CD Players
VR3
VR3 Posts: 29,385
edited November 2011 in 2 Channel Audio
I would like to preface I will ignore any suggestions involving an IPOD, Squeezebox, etc - I do not want it for serious listening, period. I just dont feel it is me.
Now that I got that out of the way - WOOO
Like my amplifiers I am going to most likely downsize here as well...
I would like to keep my budget at around 1k -
I like to buy my sources new, however; I am willing to adventure into the used market of course on a newer model...
This is where my experience is more limited and I do not know of many brands...
My Symphonic Line player is pretty much just amazing - it will be impossible to top and I really dont know if I can part with it but I will try. This one I will buy the player up front to a/b them and if it is close I could see selling my Symphonic Line - hence why new with 30 day trials is a good way to go...
So I am just looking for suggestions if any...
Thanks in advance!
Post edited by VR3 on
  • mantis
    mantis Posts: 17,313
    Look no further then a Cambridge Audio Azur 840c. I have compared it to many others including higher end models and nothing I feel is a better player for under 3000.00 even then and above I don't see anything blowing it away.
    As far as your budget , used would score one new you need to save a few more pennies.
    Good luck hope this helps.
    Dan
    VR3 Posts: 29,385
    I will have to put it on the list...
    The Klarheit II sells brand new for $4,000 and is said to be as close to vinyl as it gets... I like to call it a musical Wadia.
    So I am keeping an open mind, this is for sure! :)
    Thanks!
    VR3 Posts: 29,385
    Amazon is actually selling for 1k shipped! Hmmmmm
  • Paden501
    Paden501 Posts: 286
    A Jolida JD100 would fit into your budget nicely. It's got a tubed output stage, which is nice to have if you're not using it strictly as a transport.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • Face
    Face Posts: 14,340
    1K will buy a real nice DAC.
    VR3 Posts: 29,385
    And do what with the dac??? ;)
    Players I have heard in the past that did not do much for me -
    Rega Apollo (Very flat and 2-d sounding)
    A Denon SACD player, not sure of the exact model (just no comparison)
    A high end Wadia (Very dark and analytical, a little to dry for me, but an incredible sounding player)
    Players I have had before
    Shanling CDT100 (really really liked the straight solid state outs, not the tube buffered out)
    Onix XCD 88
    I have heard the Jolida CD player at several Polk fest and I am not a fan of tubes all over the place, a tube pre seems to be just right for me! :)
  • pearsall001
    pearsall001 Posts: 5,222
    They still make CD players???? Big step backwards...huge! :neutral:
  • inspiredsports
    inspiredsports Posts: 5,502
    Musical Fidelity A1 CD Pro
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • dkg999
    dkg999 Posts: 5,647
    The CA 840 CDP is very nice sounding, a big step up from the sound of their other CDP's. IMHO buy the cheapest CD spinner you can find that outputs a solid bitstream and put your money into a good DAC. That will give you the most flexibility.
    DKG999
    VR3 Posts: 29,385
    dkg999 wrote: »
    That is interesting, so what would be a good DAC? And what would you use for a source?
  • dkg999
    dkg999 Posts: 5,647
    As you mentioned you don't want more tubes in your system, I would suggest a used CA CDP as a transport and a used PS Audio DLIII DAC. There are mods available for the PS Audio DAC, if you so desire. The Music Hall 25.3 has mods available and uses SS for the balanced outputs. Others here are far more knowledgeable than I on DAC's. I own the PS Audio and the Music Hall and enjoy them both.
    I also own the Jolida CDP and the Rotel 1072 CDP's as points of reference. Either DAC I referenced will significantly improve the Jolida SS output or the Rotel CDP output. I have very good tubes in my Jolida and it will just slightly better either of these DAC's.
    DKG999
    VR3 Posts: 29,385
    Very interesting.... Hmmm
    That gives me a good bit to think about!
  • marvda1
    marvda1 Posts: 4,935
    here's a great sounding cdp ( i own one) virtue audio piano m1
    http://www.audiocircle.com/index.php?topic=99870.msg1014199;topicseen#new
    i think may still have a couple of new ones so you can configure them like you want, but this used one is a great deal.
    Puritan PSM156
    heiney9 Posts: 25,396
    Hook it up to a Squeezebox :cheesygrin:
    I am curious why it's not "you"? Are you adverse to convenience? Or are you just being an audio snob? I was that way until I actually used one, not anymore.
    Just busting your balls a little bit, but I am still curious what it is about the SQB you don't like.
    Sorry I can't be of much help since I gave up that archaic cdp machine quite awhile ago :lol:
    VR3 Posts: 29,385
    I honestly like flipping through CDs - I like being "forced" to listen to an entire CD if I so desire... I dont know, it is part of my experience.
    Having my entire collection at my finger tips would make it feel a tad disposable to me.
  • EDUBAG
    EDUBAG Posts: 403
    If you get a good dac, music hall, musical fidelity, wyred4 sound, benchmark, etc you can get a pretty basic cd player as transport and have the flexibility of adding your computer, or whatever fancies you in the future.
    I run my oppo dv980 h as cd player and love it, but according to stereophile it really shines as a transport, you can look it up. I paid 80 bucks for mine to a member of the club, so that would leave you with 900 from your budget to buy a dac that will better any 1000 cd player.
    Good luck,
    Eduardo
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • Paden501
    Paden501 Posts: 286
    I agree with you on this point. Sometimes I like a digital source because my entire collection is at my fingertips, but sometimes I feel like I get lost in all that. Putting in a CD or LP and just letting it play out can be really enjoyable. I don't have the urge to 'search' for the next song, playlist, genre, etc instead of just listening like I should be.
    ~Matt
    My System
    CD: Jolida JD100a
    TV: Sony 52" XBR9
  • steveinaz
    steveinaz Posts: 19,545
    Don't overlook Rotel--under appreciated, but very respectable in the bracket you're looking at. The Cambridge is solid as well, and has the benefit of additional DAC inputs. Used Arcam/Musical Fidelity are always a good choice, too.
    A cd is a digital source. I get where you guys are coming from, I WAS the exact the same way and you can still hit play and listen to an entire cd uninterupted, but the other convenience factors are off the charts so I am no longer that way.
    Not trying to take this off topic, so that will be my last comment on the subject of not using a cdp.
    Good luck with your search Trey
  • steveinaz
    Some people like to "fiddle" that's part of the big charm of turntables, I "get" it.
    steveinaz wrote: »
    I can respect that and why I asked the question. I'm sure there are people that don't understand my fascination with tube rolling, that's "fiddling" around all the time :lol:
    The "fiddling" part of vinyl is why I have never gotten back into it. The "ritual" as some call it, would drive me nuts! :cheesygrin:
  • falconcry72
    falconcry72 Posts: 3,580
    I will echo other's comments about getting a decent transport and an external DAC.
    This way, you can upgrade either component individually at a later time. Plus a good external DAC will sound better than a CD player in the same price range. All DAC's sound different though, so you've got some research to do.
  • Face
    Face Posts: 14,340
    Changing CD's is as mundane as flipping a record.
  • Paden501
    Paden501 Posts: 286
    heiney9 wrote: »
    Yeah I guess my last post was a bit of a misnomer because a CD is 'digital'... but it's also 'physical', whereas computer cataloged digital sources are not.
    Don't get me wrong, I have and use both personally, and each has its ups and downs. Which I prefer has as much to do with my mood on that day as anything.
    To Trey, I also agree with the last couple comments. I think what you're really looking for here is a DAC. I mean a CDP is really just a transport and a DAC in a single box, and a lot of the better CDPs use the same Phillips style transports anyway, so what you're really hearing is the difference in DAC between different players, and some differences in their output stages (especially for a tubed player).
    If you use the bitstream output on a decent transport CDP, and a good DAC of your liking, you may get where you want to go more easilly. It'll also be easier to change the sound of your system later by just changing the DAC alone.
    I'm really interested in seeing where you end up going with this because I'm getting more interested in fooling with DACs myself also.
    ~Matt
    My System
    CD: Jolida JD100a
    TV: Sony 52" XBR9
  • RickTfromAZ
    RickTfromAZ Posts: 122
    You may want to look at the Sony SCD-XA5400ES. Very highly rated. I believe that it can be had new for around $1000.00 on Agon.
    pitdogg2 Posts: 26,927
    listen to an Ayre cd player
  • steveinaz
    Ayre is extremely nice, but $$$$$$$$$
  • BlueFox
    BlueFox Posts: 15,251
    Face wrote: »
    Which is why some put the digital CD files on another storage media, and then listen to a play list of CDs, or random shuffle through the CDs, or random shuffle through all the songs on all the CDs. Some of these playback systems let you use an iPhone, iPad, Android phone, or tablet to remotely select CDs, songs, create play lists, etc. Or you can use a web browser instead to manage the music. Basically, everything you cannot do with a CD player.
  • Face
    Face Posts: 14,340
    Yep, I use my Droid 3 to control my music library via J. River(Gizmo app).
    Toolfan66 Posts: 17,982
    Why not have all of it at your finger tips? Vinyl, CD's, and a Media Library?
    Adding to what face said, fiddling through your music library is as mundane as changing a CD or flipping your LP..
