Making acoustic panels and other general room treatment questions
2
    SCompRacer Posts: 9,084
    edited January 2012
    Toolfan66 wrote: »
    Received an email from GIK that my panels will ship out on the 18th..
    Kewl!
    Sal, some ways to measure room response.
    XTZ Room Analyzer.
    http://www.acousticfrontiers.com/XTZ-Room-Analyzer-II-Standard.html
    Room EQ Wizard
    http://realtraps.com/art_measuring.htm
    Mike (Face) told me about this Dayton Audio OmniMic. IIRC he uses this to measure speakers but it can be used for rooms.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=390-790
    I've made some acoustic treatment believers by removing the treatments while they sat in the sweet spot.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2012
    Toolfan66 wrote: »
    I'm happy yours are on the way!
    I felt a bit guilty being second in line, but I gotta tell you that after completely filling my van with them, it would have been almost impossible for Ricardo to package and ship his panels for less than a small fortune.
    It was almost 2 years ago I researched and got the help here at CP to know treatments were mandatory. At that time I achieved some relief with blankets and rolls of insulation stacked in the corners, but the GIK's are ridiculously better!
    Now the fun begins as you get to accumulate some of the response measuring gear mentioned above, listen, and re-evaluate every tweak you've ever made in your more new, more accurate listening environment.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Phasewolf
    Phasewolf Posts: 514
    edited January 2012
    Has anyone tried read rta? It is a really nice program and with a good Mic you can do a lot with it. And the best part is there is a demo.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
    Toolfan66 Posts: 17,984
    edited January 2012
    It's all good I don't blame him and it wasn't like I don't have treatments just not 4" thick Gik's :smile:
  • inspiredsports
    edited January 2012
    Toolfan66 wrote: »
    Actually, half of them were 6" and half 4", and the Tri-Traps are just massive. I'm on the hunt for more Tri's now.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2012
    quadzilla wrote: »
    . . . the back wall also has a 6x6 bookshelf filled with records, so I expect that should act somewhat as a diffuser . . .
    Having that on your back wall is perfect! I've heard of folks truly getting a diffuser effect with LP's by pulling serveral inches of them out a couple inches, leaving the next four inches all the way in, then pulling out the next several inches out and alternating that pattern over all of the shelves for a 3-D checkerboard effect.
    I guess it wouldn't be the best solution if you're OCD about your LP shelves being neat :mrgreen:
    NAD SS rigs w/mods
    GIK panels
  • FTGV
    FTGV Posts: 3,650
    edited January 2012
    While no longer commercially available these apparently very effective active bass absorbers are reasonably easy to DIY.I,m in the process of building a scaled down version using a single driver per column,one each for my front corners. http://www.monarchyaudio.com/PDF/Phantom.pdf http://www.stereophile.com/roomtreatments/1289phantom/
    A similar product is now marketed by BagEnd called the E-Trap.http://www.bagend.com/
    edited January 2012
    My GIK acoustic panels just showed up and at first glance they look fantastic and the quality looks top notch as well, lokking forward to getting them home so I can take them outta the box and get a real good look at them..
  • nikolas812
    nikolas812 Posts: 2,915
    edited January 2012
    Heres a thread I started a while back on some acoustic panels that I built... They were VERY effective and not hard or expensive to build...
    http://www.polkaudio.com/forums/showthread.php?65330-DIY-Acoustical-Treatments
    Nik
    EndersShadow Posts: 17,687
    edited January 2012
    nikolas812 wrote: »
    Nik
    Subscription added for later use :smile:.
  • audio_alan
    audio_alan Posts: 770
    edited January 2012
    Toolfan66 wrote: »
    Cool, Larry. I'm sure they will make a big difference in your room! But you know what they say....
    Pics, or it didn't happen! :cheesygrin:
    edited January 2012
    nikolas812 wrote: »
    Nik
    Nice job Nik!!!!
    edited January 2012
    audio_alan wrote: »
    I will take some pics tonight.. The bass trap is huge about 6" thick..
    edited January 2012
    WOW!!! I am so glad I picked these up they put my cheap/DIY ones to shame, my room sounds so much better the speakers sound more level volume wise the center vocals are more forward and the bass is fuller and tighter, the one cool thing about the bass that shocked me was it hits me harder in the sweet spot, and I don't even have then hanging yet I just placed them around the room about the areas I want to hang them..
    Very happy with my purchase now I feel I can focus more on gear then speaker upgrades, cables, and an audio rack. My list is getting shorter..
    edited January 2012
    Toolfan66 wrote: »
    the one cool thing about the bass that shocked me was it hits me harder in the sweet spot....
    Kewl! Congrats!
    Same thing happened here when I stacked two GIK Tri-Traps in each corner and stuck three GIK 244 panels behind the speakers. Startling, articulate nuanced bass. Trentemoller's Vamp and deadmau5's Sofi Needs a Ladder never sounded so good.
  • Phasewolf
    edited January 2012
    Toolfan66, you said that the new traps work a lot better then the ones you had made were they all the same thickness old vs new or were the new ones thicker. Also did you use the same amount and type?
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • Face
    Face Posts: 14,340
    edited January 2012
    SCompRacer wrote: »
    Kewl! Congrats!
    Trentemoller almost put me to sleep, fortunately deadmau5 woke me back up. :wink:
    edited January 2012
    Face wrote: »
    You mean like too much foreplay versus just getting right to it?:cheesygrin:
    edited January 2012
    Phasewolf wrote: »
    My old ones were all 2" thick and hung flat to the wall yes they were all the same material, these were panels I picked up for $3ea. I picked up 10 of them, but they were not pretty so the wife picked out some material to cover them (the DIY part) and even though they did the job and tuned the room they don't touch the GIK's.
    The room kit I picked up from GIK came with 1 Bass Trap that is 6.750" thick, 4 Bass Trap's that are 4.500" thick, and 3 Acoustic Panels that are 3.500" thick. All panels are built to keep a gap of about 1.500" on the back side from the wall they are also built to absorb from the sides of the panels not just from the front or back. The quality is top notch as well as the design..
    I was always in the room treatment camp but I cannot recommend it enough now. I would say if one is going to build there own I believe the 1.500"-2.000" gap from the wall is a must..
    edited January 2012
    Toolfan66 wrote: »
    Which room kit did you go with?
    edited January 2012
    Kit 1
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2012
    awesome job on the panels Nik!
  • tommyt21
    tommyt21 Posts: 685
    edited January 2012
    I dont mean to thread jack, but i just recently became aware of room treatments. In my situation would a product like this work behind my front speakers? http://www.amazon.com/Auralex-WEDGIE-24-Wedgies--Panels-Charcoal/dp/B0002D05KA/ref=sr_1_2?ie=UTF8&qid=1327540306&sr=8-2
    I have to have my speakers in this placement nowhere else to put them. They are estremley close to the wall on twoo sides. I tested it with some bed pillows directly behind the A7's and I thought I noticed a difference in the mid range, but I don?t know if that?s my mind playing tricks on me. Theoretically acoustically treating the Niche(it's 11 inches deep) where I have all my equipment should that help with what I perceive as muddiness in the midrange?
    Also I have a corner loaded sub on carpet/pad/Concrete would a subdude/Gramma pad help with some of the boomieness I get?
    Attachment not found.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • tommyt21
    tommyt21 Posts: 685
    edited January 2012
    Regarding my above post would the Acoustimac DMD panels be a better choice than the Auralex foam? http://www.acoustimac.com/index.php/acoustic-panels.html
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • inspiredsports
    edited January 2012
    I would reccomend you stay away from foam and concentrate on GIKAcoustics.com, RealTraps.com or home-made panels using their designs.
    NAD SS rigs w/mods
    GIK panels
  • audio_alan
    edited January 2012
    +1 on avoiding foam, unless you are just going for hi-mid and highs control. They don't do much to bass. Rigid fiberglass is definitely where it's at. They help absorb sound through the entire sound spectrum.
    Regarding Larry's point about spacing the panels off the walls, I've read that with rigid riberglass you should space them away from the wall as much as the panel is thick. So 2" panel, 2" off the wall, 4" panel, 4" off the wall, etc. That will ensure that it absorbs the most sound, and evenly, but it can also eat up a lot of space. As Larry suggested, at least make sure they are 1.5"-2" off the wall. Corner traps are the best because they are at an angle to the 2 walls, making a varying-width gap.
    Congrats on the new traps, Larry!
  • Polkie2009
    edited January 2012
    +1 on avoiding the foam also. I looked into trying foam when I first got interested in room treatments,but after learning more, found panels are much better. there are a number of folks who make nice sound treatments as mentioned above. If you like the acoustimacs, try them out,they seem fairly priced and have decent specs. If you don't like them, sell em and try the GIK's or RealTraps, ATS, etc...:)
  • thejck
    thejck Posts: 849
    edited January 2012
    I have large 5 feet tall glass windows behind me about a foot from where I set. Does anyone have any thoughts on how to live with this? My wife recently made some roman shades for the windows. They are cloth with a product called warm window fabric that consists of thin layers of foam to insulate the glass. They have helped some but i dont think they work as room treatments are supposed too.
    Any ideas? move? I soo wish I had followed my plan to build my house instead of buying this one.
    edited January 2012
    thejck wrote: »
    Thick curtains are about all you can do honestly. Its what I have had to deal with in the past.
  • tommyt21
    tommyt21 Posts: 685
    edited January 2012
    I just got my Auralex Gramma in and WOW:eek::eek: I'm a believer, bass cleaned up like crazy, Nice tight even more in the chest style thump. My Hsu sounded good before but this was like throwing a freaking awsome switch on. Instant things I noticed less rattling around the room, greater accuracy, super clean hits, less bass nulls through the room and the biggest improvement was the boom I would get especially with the really low end its all but gone. Even though the Gramma is greatly over priced ( if we look at the materials used) It was probably the best dolla for dollar improvement in my system yet.:mrgreen:
    I orderd some 2 inch acoustic panels to go behind my A7's now i'm really excited to get them in. Then I think I will give a whack at some DIY panels...:razz:
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
