Monitor 60 tweeter problem
ROHfan
I've had my m60's since Feb 2011 (brought from Newegg.com) and the left tweet is crackling since last week. I run an HK 3490 and never push it past -15db so I don't think I'm playing it too loud. Has anyone had this problem? Would Polk be able to send me a replacement? Thanks for any info.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
Try swapping speakers to see if it is the speaker's problem, or if it is something else. Polk's warranty seems to be very good, although I haven't had to use it.
I run the same stereo setup, sounds pretty awesome!PC -> HK3490 -> Polk Monitor 60II+JBL ES150P -> Ears -
Tried all the usual stuff and it's definitely the tweeter. I'm just hoping I don't have to send in the part and have to wait three weeks until I can use my speakers again. Oh well, I may have to break out the old ADS monsters I have stored in the attic if it comes to that.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
well, it sounds like you'll have to contact polk and get it fixed up. :sad:PC -> HK3490 -> Polk Monitor 60II+JBL ES150P -> Ears
and yes you'll wait 3 weeks
If Polk CS walks you thru it, they'll likely have you swap tweeters first to make sure it isn't a crossover issue.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
