre and not get fatigue?
Please be honest. I have several recordings I can take to +4 and above and it is still listenable.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
«134
    tonyb Posts: 33,072
    edited February 2012
    Seriously ?? You don't think at that volume it's more likely the gear than the CD ?
  • concealer404
    concealer404 Posts: 7,440
    I don't think i've ever listened to anything at higher than -14 on my pre...
    Of course... sensitivity, different gear, etc etc etc...
  • SolidSqual
    SolidSqual Posts: 5,218
    Yeah the recording is garbage. It's digital as hell. You can clearly tell each part of the song was recorded individually and then slammed together. There is no cohesion at all. It's sad because her live performances don't suffer from the same issues at all.
  • Serendipity
    tonyb wrote: »
    I've had Polkies here listening to my old rig at +10dB and it was listenable.
  • Serendipity
    Before I got the Denon AVR-5800, I could take Enya's Watermark to +12dB on "Storms in Africa" and "Exile" and not get listener fatigue.
  • concealer404
    I have a small-ish room that's shaped a bit weird. The speakers have no problems overpowering the space well before i get to the +0dB mark.
    tonyb Posts: 33,072
    Thats kiss a tweeter goodby territory.....especially with a receiver. Good luck to you.
  • Serendipity
    It's well known on here that I am in a large room with lots of open space. And that I listen to lots of Classical, Jazz, and New Age artists. Which are usually recorded quiet compared to the very few pop recordings I have. For example, I read on another forum that Enya's average recording level is -14dB whereas Metallica is closer to 0dB or maybe even in the red??
    If I have Enya - Watermark in the CDP at +5 and then switch over to something like Green Day or Kelly Clarkson, holy cow! I will get blasted beyond belief if I forget to change the volume level.
  • Serendipity
    tonyb wrote: »
    Mozart, Bolero, etc. needs to be turned up that much to be heard at an engaging level.
    For a pop recording, something like Lady Gaga at -30 would be considered loud (and noisy).
  • Serendipity
    I just pulled out the SPL meter and tuned to a local FM station.
    At -23dB, I get 75-76dB average, C-weighted on the SPL meter.
    Then put on "Classical Treasures - The Romantic Piano" which is a cassette tape.
    http://www.tower.com/romantic-piano-classical-treasures-cassette/wapi/106047133
    At 0dB, I get 70-72dB peaks, C-weighted and most of the time the meter is to the left.
    This means FM radio is at least 25dB louder than my cassette tapes!
  • steveinaz
    steveinaz Posts: 19,545
    YES..it is sub-par. It's definitely suffering from over-saturation, loudness wise, and it's a shame for content of this quality. When I only have to light up 2 led's on my passive pre for a CD to be LOUD---it's dynamics are squashed, without a doubt.
    I noticed this right away.
  • newrival
    newrival Posts: 2,017
    totally agree, it's really bad. It's mastered way too high. It goes back to all these threads about dynamics.
    The same with 19. Really bad...
  • Serendipity
    Thank you. I was worried that I would be destroying tweeters with my high volume levels, but the aforementioned volume settings are 'normal' for my musical collection (with the exception of a few pop recordings I rarely listen to).
    I did some more tests, FM radio and pop CDs are by far the loudest, while my cassette tapes and classical CDs much quieter. That's why I'm going into the +dB range of my volume knob regularly with my recordings. For the record, with my SPL meter I did have to go up to the 80dB range with the volume at +3dB, on the second track of Shepherd Moons since I really enjoy this recording.
    But at that setting with Adele's Set Fire to the Rain I'd easily be in the 100 dB or more!
  • Serendipity
    So I made a video with my volume set around 0dB, playing a quiet recording. I have the SPL meter in the video set to the 70dB setting, Slow response, C-weighted. It varies from around 70-75dB and peaks around 77dB. Nowhere near the level necessary to destroy tweeters, although I agree that if I put on a pop/hip-hop recording I'd blow something at this level.
    The volume control on the Denon in this video is turned way up!!
  • Tbone289
    Tbone289 Posts: 661
    I've never listened to it. If you want to listen to Adele, I highly recommend the Albert Hall disc. Of course, it's still more important to get your setup right!
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Serendipity
    I know, see the video above. What I am saying is that I can take my classical recordings to 0dB on the volume knob (and above) and the sound is still listenable, but if I did this with Adele - 21 I'd be well into the 100dB range. This is the problem. It's just too freaking loud.
    In the video I have the volume at -1, then turn it to 0, all while achieving in-room SPL's of 70-77dB.
  • BlueFox
    BlueFox Posts: 15,251
    I'm glad you used an SPL since saying thing like 'volume st a 0db' means absolutely nothing without an SPL reference.
    If the volume is turned all the way up and you are only getting 77db peaks then there is something wrong. Many times when the volume is turned all the way up you are distorting the amp.
    I just put 21 into the CD player and the first song, Rolling In The Deep, plays in the mid-70db SPL range at my usual setting of -40db. I just took it up to 100db at -28db and it still sounds good.
    I agree the CD, like many others, could be better recorded, but it is a pretty good CD. Not as bad as you are making it out to be. Also, get her Bluray, Live At The Royal Albert Hall. That is also pretty good if you like Adele.
  • Serendipity
    BlueFox, the volume can be turned up even higher on my Denon AVR-5800. It can go to +12 no problem and if you look at the video, I did go to +2 for a brief moment but would have to change the SPL meter to the 80dB range. I didn't want to stop the video to change the SPL meter setting so I turned the volume to -1 and then up to 0 so that the level was approximately 77dB. Also, notice when I start the video at around -30dB it is too quiet and you hear the camera's microphone.
  • Bobsama
    Bobsama Posts: 526
    I'm of the same mind: her CDs are bits of leftovers--if it was mastered better, I'd definitely enjoy it a lot more. How many years until MFSL or someone gets their hands on the recordings?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Zero wrote: »
    Great music that's recorded like ****. Proof positive that some engineers out there deserve swift kicks to the d!$!.
    I'd blame the producer before I blamed the engineer. He's the one with the money making those calls.
  • Serendipity
    BlueFox wrote: »
    Huh? You are getting a mid-70dB SPL range at -40dB on the volume knob, and 100dB SPL at -28dB?
    This makes no sense. 12 clicks shouldn't bring up the volume from around 70dB to 100dB.
    I regularly take my volume past 0dB and in the video, I actually had it at +2 for a moment.
  • BlueFox
    Typo. Make that -22db, with peaks around 110db, on both fast and slow response. Of course, I will never listen to Adele that loud, but it isn't atrocious.
    Out of curiosity, with no input I turned the pre all the way up, and it stops at 0db. I guess I need to get a pre that goes to 12. :biggrin:
  • Serendipity
    BlueFox wrote: »
    What happens if you turn the volume to 0dB with an input signal? My system is listenable at 0dB on classical recordings, but at 0dB on a pop recording it's way too loud.
  • BlueFox
    I am not going to find out. At 0db on the pre I will be putting 800W/ch into the speakers, and I'm not anxious to see what happens. As mentioned earlier, the volume setting numbers are only good for your system. They mean nothing to others. Only the actual SPL is valid for comparison. My normal setting for Classical is -40db, and it is playing now. Yes, pop/rock/rap, etc. is louder, so I either turn it down a tad, or if I feel like rocking turn it up some more.
  • Serendipity
    OK, just seems strange that there is such a big volume level difference between recordings. Aaron Copland's Fanfare and Ravel - Bolero need to be turned up past 0dB on my system, while Lady GaGa playing on the radio at -30dB sounds like cr*p.
    Kelly Clarkson's Breakway was noticeably bad too. I had to turn it down so much...
  • BlueFox
    Yes, volume does vary between CDs. There are so many factors, and the loudness added for marketing does not help. I do not have any problem with Adele 21, however the new Lady Gaga CD drives me crazy. Her first two CDs, Fame and Fame Monster, are actually recorded pretty good. Born This Way is recorded terrible, and, for me, is not playable.
  • Serendipity
    To my ears, loud CDs such as Metallica's Death Magnetic or Lady Gaga - Born This Way are simply painful to listen to. I have a volume knob that goes from -60 to +18, why record a CD where I can only go from -60 to -24 and then everything above that sounds bad? Makes no sense.
  • grimmace19
    grimmace19 Posts: 1,429
    Her music could be recorded and mastered better than anything else on earth and I still wouldn't listen...
    Toolfan66 Posts: 18,055
    grimmace19 wrote: »
    Really??? I love her but agree with above statements on mastering. The vinyl is much better..
  • snow
    snow Posts: 4,358
    Interesting reading this, When I first seen you talking about having to turn your receiver up to in the + range I was certain of a few things 1. Your deaf. 2. You have a weak crappy receiver. 3 Your speakers are terribly inefficient.
    But the Denon isn't a weak crappy receiver and I have no idea of what your speakers are, certainly some recordings are much louder than others, for instance I was listening to Alison Krauss earlier then switched to Sade-Solider Of Love and I had to turn down the volume quickly easily a 10db difference or more.
    One of the tricks salesmen will use to sell cheaply built receivers is just that, have efficient speakers hooked up and a couple of really loud CD's on hand then point out that hey at a 1/4 volume its powerful enough to blow you out of the room, of course once you get it home and hook it up to your 84 db speakers it doesnt do as well :mrgreen:
    REGARDS SNOW
