Pro Amps for home use!
  • 20hz
    20hz Posts: 636
    edited October 2011
    has any body heard any of the d-class amps on home subs ???
    for example the peavey ipr 1600 or the behringer inuke 1000 .
    I am driving four 12's I need 200 watts for each 12" , I appreciate any sugestions .
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    I guess a pro amp would be good to run a butt kicker or bass shaker.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • TroyD
    TroyD Posts: 13,124
    edited October 2011
    pietro944 wrote: »
    Trust your ears,not your eyes......The Dac,pre-amp and/or Tube Buffer is 95% of Sound Quality,not the amp:eek:
    Do you really think we don't?
    BDT
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    20hz wrote: »
    I used a Peavey class D for a long time with subs. It worked real well. Lots of power and dynamics. Never ran out of steam. Was a bit noisy though with the cooling fans.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited October 2011
    Joe08867 wrote: »
    I ordered quieter fans for my QSC when I was running it. Made an unbelievable difference. The lights were the only thing that indicated it was on because it was so quiet.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2011
    TroyD wrote: »
    BDT
    We need to be educated?????
    95%???, yea right, sure it is, even then it would be totally lossy sounding, kinda like getting 95% lucky, almost, but you just never quite get there and leaving totally frustrated as the final result.
    RT1
    heiney9 Posts: 25,498
    edited October 2011
    pietro944 wrote: »
    Pure B.S.
    Everything matters.................period.
    Pro amps stink for home use if your goal is high fidelity. They just don't cut it, period.
    P.s. That certainly doesn't mean those of you that use them can't enjoy them. But those of you who continue to assert they are every bit as good as a well designed "home" amp are kind of clueless. As well as those of you who think the amp doesn't matter. We all have a different audio path, that 's alright. But you will never convince a race car driver a Hyundai is the same as a Ferrari..............because it's not.
  • pietro944
    pietro944 Posts: 720
    edited October 2011
    TroyD wrote: »
    BDT
    Who is "we"?......My reply was to the thread starter,not to get into a dick-size argument.
  • pietro944
    edited October 2011
    heiney9 wrote: »
    Pure B.S.
    Pure snake-oil...beyond B.S.....comparing car engines to home amplifiers....what are we,simpletons?
    Back in the 60's,Julian Hirsch of Audio and Stereo Review fame, espoused the same reasoned argument about cables and amplifiers,as I am......The "purists" tried to burn him at the stake....It didn't work with him....and it won't work with me,either.......To the newbies:put your money in the important things.Buy an inexpensive,well-made,well-built amp.....PERIOD!
  • halo71
    halo71 Posts: 4,638
    edited October 2011
    Define that, give some examples please. "Of an expensive, well-made, well-built amp." Because I can tell you for sure that I can damn sure tell a difference between my old trusty Peavey rack amp (guitar rig) and my vintage Onkyo Integra M504. And that is on any of the 12 pairs of speakers I own. Running the same pre, cd/dvd etc.....just changing out amps.
    --Gary--
  • Face
    Face Posts: 14,340
    edited October 2011
    pietro944 wrote: »
    Compare a high quality amp from the 60's to one built today, there wont be a comparison. What was considered high quality then, and even the 70's, is highly colored in comparison to even a 10 year old Adcom.
  • reeltrouble1
    edited October 2011
    Cheap pro gear sounds exactly like that to me for 2ch stereo.... I use a pro amp in the studio with a pro mixer and generic CD player along with a laptop, makes recorded music sound flat, dull and so on, I would never use it for any sort of serious musical 2-ch listening enjoyment, the gear is just not meant to be used with hi-fi speakers, the noise floor is certainly an issue, works as intended for playing electronic instruments.
    If I hooked the amp to the Sound Labs the inexpensive electronic parts would smoke and die.
    Seems as if this pro gear issue comes along a couple times each year....generally pretty much the same comments, not much left to say, if someone digs it then go for it, however, you can expect some push back from others should you choose to expound its sound to those who have moved far beyond. We all started somewhere though, oh, and I am pretty sure 100% of the membership relies upon their ears to hear music....
    RT1
    nooshinjohn Posts: 26,001
    edited October 2011
    pietro944 wrote: »
    First you say this, the you go here....
    pietro944 wrote: »
    Looks to me like you are throwing all your cards on the table here and looking to start an argument for sure. If it does turn into "dick-sized" argument, I would be careful because your line of thought is rather small.
  • pietro944
    edited October 2011
    To the thread starter.....For efficient 8 ohm speakers,a pro-amp or any high-powered,high current amp is overkill for 2 ch sound.For inefficient 4 ohm speakers with a Crown or QSC power amp,the results will be spectacular.
    To others......Have a nice day!:smile:
  • reeltrouble1
    edited October 2011
    well the dicking contest seems complete.....pietro doesn't even show, your also trolling for your agenda....have a nice night though.
    RT1
    Toolfan66 Posts: 18,187
    edited October 2011
    pietro944 wrote: »
    So you pass on snake oil but drink the koolaid??
    F1nut Posts: 52,002
    edited October 2011
    pietro944 wrote: »
    In all the years I've been in audio, that is the absolute worst advice I've heard.
  • TroyD
    TroyD Posts: 13,124
    edited October 2011
    another idiot for the bozo list.....
    I mean, really. I don't care what you listen to, I really don't. However, I've heard enough amplifiers that I have no vested interest in to conclude that, to my ears, they sound better/different. I chose not to use certain products because I don't like them. Bully for you if you do, however, who is to say that your opinion is any more enlightened than mine?
    BDT
  • nguyendot
    nguyendot Posts: 3,594
    edited November 2011
    Where did the train of thought come from that amps are only 5% of the equation?
    Main Surround -
  • organ
    organ Posts: 4,969
    20hz,
    I used a pair of 200w mono blocks Class D to power a pair of 12" subs at one point. Never felt the need for more power.
    I also used them to power a pair of Maggies MG-12QR, Mirage M-3si and a few others. Sounded great on all those speakers.
    But of course, there are good and bad Class D out there just like any other design. Hope this helps.
  • agfrost
    agfrost Posts: 2,474
    nguyendot wrote: »
    I thought it sounded familiar, so I looked in my handy Chemical Rubber Company Handbook of Chemistry and Physics and found the pertinent equation:
    Jay
