Pyle any good?
edited February 2012 in 2 Channel Audio
I can get a Pyle PT560AU pretty cheap.
Is Pyle any good or should I buy something else?
http://www.pyleaudio.com/sku/PT560AU/300-Watts-Digital-AMFMUSB-Stereo-Receiver-
It will be used for home 2 ch w/ sub
Post edited by gwdgs on
Welcome!
    edited January 2012
    I had a Pyle amp for a short time... build quality wasn't too good.
    I would be worried that the unit fails shortly.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited January 2012
    Ya I just did some checking no sub output on the one I was looking at.
    Looks like I keep saving for the M NR1402
    edited January 2012
    Stay away....very far away!
    --Gary--
    edited January 2012
    halo71 wrote: »
    That's what I was trying to say while being nice...
    edited January 2012
    Pyle of crap.
    edited January 2012
    If you're looking for a great bang for your buck stereo receiver, look no further than the HK 3490.
    edited January 2012
    You could also consider an integrated amplifier since your only looking at 2 channel you dont need all the extra stuff in there. Consider the used market for sure like audiogon.
    edited January 2012
    I use some of Pyle's speaker offerings but I wouldn't suggest wasting your time on their electronics.
    Too much **** to list....
    edited January 2012
    Pyle goes for the low-end pro-gear market, the gear works is about the best I can say for it, I would never use it for home stereo application.
    RT1
    edited January 2012
    Are you guys sure it's not one of those "giant killers" I'm always hearing about? :cheesygrin:
    edited January 2012
    Agreed. Fun and cheap for experiments.
    edited January 2012
    decal wrote: »
    Very.
    In fairness and in the interest of disclosure, though...
    I do have a pair of Pyle compression drivers here that I actually bought with malice aforethought. The Fs and claimed frequency response of the driver fit my intended application (Altec 511B horns) and they cost, like, 27 bucks a pop. They're hefty, reasonably well made and they sound OK. Hard to knock them, really... but we're not talking Altec/JBL class compression drivers, either - probably not even Selenium/Eminence/B&C grade. Cheap enough to play with, though.
    EDIT - FWIW here is what I was doing; just playing around - a Frankenspeaker with a 511B and the aforementioned Pyle driver on top, and the bass section of an AR-2 (unsuffixed) on the bottom - "vertically biamped" in the most ghetto manner imaginable - the horn/driver (with XO) hooked to one channel of an hk 330i receiver, and the AR-2 bass section hooked to the other channel. Feed a mono signal to the receiver, and "tune" the HF/LF integration with the "balance" control. :-P MacGyver would be proud.
    It worked a treat, actually.
    edited January 2012
    My Dad used to have some PyleDriver subs in his car in the late 80's. I do remember them sounding very good. Mind you he was not into rap or rattling teeth or anything, but they were decent woofers.
    --Gary--
    many years ago (as with a lot of brands of almost anything imaginable) Pyle was very good. They originally produced only speakers. I think but am not sure the company's start up owners last name was Pyle. Hence the original name of Pyle Drivers. Sometime in the 90's the company was bought out by an electronics corp (Sound Around) that now holds many brands such as Pyramid, Lanzar, legacy, and others. Since then it has mostly been very cheaply made Chinese equipment. The sound lets you know it as well. I personally would not recommend any current Pyle speakers or equipment for use in a situation where you expect to enjoy it/ them. If you need something cheap just to fill a hole or get you by for a very short period, you may be ok, but the sound and quality is lacking on all of their product produced in the last 15 or so years IMO.
    how to reset pyle hybrid pro p1001at 1000whatts? help me
    or go 9-pound to ensure a one and done reset. :|
    Or an old fashion plye driver. :D
    [/quote
    Go big,or go home.
    I had my Pyles removed surgically.
    I think we’re a bit too hard on Pyle. I have a phono preamp around here that I use once in awhile. It’s crazy inexpensive, absolutely dead quiet and it compares favorably with my Parasound phono preamp. They obviously use cheaper opamps but a slight loss of sound stage and small lack of punch in the bass are all I can hear. But these things are less than fiddy bucks! They come in very handy at times.
    The world is full of answers, some are right and some are wrong. - Neil Young
    It'd be funny if Schitt bought Pyle.
    OleBoot wrote: »
    is that why you sing soprano?
    Willow wrote: »
    I think you are confusing your Pyles with your NADs. Having said that, since the surgery I do get an improved baked bean treble response.
    OleBoot wrote: »
    ^^^ That is signature line material, that is!
    I am rolling on the floor here.
Welcome!
Welcome!
