Monitor 7c upgrades
TrashyTrucker
Hey all,
purchased some m 7c's locally and ordered rdo 194's and placed an order to sonic craft. Parts include: 2-2.2 ohm mills. 2-12 mf and 4-17mf sonic caps
Pulled the polly's and replaced with jumpers. Original high pass had 2 ohm resistor and polly switch. I jumped the polly and instead of adding a .5 ohm, I increased the 2 ohm to a 2.2 ohm. The seller had made an attempt to upgrade the speakers before I purchased them. However, they were too dull to my liking and lacked sparkle and detail. It will take 48 hrs to burn in the tweeters and a total of at least 100 hrs to burn in xo. I will let you all know. I will leave them on for one week.
Thanks for reading,
Matt
Thanks for reading,
Matt
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Rotel RCD 1520 cdp
biamped to:
Post edited by TrashyTrucker on
Looks great Matt-
I'm about ready to do my 7's. Have Solens for the low pass and will order either SonicCaps or Clarity Caps for the tweets as well as Mills resistors. Mine still have the fuse on back so I'll prob leave that alone. I have a set of rings from Larry and need to build a decent set of stands. Looking forward to your listening impressions.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
Looks Great!!!
Looks great Matt-
Thanks! They really opened up since the polly's were removed.TOOLFORLIFEFAN wrote: »Looks Great!!!
Thanks Larry! would be interested in perhaps a set of rings for these? I have been out of the loop for a while, so I prob am not up to speed on the procedure in placing orders?:eek: LOL,Or perhaps add me to the next round then! please pm back with details etc. etc.
regards matt
Rotel RCD 1520 cdp
biamped to:
...SDA's are just like candy for your ears... -
Forgot to mention:
Have reversed polarity or phase of one speaker intentionally. As not to bother the neighbor's as bad. This cancels out one another. (but should not be used in critical listening!) Only for burn in purposes.
I also plan to place each speaker facing one another approx 6" apart. I then will cover them with three blankets to further dampen sound of the highs. And then just wait for these little eggs to emerge!LOL
Thanks CP for making this insane hobby... I mean passion more fruitful!
regards,
Matt
Rotel RCD 1520 cdp
biamped to:
How do you like the sound so far?
Day 6 of running fm stereo signal through the xo's. I found out this was a very rewarding investment. They definately opened up (possible due to the pollys removel) more, however no more brash sounding highs. More clarity and sonics, the bass seems tighter.
Thanks for looking,
Matt
Rotel RCD 1520 cdp
biamped to:
I love my Monitor 7's. Glad to hear that you're enjoying yours. PM me - I'm in the St Louis area too.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
HTguru1982 wrote: »I love my Monitor 7's. Glad to hear that you're enjoying yours. PM me - I'm in the St Louis area too.
Cool! I am not on here much anymore during the weekdays
. Pleased to meet a fellow Polkie neighbor! We should schedule those in our area to make a Polkfest? Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
In my experience the full burn in w/ Sonicaps/mills takes around 200-300 hours. Most of the improvement occurred at a little over 100 hours.
Good work there!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »In my experience the full burn in w/ Sonicaps/mills takes around 200-300 hours. Most of the improvement occurred at a little over 100 hours.
Good work there!
Was interesting you made that observation... I purposely wired the speakers out of phase and threw like 3 blankets to dampen the sound of the highs. To my surprise, two days into the burn in... I took a peek inside and found out it was too warm in there! (no damage... Magnet slippage etc. etc.) I then replaced with only 1 blanket!
It is now 8 days into burn in. They are a part of my garage rig now.
Day 8 and now in correct phase:
The highs are crisper and in much richer detail as in before. It makes the transition between the two much more seemless.
The lows (mid woofer) moves air as with the electrolytic cap. But now has a much tighter response and as aforementioned on the highs, has more accurate detailed bass. Not "boomy" or "flabby" as before upgrade.
I do agree much more burn in time is needed as with any upgrade.
Final conclusion: If you have a pair of 7's around...invest about $268.00 in rdo's and sonicaps and mills, You will be impressed enough to put 25+ year old speakers up againts side by side in todays generation of speakers with similar specs. IMHO This upgrade in no way is suptle. This was a fun project, thanks for looking.
regards,
Matt
Rotel RCD 1520 cdp
biamped to:
