Subwoofer red and white jack replacement?
matt92
matt92 Posts: 9
edited January 2012 in Troubleshooting
Hey guys I'm in need of some help, I know a decent amount about audio equipment. I have an elongated 8' polk audio subwoofer - model number UL 1492 or LR106476. I moved my surround sound to my dorm room. I was hooking it up and I had the red and white audio cable plugged in and when I sat it down the cable did not reach and therefore broke the tips of into the audio receptors. I removed the tip from the red jack sucessfully, but cant remove the white one. I was wondering what part should I buy to replace it or what I could do. I would be greatful for some info soon!
Post edited by matt92 on
  • michael1947
    michael1947 Posts: 775
    edited January 2012
    Post some photos of both broken parts and we may be able to come up with a fix.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • matt92
    matt92 Posts: 9
    edited January 2012
    I don't know if you can see that clearly, but the red input is clear, and the white or negative is clogged with the tip.
  • hertz9753
    hertz9753 Posts: 310
    edited January 2012
    matt92 wrote: »
    I would try a pin, needle or a small nail to remove that.
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
  • matt92
    matt92 Posts: 9
    edited January 2012
    I've tried that, actually both broke off and i cut one end off a cue tip, put super glue on the end and pulled it out, but its not working for this one. What is the name for the audio receptors? I'm guessing I will have to buy new receptors for it, could someone give me a link to where they sell these?
  • ken brydson
    ken brydson Posts: 9,058
    edited January 2012
    I could be wrong but I believe you only need 1 unless it's some kind of sub/sat setup that requires R/L. I only use one on my SVS.
  • matt92
    matt92 Posts: 9
    edited January 2012
    yeah I've plugged it in with one, but it only has half the power with one, it doesn't seem near as loud.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2012
    It seems lower in volume due to half the input voltage, but that shouldn't affect the output wattage of the amplifier. Make the needed gain adjustments to compensate. If you are getting the signal from a receiver that has adjustable subwoofer gain, move it up by 3 dB.
  • matt92
    matt92 Posts: 9
    edited January 2012
    Ok I have two tuners, one that controls power output (Hz, from 60-180), and volume (60-180). I noticed it has 2 inputs for speakerwire, and 2 outputs for speakerwire, so I went ahead and plugged the inputs with my reciever, it seemed that it may of helped some, but not much. Do you think it makes any difference hooking them up? Also is there anyway I could just buy a new svc box?
  • Dennis Gardner
    edited January 2012
    One knob is the crossover frequency cutoff, the other is volume. If you are handy, you could unplug the unit from the wall and take out the screws that mount it to the back of the box. This would allow you to see if the broken part could be removed from the inside at all. The whole amplifier is mounted to the metal plate that you see and should be easy to get into.
  • matt92
    matt92 Posts: 9
    edited January 2012
    ok i will do this soon, and upload a pic of the amp. Thanks for the replies guys.
  • matt92
    matt92 Posts: 9
    edited January 2012
    I took apart the sub, and took two photos of the amp.
    I believe the vca receptors are by the yellow glue or muck. How much would a new amp cost?
  • matt92
    matt92 Posts: 9
    edited January 2012
    does anyone have any advice of what i should do?
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    You can replace the RCA connectors if you know how to solder, or a local TV repair shop can do this for you. Shouldn't cost much, my roommate in college had this done for $20 IIRC.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    If it were me on a budget I would go get a roll of speaker wire and use the speaker level inputs....
    Too much **** to list....
  • matt92
    matt92 Posts: 9
    edited January 2012
    awesome thanks, I called around yesterday to some audio places, and they were going to charge me 25$ just to look at the sub, even when I told them what is exactly wrong with it....I'm goin to try some tv repair shops now.
  • i'm looking to purchase one of these used, but i can't find the user manual anywhere online. does anyone know what the ohm resistance is and how many watts are in these bad boys? i'm hoping it's compatible with my onkyo tx-nr535.
  • If you want to replace the RCA jacks, they are available from Parts Express or any other parts dealer online.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
