LSI9 woes
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited April 2004
    When you say, "SR Tough" what are you referring to? Do you mean the wood material the cabinet is made from?
    Ken
  • bogo
    bogo Posts: 53
    edited April 2004
    Hi Gatemplin,
    Thank-you for the advice. What exactly do you mean by 'bondo', is it possible to be more exact. I was just planning on getting a replacement top part of the SR TOUGH finish, using a heat gun to take it off and reaplce it with a new top piece.
    So you think judging by the shabby picture at http://pictures.baldacchino.net/audio/P1010019 it is possible to repair this?
    Shane Baldacchino
    Microsoft Certified Systems Engineer
    Microsoft Certified Systems Administrator
    Microsoft Certified Professional
    A+ Hardware and Software Technician
    http://scriptandcode.com - Your trusted partner for your scripting and code needs.
  • gatemplin
    gatemplin Posts: 1,595
    edited April 2004
    If you can get an exact replacement piece from SRtough and just glue it on, then do that.
    Bondo is an auto-body filler. It dries very hard and smooth when sanded down. It is cheap too. I would pull off that piece with a heat gun. Prep the area with tape and carefully remove the broken MDF if there is any, and use Bondo to make a flush mating surface for the new laminate. This may not be necessary but I cant tell from the picture.
    Graham
  • bogo
    bogo Posts: 53
    edited April 2004
    Thanks for the great advice. I will post some better pictures after the weekend and hopefully next week get started on the repairs.
    Thanks again for the feedback.
    Shane Baldacchino
    F1nut Posts: 52,294
    edited April 2004
    Bogo,
    Mate, just buy the replacement cabinet and be done with it.
    F1
  • bogo
    bogo Posts: 53
    edited April 2004
    For the price of a new cabinent I would prefer to buy two new speakers. The cost of a cabinet is $680 AUD. I paid 650 USD a pair. I am convicned I can fix this.
    Shane Baldacchino
    F1nut Posts: 52,294
    edited April 2004
    Point taken!
