Monitor 60 tweeter problem
ROHfan
ROHfan Posts: 1,014
edited February 2012 in Troubleshooting
I've had my m60's since Feb 2011 (brought from Newegg.com) and the left tweet is crackling since last week. I run an HK 3490 and never push it past -15db so I don't think I'm playing it too loud. Has anyone had this problem? Would Polk be able to send me a replacement? Thanks for any info.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • exlvit
    exlvit Posts: 19
    Try swapping speakers to see if it is the speaker's problem, or if it is something else. Polk's warranty seems to be very good, although I haven't had to use it.
    I run the same stereo setup, sounds pretty awesome!
    PC -> HK3490 -> Polk Monitor 60II+JBL ES150P -> Ears
  • ROHfan
    ROHfan Posts: 1,014
    exlvit wrote: »
    Tried all the usual stuff and it's definitely the tweeter. I'm just hoping I don't have to send in the part and have to wait three weeks until I can use my speakers again. Oh well, I may have to break out the old ADS monsters I have stored in the attic if it comes to that.
  • exlvit
    exlvit Posts: 19
    well, it sounds like you'll have to contact polk and get it fixed up. :sad:
  • malvrich
    malvrich Posts: 49
    and yes you'll wait 3 weeks
  • steveinaz
    steveinaz Posts: 19,546
    If Polk CS walks you thru it, they'll likely have you swap tweeters first to make sure it isn't a crossover issue.
