binding post cup on sda
TrashyTrucker
TrashyTrucker Posts: 225
edited November 2011 in DIY, Mods & Tweaks
Here is a pic of what I am needing help with.
I plan to do the cardas binding post's upgrades. However, I wish to purchase a new cup (if that is the name) to start over with. I plan to use 5 post per cup. the 5th one will be used for the sda interconnect. I will no longer use the stock pin-blade connect which is 18 ga. Upgrade will be two 14ga combined.
Does anyone know which cups will interchange with the sda srs 3.1 TL's cup?
Desire a different one which can be modified to accept the 5th post. I plan not not using the present cup.
thanks,
Matt:mrgreen:
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Post edited by TrashyTrucker on
    Toolfan66 Posts: 18,127
    Why not use the BPC you have?? I have modded all my SDA's this way. To answer your question the 2.3's 1.2's tl versions as well use the same cup. you can also use any of the cups all you have to do is mod them as well..
    If you find my 1.2tl/1C/CRS+ upgrade threads you can see how I modded them to put in the 5th binding post for the SDA cable. I used a piece of delrin to give it more stability but you can use a piece of lexan from any hardware store..
    Be sure to keep the white wire jumper on the back side of the BPC on the negitive side just in case you use an AI-1 DreadNought SDA cable..
  • gimpod
    gimpod Posts: 1,793
    TOOLFORLIFEFAN ever think of running off a bunch of those delrin or lexan plates pre-drilled and ready to go for sale. ?
    I know, I know, One more thing to do for us that you most likely don't have time for.
  • TrashyTrucker
    Thanks Larry... That is an option, however if I can get my hands on another cup... perhaps I will have the orig. cable and BPC to go with it? just a thought.
    Rotel RCD 1520 cdp
    biamped to:
  • TrashyTrucker
    I plan to order these... no affiliation.http://www.soniccraft.com/products/connections/bindingpost/cardas_ccgr.htm
    edit: I plan to upgrade the BP on the amplifier's as well
    Rotel RCD 1520 cdp
    biamped to:
  • zingo
    zingo Posts: 11,258
    gimpod wrote: »
    This is what I did with my custom Klipsch Forte speakers. I had a lexan plate cut to the same size and thickness of the original cup, then drilled for the banana posts. It's an easy and cheap tweak that allows you to completely customize the back of your speakers while providing a completely custom look. The picture below will give you an idea, however, I've put better binding posts and a new gasket on since that picture.
  • gimpod
    gimpod Posts: 1,793
    This is what I'm talking about. My SDA CRS Upgrade Thread Post #3. The 1/4" thick delrin plate for the back of the binding post cups.
  • TrashyTrucker
    gimpod wrote: »
    Thanks gimpod! Btw... How did tool like those duelands in those custom boards you all made? Happy Thanksgiving to all!
    Matt:mrgreen:
    Rotel RCD 1520 cdp
    biamped to:
