MIT Shotgun S3 speaker cables or interconnects first?
    heiney9 Posts: 25,498
    edited October 2011
    At minimum don't coil speaker cables and try and keep power cables and signal cables crossing each other at 90*, that takes care of most of the issues.
    Toolfan66 Posts: 18,187
    edited October 2011
    heiney9 wrote: »
    That can be a task with upgraded power cables and IC's as they are stiffer then the cheaper stuff..
    edited October 2011
    I hear ya!!! At worst you don't want all you cables laying parallel to each other. Just try an mix 'em up so they aren't all 100% parallel. Even 45* criss cross is better than parallel. Again you just have work within the space given and the type of cable given. I would imagine (this is a logical guess) as you move up to better cables it becomes less of an issue as I'm sure the shielding and sheathing is incorporated into the design to minimize the effects of wires running in close proximity to each other. Although I still always try to isolate power from signal cables.
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    This is good knowledge. I'm glad the topic came up. I'm in the process of sourcing out dedicated circuits for my system since it shares the same circuit as my entire main floor and kitchen... I'm amazed it hasn't popped. However, in addition to that, it will allow me to re-connect my entire system. And with this knowledge, I can implement this knowledge when I do that.
    I'm wonder how much noise is in my line. So much to do... so much to buy and add...
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2012
    Joe is great to work with. Just bought some S3 8 footers. Hope that I can figure out how to make them work seeing my amps are pretty close to the speakers.
    Just wish MIT would do shorter runs. oh well can't complain about the deal at all!
  • michael1947
    michael1947 Posts: 775
    edited March 2012
    You fellas got any photos of your 2 channel rigs and your cable lay outs: and Chris how is that new rig coming along...what with all of those tubes?
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2012
    cstmar01 wrote: »
    ...Hope that I can figure out how to make them work seeing my amps are pretty close to the speakers. Just wish MIT would do shorter runs....
    I'll tell ya, the cables are so thick, they really "act" like shorter cables. If you think you need 6's, you'll be glad you got 8's. If you think you need 8's, get 10's. They have minds of their own...
