Monitor 7c upgrades
TrashyTrucker
TrashyTrucker Posts: 225
edited November 2011 in DIY, Mods & Tweaks
Hey all,
purchased some m 7c's locally and ordered rdo 194's and placed an order to sonic craft. Parts include: 2-2.2 ohm mills. 2-12 mf and 4-17mf sonic caps
Pulled the polly's and replaced with jumpers. Original high pass had 2 ohm resistor and polly switch. I jumped the polly and instead of adding a .5 ohm, I increased the 2 ohm to a 2.2 ohm. The seller had made an attempt to upgrade the speakers before I purchased them. However, they were too dull to my liking and lacked sparkle and detail. It will take 48 hrs to burn in the tweeters and a total of at least 100 hrs to burn in xo. I will let you all know. I will leave them on for one week.
Thanks for reading,
Matt:mrgreen:
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Post edited by TrashyTrucker on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Looks great Matt-
    I'm about ready to do my 7's. Have Solens for the low pass and will order either SonicCaps or Clarity Caps for the tweets as well as Mills resistors. Mine still have the fuse on back so I'll prob leave that alone. I have a set of rings from Larry and need to build a decent set of stands. Looking forward to your listening impressions.
    Toolfan66 Posts: 18,198
    Looks Great!!!
  • TrashyTrucker
    TNHNDYMAN wrote: »
    Looks great Matt-
    Thanks! They really opened up since the polly's were removed.
    Looks Great!!!
    Thanks Larry! would be interested in perhaps a set of rings for these? I have been out of the loop for a while, so I prob am not up to speed on the procedure in placing orders?:eek: LOL,Or perhaps add me to the next round then! please pm back with details etc. etc.
    regards matt:mrgreen:
    Rotel RCD 1520 cdp
    biamped to:
  • TrashyTrucker
    Forgot to mention:
    Have reversed polarity or phase of one speaker intentionally. As not to bother the neighbor's as bad. This cancels out one another. (but should not be used in critical listening!) Only for burn in purposes.
    I also plan to place each speaker facing one another approx 6" apart. I then will cover them with three blankets to further dampen sound of the highs. And then just wait for these little eggs to emerge!LOL
    Thanks CP for making this insane hobby... I mean passion more fruitful! :lol:
    regards,
    Matt :mrgreen:
    Rotel RCD 1520 cdp
    biamped to:
  • saemark30
    saemark30 Posts: 146
    How do you like the sound so far?
  • TrashyTrucker
    Day 6 of running fm stereo signal through the xo's. I found out this was a very rewarding investment. They definately opened up (possible due to the pollys removel) more, however no more brash sounding highs. More clarity and sonics, the bass seems tighter.
    Thanks for looking,
    Matt :mrgreen:
    Rotel RCD 1520 cdp
    biamped to:
  • HTguru1982
    HTguru1982 Posts: 1,066
    I love my Monitor 7's. Glad to hear that you're enjoying yours. PM me - I'm in the St Louis area too.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • TrashyTrucker
    HTguru1982 wrote: »
    Cool! I am not on here much anymore during the weekdays :neutral:. Pleased to meet a fellow Polkie neighbor! We should schedule those in our area to make a Polkfest?
    Rotel RCD 1520 cdp
    biamped to:
  • drumminman
    drumminman Posts: 3,396
    In my experience the full burn in w/ Sonicaps/mills takes around 200-300 hours. Most of the improvement occurred at a little over 100 hours.
    Good work there!
  • TrashyTrucker
    drumminman wrote: »
    Good work there!
    Was interesting you made that observation... I purposely wired the speakers out of phase and threw like 3 blankets to dampen the sound of the highs. To my surprise, two days into the burn in... I took a peek inside and found out it was too warm in there! (no damage... Magnet slippage etc. etc.) I then replaced with only 1 blanket!
    It is now 8 days into burn in. They are a part of my garage rig now.
    Day 8 and now in correct phase:
    The highs are crisper and in much richer detail as in before. It makes the transition between the two much more seemless.
    The lows (mid woofer) moves air as with the electrolytic cap. But now has a much tighter response and as aforementioned on the highs, has more accurate detailed bass. Not "boomy" or "flabby" as before upgrade.
    I do agree much more burn in time is needed as with any upgrade.
    Final conclusion: If you have a pair of 7's around...invest about $268.00 in rdo's and sonicaps and mills, You will be impressed enough to put 25+ year old speakers up againts side by side in todays generation of speakers with similar specs. IMHO This upgrade in no way is suptle. This was a fun project, thanks for looking.
    regards,
    Matt:mrgreen:
    Rotel RCD 1520 cdp
    biamped to:
