SDA Driver Seals: Original Foam vs. Mortite vs. Armaflex Foam
13»
    Toolfan66 Posts: 18,194
    edited January 2012
    Round it is..
    Is the 1.875 center to center on the holes? Also will .250 holes be ok or do you need them to be a different size?
    Colors? I probably can come close to matching any color you would like.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited January 2012
    thejck wrote: »
    How do u pull the old drivers off if you used mortite. They are a pia.
    I made a small prying bar from a 8-1/2" piece of coathanger wire. I flattened the prying end a little bit (reduced thickness about half) to make it easier to get under the rim hole.
    I still use the pry bar with my Armacelled drivers. Of course, the Armacell does not cause as tight a fit as the Mortite, but the Amacelled drivers don't always fall right out after unscrewing.
    heiney9 Posts: 25,520
    edited January 2012
    thejck wrote: »
    Toolfan66 wrote: »
    I pulled the crossover and pushed from the back side then worked my way up.. I don't miss mortite at all..
    Mortite has been in place over 2 years now and I've taken the speakers apart twice, never a single issue. Actually the Mortite stays in place on the back of the drivers. Not sure why you are having issues.
  • DarqueKnight
    edited January 2012
    Toolfan66 wrote: »
    Yes.
    Toolfan66 wrote: »
    I had to take one of the screws out and match the plate hole to my drill bits. The holes are 3/16". With the large flathead screws I am using, 1/4" holes would work.
    Toolfan66 wrote: »
    Black.
    edited January 2012
    Consider it done!!:smile:
  • DarqueKnight
    edited January 2012
    Thanks. Send me a PM with cost and shipping.
  • thejck
    thejck Posts: 849
    edited January 2012
    heiney9 wrote: »
    One of my braces had come loose and i had to pull a driver to get to it. I struggled with the driver and ended up having to use a screw driver to pry on it which nicked the wood slightly and I am not too trilled about it. I ended up using a screw that was able to grip the screw hole on the basket and use that to pry. I am not sure what damage this has caused and I have had a really frustrating day cause of it.
    When I installed the mortite I pushed it onto the basket and then screwed it onto the wood. When I pulled it off half of it was on the basket and the rest on the wood. I even had used poly urethane on the wood before I installed the mortite to prevent it sticking.
    I am using Larrys rings as well and maybe that is what is causing the sticking.
  • thejck
    thejck Posts: 849
    edited January 2012
    going to try this in the morning.
    Isnt the Armacell only sticky on one side?
    You said you cut the tape at a 1/4 inch did you end up getting 4 strips from each section or was there some cutting waste.
  • DarqueKnight
    edited January 2012
    thejck wrote: »
    going to try this in the morning. Isnt the Armacell only sticky on one side?
    Yes, the Armacell is only sticky on one side, but some of my drivers have a snug fit which requires some extra effort to remove them. I made the small end of the prying bar 3/8 inch long.
    One clarification: I call this a "pry bar", but I don't use a prying action where the flat end is inserted in a driver's rim hole and the bar is pressed downward to pry the rim up. The flat end is inserted in the rim hole 1/8" to 1/4" and the tool is pulled outward.
    thejck wrote: »
    I cut 1/2 inch strips. The Armacell is 2 inches wide, so this allowed four 1/2 inch strips per section:
    Marks 1/2" apart were made on the Amaflex's backing at regular intervals. Ink and pencil marks did not easily adhere to Armaflex's yellow wax paper backing, therefore a fine point ink pen was used to punch holes and then the pen and straight edge (24" drafting T-square and 48" carpenter's level) were used to scribe cutting guide lines.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2013
    Old thread, great info.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    xschop Posts: 5,417
    11 years later, and still relevant. Enjoy reading Ray's findings.
    qwertycus wrote: »
    replacing the plastic brackets with something more substantial, maybe machined from aluminum or steel?
    Looks like a job for SUPERLARRY! (aka Toolforlifefan):tongue:
    Put me down for six in natural brushed aluminum.:biggrin::cool:
    First time reading this post. So someone was pondering alloy faceplates back in the day.
    And F1 didn't blow a fuse lol
    pitdogg2 Posts: 27,349
    Anything Ray did is always going to be relevant when it comes to SDA's.
  • skipshot12
    skipshot12 Posts: 2,092
    Absolutely relevant 11 years later.
    I’m going thru this right now and, all that came before saved me from the headaches of trial and error….
    I thank you all.
    Skip
