CD Players
VR3
I would like to preface I will ignore any suggestions involving an IPOD, Squeezebox, etc - I do not want it for serious listening, period. I just dont feel it is me.
Now that I got that out of the way - WOOO
Like my amplifiers I am going to most likely downsize here as well...
I would like to keep my budget at around 1k -
I like to buy my sources new, however; I am willing to adventure into the used market of course on a newer model...
This is where my experience is more limited and I do not know of many brands...
My Symphonic Line player is pretty much just amazing - it will be impossible to top and I really dont know if I can part with it but I will try. This one I will buy the player up front to a/b them and if it is close I could see selling my Symphonic Line - hence why new with 30 day trials is a good way to go...
So I am just looking for suggestions if any...
Thanks in advance!
Thanks in advance!
Post edited by VR3 on
Look no further then a Cambridge Audio Azur 840c. I have compared it to many others including higher end models and nothing I feel is a better player for under 3000.00 even then and above I don't see anything blowing it away.
As far as your budget , used would score one new you need to save a few more pennies.
Good luck hope this helps.Dan
I will have to put it on the list...
The Klarheit II sells brand new for $4,000 and is said to be as close to vinyl as it gets... I like to call it a musical Wadia.
So I am keeping an open mind, this is for sure!
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Amazon is actually selling for 1k shipped! Hmmmmm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A Jolida JD100 would fit into your budget nicely. It's got a tubed output stage, which is nice to have if you're not using it strictly as a transport.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
1K will buy a real nice DAC."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
And do what with the dac???
Players I have heard in the past that did not do much for me -
Rega Apollo (Very flat and 2-d sounding)
A Denon SACD player, not sure of the exact model (just no comparison)
A high end Wadia (Very dark and analytical, a little to dry for me, but an incredible sounding player)
Players I have had before
Shanling CDT100 (really really liked the straight solid state outs, not the tube buffered out)
Onix XCD 88
I have heard the Jolida CD player at several Polk fest and I am not a fan of tubes all over the place, a tube pre seems to be just right for me!
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
They still make CD players???? Big step backwards...huge!
"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Musical Fidelity A1 CD ProVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
The CA 840 CDP is very nice sounding, a big step up from the sound of their other CDP's. IMHO buy the cheapest CD spinner you can find that outputs a solid bitstream and put your money into a good DAC. That will give you the most flexibility.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
That is interesting, so what would be a good DAC? And what would you use for a source?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
As you mentioned you don't want more tubes in your system, I would suggest a used CA CDP as a transport and a used PS Audio DLIII DAC. There are mods available for the PS Audio DAC, if you so desire. The Music Hall 25.3 has mods available and uses SS for the balanced outputs. Others here are far more knowledgeable than I on DAC's. I own the PS Audio and the Music Hall and enjoy them both.
I also own the Jolida CDP and the Rotel 1072 CDP's as points of reference. Either DAC I referenced will significantly improve the Jolida SS output or the Rotel CDP output. I have very good tubes in my Jolida and it will just slightly better either of these DAC's.DKG999
Very interesting.... Hmmm
That gives me a good bit to think about!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
here's a great sounding cdp ( i own one) virtue audio piano m1
http://www.audiocircle.com/index.php?topic=99870.msg1014199;topicseen#new
i think may still have a couple of new ones so you can configure them like you want, but this used one is a great deal.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Vr3MxStyler2k3 wrote: »And do what with the dac???
Hook it up to a Squeezebox :cheesygrin:
I am curious why it's not "you"? Are you adverse to convenience? Or are you just being an audio snob? I was that way until I actually used one, not anymore.
Just busting your balls a little bit, but I am still curious what it is about the SQB you don't like.
Sorry I can't be of much help since I gave up that archaic cdp machine quite awhile ago
I honestly like flipping through CDs - I like being "forced" to listen to an entire CD if I so desire... I dont know, it is part of my experience.
Having my entire collection at my finger tips would make it feel a tad disposable to me.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If you get a good dac, music hall, musical fidelity, wyred4 sound, benchmark, etc you can get a pretty basic cd player as transport and have the flexibility of adding your computer, or whatever fancies you in the future.
I run my oppo dv980 h as cd player and love it, but according to stereophile it really shines as a transport, you can look it up. I paid 80 bucks for mine to a member of the club, so that would leave you with 900 from your budget to buy a dac that will better any 1000 cd player.
Good luck,
EduardoHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
Vr3MxStyler2k3 wrote: »I honestly like flipping through CDs - I like being "forced" to listen to an entire CD if I so desire... I dont know, it is part of my experience.
I agree with you on this point. Sometimes I like a digital source because my entire collection is at my fingertips, but sometimes I feel like I get lost in all that. Putting in a CD or LP and just letting it play out can be really enjoyable. I don't have the urge to 'search' for the next song, playlist, genre, etc instead of just listening like I should be.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
Don't overlook Rotel--under appreciated, but very respectable in the bracket you're looking at. The Cambridge is solid as well, and has the benefit of additional DAC inputs. Used Arcam/Musical Fidelity are always a good choice, too.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
A cd is a digital source. I get where you guys are coming from, I WAS the exact the same way and you can still hit play and listen to an entire cd uninterupted, but the other convenience factors are off the charts so I am no longer that way.
Not trying to take this off topic, so that will be my last comment on the subject of not using a cdp.
Good luck with your search Trey
Some people like to "fiddle" that's part of the big charm of turntables, I "get" it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I can respect that and why I asked the question. I'm sure there are people that don't understand my fascination with tube rolling, that's "fiddling" around all the time
The "fiddling" part of vinyl is why I have never gotten back into it. The "ritual" as some call it, would drive me nuts! :cheesygrin:
I will echo other's comments about getting a decent transport and an external DAC.
This way, you can upgrade either component individually at a later time. Plus a good external DAC will sound better than a CD player in the same price range. All DAC's sound different though, so you've got some research to do.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Changing CD's is as mundane as flipping a record."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yeah I guess my last post was a bit of a misnomer because a CD is 'digital'... but it's also 'physical', whereas computer cataloged digital sources are not.
Don't get me wrong, I have and use both personally, and each has its ups and downs. Which I prefer has as much to do with my mood on that day as anything.
To Trey, I also agree with the last couple comments. I think what you're really looking for here is a DAC. I mean a CDP is really just a transport and a DAC in a single box, and a lot of the better CDPs use the same Phillips style transports anyway, so what you're really hearing is the difference in DAC between different players, and some differences in their output stages (especially for a tubed player).
If you use the bitstream output on a decent transport CDP, and a good DAC of your liking, you may get where you want to go more easilly. It'll also be easier to change the sound of your system later by just changing the DAC alone.
I'm really interested in seeing where you end up going with this because I'm getting more interested in fooling with DACs myself also.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
You may want to look at the Sony SCD-XA5400ES. Very highly rated. I believe that it can be had new for around $1000.00 on Agon.
listen to an Ayre cd player
Ayre is extremely nice, but $$$$$$$$$Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Which is why some put the digital CD files on another storage media, and then listen to a play list of CDs, or random shuffle through the CDs, or random shuffle through all the songs on all the CDs. Some of these playback systems let you use an iPhone, iPad, Android phone, or tablet to remotely select CDs, songs, create play lists, etc. Or you can use a web browser instead to manage the music. Basically, everything you cannot do with a CD player.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yep, I use my Droid 3 to control my music library via J. River(Gizmo app)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Why not have all of it at your finger tips? Vinyl, CD's, and a Media Library?
Adding to what face said, fiddling through your music library is as mundane as changing a CD or flipping your LP..
