New Polk Speaker setup looking for receiver suggestions
Devilray427
Devilray427 Posts: 5
edited September 2011 in Speakers
Hi all,
I'm looking for a receiver in the 2-3 hundred dollar range to power my new setup any suggestions?? any other setup suggestions is greatly appreciated as I am new to this.
first real HT setup as follows:
2-polk monitor 30
2-polk monitor 40
1-CS1
1-PSW 505 sub
Post edited by Devilray427 on
  • Demiurge
    Demiurge Posts: 10,874
    Is that a firm budget? You're really at entry level at that price, not that you can't find a receiver to get the job done.
  • Demiurge
    Actually, check this one out in the Flea Market:
    http://www.polkaudio.com/forums/showthread.php?t=124127
    I know you're new, but perhaps you could make a deal with the seller (no affiliation). That's a good price for a nice receiver.
  • Libertyc
    Libertyc Posts: 915
    check out Harman Kardon refurbs on ebay.
    http://myworld.ebay.com/harmanaudio/
  • Devilray427
    What do you guys think of a pioneer elite vsx-31 with my current setup? 299$
  • Demiurge
    I have a higher end pioneer in my system and I love it. I can't comment on that specific model, though.
  • thesurfer
    thesurfer Posts: 574
    Go with H/K, not only do i use one, but its probally the most recomended on this forum, they have great high current clean power,
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
  • Devilray427
    Recommendations on a H/K model?
  • thesurfer
    H/K 3490, is a solid choice,
  • codyc1ark
    codyc1ark Posts: 2,539
    Do you need 3D? If you don't, I'd look for a Pio SC-05/07. You'll have to stretch your budget some, but it will be worth it. I wouldn't buy anything without pre-out connections. IMO, the receivers with pre-outs usually point to better overall build quality. Good luck, your on your way to a nice setup.
    Welcome to CP!
  • Libertyc
    Libertyc Posts: 915
    The HK 3490 is 2-channel.
  • thesurfer
    Libertyc wrote: »
    Well, thats what im into, But your right, that wont serve the purpose,, Ill find one,
  • falconcry72
    falconcry72 Posts: 3,580
    thesurfer wrote: »
    That's not true at all.
    The most recommended is without a doubt the Pioneer SC series of Elite receivers.
    And, as mentioned before, you're suggesting a 2-channel receiver to someone who's obviously looking for surround sound ala 5.1
    I know we all like to increase our post counts, but unless you have something beneficial to say, it might be best to not make noise.
    I'm not trying to be a dick, but I see patterns when they appear, and I'm looking out for dudes like the OP here, by protecting him from dudes like you.
  • thesurfer
    Dudes like me??? Ive got more than enough posts, So i made a mistake, on the model, check how many post i put up a day,, Im in no way trying to boost my post #,s Plus, Its non of your buisness what, when, or what i post, If you read the post, there asking about a good H/K model, Instead of giving me crap, put your know how into the question, H/K makes very nice high end recievers,, I know for a fact they outsell pioneer,,
  • falconcry72
    thesurfer wrote: »
    Like I said, I'm not trying to be a dick; I generally like people.:smile:
    And no, the OP was not asking about HK.
    Whether or not HK outsells Pio has nothing to do with quality or with your statement that HK receivers are the most recommended on this site. They aren't. Period.
    The point here is that you should use phrases like "maybe" or "probably" or "I'm not sure, there may be better answers" instead of blatantly stating that your preference is fact.
    Again, I'm not trying to be a dick, I just don't like seeing people who are new to the hobby being led astray by brazen ineptitude.:wink:
  • thesurfer
    To be honest Falcon, I said, there probally, the most recomended, so you need to read what i wrote, Also, i dont believe you have the right to tell anyone what they should post, or how to phrase it, And ive never tried to lead anyone astray,, You seem to have something agaisnt H/K gear, thats fine, MY op, means as much as yours, and i believe you cant go wrong with H/K gear, Pease read my post, before you disect them, Its nothing personal, but pioneer isnt all that, and a bag of chips, and yes, H/K gear is some of the best High end gear you can buy for the money, look into it, if im wrong, PM me and let me know, as this is not our personal debate thread,,
  • falconcry72
    thesurfer wrote: »
    I have the right to tell anyone anything at any time, but that doesn't mean that you have to listen to me.
    I have nothing against HK. I also have nothing for Pioneer.
    I don't want to fight anymore; I just want to be friends, but if we're going to be friends, you're going to have to learn to use a period from time to time.:wink:
  • thesurfer
    Yes, i do agree...... There, i threw a few extras in, for a friend.
  • codyc1ark
    This would be a great choice, you may have to add a bill to your budget...
  • thesurfer
    Or, H/K 635??? its a nice one,
  • rebuy
    rebuy Posts: 694
    Devilray has monitor speakers and a small budget for a receiver. I was in that same situation too less than 2 months ago. So I'm gonna recommend an Onkyo to Devilray.
    They should make his monitors sound pretty good and Onkyo has better power numbers than cheaper equipment from other makers. We all know we need preouts but like me, some people don't have the coin to get that stuff. So we need to get the best bang for our buck. Get an Onkyo, it's so easy the wife can use it.
    You can get them from shop Onkyo on the net. You can also find refurbs for cheap too.
    I do recommend that you do your home work before a model.
    A bought a 608 from last year for around 200 and it has been fine, however, some of the other models from that year had serious problems. see if you can find a TX-sr 608 they seem to be ok and you can get one cheap.
  • thesurfer
    rebuy wrote: »
    You say, problems with that line, ??? ONkyo that is,
  • rebuy
    rebuy Posts: 694
    yes, if you look at shop onkyo web site you'll find that some models had recall notices or service bulletins. The 608 was not on the list. I think the 708 and the 508 are on the list and a few more.
  • mantis
    mantis Posts: 17,561
    I think this is the best choice if you can get it at this price. Thats well under retail.
    Dan
  • Devilray427
    I know i'm new to the HT world, and the Polk forums. Just wanted to say really appreciate all your help, you guys have a great community here. On par with EVGA forums and wasn't at all expecting this great response. Thanks again.
  • Devilray427
    struggling btw a refurb Onkyo and the pioneer elite vsx-31 both 299
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Well I just noticed Walmart has that pioneer so you may want to take advantage of the return policy they have and give it a whirl :smile:
  • UnKAndroiD
    UnKAndroiD Posts: 9
    I also am new to the site and looking for help/insight/recommendations for what I plan to have as my set up. I know this is a budget set up, but just want something simple and effective for my girlfriend and I to use. I already have 2 Monitor 30 Bookshelf speakers but I plan to get:
    2 Monitor 50 Floor Speakers
    1 CS1 Center Channel
    1 Pioneer VSX-520-K
    Will this all work? From the research I have done I think it should but like I said I am pretty novice at these things. Any suggestions would be great.
    Thanks,
    Mo
  • polkfarmboy
    UnKAndroiD wrote: »
    1 Pioneer VSX-520-K
    Thanks,
    Mo
    Post a new thread bud and we will all be glad to help in what ever way we can:smile:
  • UnKAndroiD
    UnKAndroiD Posts: 9
    Sorry, I wasn't sure how this forum worked. Appreciate letting me know tho.
