To tl SDA 2B or not?
muncybob
muncybob Posts: 3,235
edited September 2011 in Vintage Speakers
I'm definatley going to have my crossovers updated. My 2b's have had the RDO 194 tweeters in them for a few years now and initially I was ging to keep them and have the crossovers worked on and install binding posts(along with Larrys rings, JB weld and spikes). I had not really thought about going tl until an interesteding offer involving a tl'd crossover was made to me. So, perhaps I will sell the 194's, pick up the 198's& related crossover and go tl.....but, what makes going tl favorable to just modding the crossovers and sticking with the 194's?
Yep, my name really is Bob.
Post edited by muncybob on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    The RDO194 is a good tweeter, the RDO198 is even better.
    SDA SRS 2.3TL's
    SDA 2B TL's
    heiney9 Posts: 25,412
    muncybob wrote: »
    Personally I think the TL mod is a bit overated. The 194's and 198's are very similar tweeters. That said if you can TL it for close to same cost then there really is no down side.
    You should easily get 80-85% of what you paid for the 194's and there are only a few extra parts to buy for the x-over. Maybe you'll have an extra $20-30 over what you'd pay for a non-TL version.
    I don't see how you could go wrong. If you had to take a larger loss on selling the 194's to replace them with the 198's I'd say probably not worth it, but since that's not the case here.
    There are going to be some that chime in and say there is a huge difference, to me adding an extra cap and using the same basic tweeter design and material isn't going to make the TL some kind of ephiphony modification vs. non-TL.
    YMMV
    muncybob wrote: »
    They are the same tweeter with slightly different electrical properties.
  • inspiredsports
    inspiredsports Posts: 5,502
    While RDO194's and RDO198's might be "very similar tweeters" with only "slightly different electrical properties", I strongly disagree that the sound quality improvement is overrated.
    You can update the cabinets incrementally (trying the 194's first, and then adding the 5.8uf bypass and 198 at a later date) but in my opinion that's wasting time, money and energy to reach a conclusion many dozens of others have reached: ie. the TL (198) mod is an order of magnitude better.
    Don't forget TFL rings, spikes and an SDA interconnect cable upgrade.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Face
    Face Posts: 14,340
    Sounds like someone has tweeter envy. :)
    The OP could update incrementally, trying the 194' first, and then adding the 5.8uf bypass and 198 at a later date, but in my opinion that's wasting time, money and energy to get to a point dozens of others have reached: ie. the TL mod is an order of magnitude better.
    That's why I strongly suggested he just do the TL mod, since it's not a huge amount of extra $$$ or time involved.
    Face wrote: »
    Not at all, if I was convinced the 198 was some sort of second coming as some seem to state, I'd be out looking for a pair of SDA's (spending a lot more than I did for my current SDA's) that are currently TL'd or had that option.
    I don't doubt for a second there are difference's but some people on here make it sound the 194's are just poo compared to the 198's..........I don't see it since Polk said it's the same tweeter with sightly different electrical properties. Perhaps the 198's and it's electrical properties are a slightly better fit in some circuits than the 194's.
    I've never compared them side by side in the same exact speaker at the same exact time. If I were in his shoes, I'd go for the 198's and the TL just because the extra cost and time are so little
    In his case it's a no brainer and he can't loose even if there is a slight difference.
  • inspiredsports
    If the OP can't lose, why do the negative comments in post #3 even exist ?? :biggrin:
    NAD SS rigs w/mods
    GIK panels
    The same reason post #5 exists.........nice edits, btw. It's called a discussion.:wink:
  • Joe08867
    Joe08867 Posts: 3,919
    The TL mod is a must in my book. I have heard and still own both standard and TL'd 2b's and there is no comparison between the two. The TL mod opens up the sound-stage adds airiness and depth. The originals are an good speakers but the TL mod makes them a great speaker.
  • vstarkwell
    vstarkwell Posts: 328
    Sorry to interrupt this thread, but I was hoping to learn what is a TL mod? I read about them all the time here yet I still can't figure out what it actually is or does to the speakers.:confused:
    Monitor 7C's With Tubes
  • muncybob
    Well, as usual I wish I could do a side by side comparison. Appreciate the opinions.
    So, since tl discussion seems to evolve around the tweeters am I safe in assuming the tl mod would have no difference in mid and low end versus the non tl mod?
  • nspindel
    nspindel Posts: 5,343
    Certain crossover circuits allow for the use of the RD0-198 (SL3000 replacement) as opposed to stock use of RDO-194 (SL2000 replacement) if you add a 5.8uF cap into a pre-existing location in the crossover.
  • Joe08867
    The TL mod makes it possible to use the Ti-Laminate SL3000 tweeter or RD-0198 replacement with a speaker original designed for the SL2000.
    It can only be done on certain models of SDA's but is worth the costs involved.
    I suggest the mod to people who are looking to update there speakers anyway.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    I've had both tweeters. There was something special about the speakers before any modifications. But now, after months and months of letting all of the mods settle in, now I have a pair of speakers that I will never let go. Perform the TL mod and don't look back!
    Never mind
  • audiocr381ve
    heiney9 wrote: »
    Except you never compared the same model with and without the TL mod. You compared different model SDA's with slightly different modifications and you have what.............a couple months experience with SDA's in your entire life? :biggrin: 1/2 that time was without the mods. How much gear did you swap in and out and in and out those months??? Hardly a basis to form any kind of baseline for anyone to take you all that seriously as far as how good the TL 198 vs non-TL 194 is.
    I'm just sayin'.....................
    Calm down Kimosabe. I'll say it again to get through your thick head, I had 2B's unmodified with RD0-194's, then modified with RD0-198. I strongly prefer the RD0-198's with the mods, and that is all I bring to the table. I never implied more or less so relax, push up your glasses, and run more tests if you wish. That's just not me pal.
  • audiocr381ve
    heiney9 wrote: »
    Never mind
    Ahh, nvm.
  • falconcry72
    falconcry72 Posts: 3,580
    Joe08867 wrote: »
    ... I have heard and still own both standard and TL'd 2b's and there is no comparison between the two. The TL mod opens up the sound-stage adds airiness and depth. The originals are an good speakers but the TL mod makes them a great speaker.
    Does your original pair have upgraded cross-overs with the same quality of parts as your TL'd pair? If not, you're comparing a lot more than just tweeters, which isn't exactly fair.
  • falconcry72
    Yea, but you're comparing the 194's with stock crossover components to the 198's with upgraded crossover components, correct?
    That's not a fair comparison, and it doesn't help answer the OP's question, IMO. If he was deciding between TL'ing with high quality caps and resistors vs. not doing anything at all, then, of course, TL, but he's going to be upgrading the crossover components regardless.
    Like I said apples and kumquats.
    That's not a fair comparison, and it doesn't help answer the OP's question, IMO. If he was deciding between TL'ing with high quality caps and resistors vs. not doing anything at all, then, of course, TL.
    Yep, the entire point of my "never mind" post.
  • Joe08867
    The original speakers are upgraded with new caps, resistors and tweeters RD-0194 but no TL upgrade. All of my speakers have the same caps in them (Sonicaps) except the CRS+ I sold they had Clarity Caps.
    So it is a fair comparison. This winter the TL mod will be added to the other set.
  • audiocr381ve
    Correct, that's all I got. Maybe it's helpful maybe it's not, never implied any more or less :rolleyes:
  • falconcry72
    Joe08867 wrote: »
    Nice, it's cool to hear the comparison from someone who has heard both tweeters with the same caps and resistors. :smile:
  • Joe08867
    To the OP, no matter what you do to your speakers you owe it to yourself to update/upgrade the crossovers. It is truly night and day.
  • falconcry72
    I gotcha. I didn't mean to come off as a dick, if I did.:redface:
    You original post is extremely vague as you didn't disclose the specifics. I just wanted the OP to know that not everyone is always comparing apples to apples.
    The reason I deleted my post is because I'm not arguing against the OP doing the TL mod in this case, so I thought it best to just delete my post.
  • audiocr381ve
    heiney9 wrote: »
    Sure :rolleyes: Just adding my experience to the conversation, man. Damn... it may be time for you to take your midol, just sayin...
    falcroncry72, nah you didn't bro. Although other members do.
    Toolfan66 Posts: 17,995
    The only way anyone can have a fair comparison is if you have a set of 2B's that are modded caps/resistors and RDO-194's and another set fully modded for the tl version caps/resistors and RDO-198's.
    Anyone comparing a stock set to a fully modded tl set and saying tl is it you must get the RDO-198's and tl them it's the only way to go is ridiculous..
    tl is overrated!!! it dosen't need to be tl to be great!!!
    Don't forget they need to be in the same room with the same gear. If you are constantly swapping gear in and out and not using exactly the same gear to compare then it really means diddly.
    Just sayin....................
