Preamp ~$1-2k
falconcry72
falconcry72 Posts: 3,580
edited September 2011 in 2 Channel Audio
Well this is purely hypothetical, as I don't have this kind of coin to spend on a preamp right now. I'm hoping to save up the money over the next year or so, and I'd like to get the research done ahead of time, so that by the time I have the cash I can jump on a good deal when I see it.:cool:
My only requirements are that it be tubed and have a remote for volume and hopefully input selection.
Here's my (very) shortlist so far:
- Audio Research LS-15
- Belles 20A or 21A
Thoughts? Comparisons?
Other suggestions are welcomed and encouraged.:smile:
Post edited by falconcry72 on
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2011
    BAT VK20
    BAT VK3i
    Audio Research
    Conrad Johnson
    Carey
    Manley
  • headrott
    headrott Posts: 5,496
    edited August 2011
    I almost bought a Bells 21A. Good pre especially with the Auricap upgrade, and it's easy to do.:smile: I ended up getting a BAT VK3i though as it had the tubes I wanted to use in it and sounds very nice. It is in your price range (used) as well.
    Greg
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2011
    It ain't tubed, but my Wyred 4 Sound pre has made everything better. Go for balanced IC's if you can spare the coin.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • falconcry72
    edited August 2011
    I-SIG wrote: »
    ...Go for balanced IC's if you can spare the coin.
    Wes
    I just recently went balanced in my system, and it was a definite improvement.
    I went from MIT AVT-1 single-ended IC's (MSRP ~$400) to Signal Cable Analog 2 balanced IC's (MSRP ~$120), and I am very happy about the change.:smile:
    I would like to continue to run balanced, but I'm not wed to it. If I can get a good deal on a quality unbalanced piece, (ie. the Belles 350a), then so be it. :smile:
  • cstmar01
    edited August 2011
    The bat is balanced lol. I've heard the unit and really like it. It tends to still have a ss sound to it even though its tubed. Very enjoyable and well built. They have great customer service if something goes wrong even on used gear.
  • quadzilla
    quadzilla Posts: 1,543
    edited August 2011
    I'm pretty impressed with my Conrad Johnson, so +1 to that suggestion.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • madmax
    madmax Posts: 12,434
    edited August 2011
    Manley Jumbo Shrimp used.
    http://www.manley.com/mspr.php
    Vinyl, the final frontier...
  • TroyD
    TroyD Posts: 13,124
    edited August 2011
    I'd look for a Melos SHA-1. Find one. Buy it. Ronco it.
    Others I've had/have that I'd recommend:
    Carver C-19
    Manley Shrimp.
    CJ would depend on which model....I've heard some definate winners some good but not great.
    Dodd Battery if you can find it....
    I wouldn't let balanced be a deal breaker...unless you are dealing with unusually long runs of IC's.
    BDT
  • george daniel
    george daniel Posts: 12,096
    edited August 2011
    Lots of great suggestions-- the Melos is a killer pre--I killed mine unfortunately--
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2011
    The Jumbo Shrimp has been the one I've been eye-balling for a potential tube pre.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2011
    Rogue 66 Magnum or std can be bought used very reasonable and will get you amazingly close to the other pre's in your price range. The AR SP16L is also very good and in your price range.
    DKG999
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    Huge fan of Conrad Johnson. Great stuff to be had by them.
    Plus they just look awesome..
  • falconcry72
    edited August 2011
    dkg999 wrote: »
    ...The AR SP16L is also very good and in your price range.
    How does the SP-16L stack up against the LS-15?
    I'm sure they sound different. The LS-15 uses (4) 6922's in the audio circuit, but a sloid state power supply, while the SP-16L uses (3) 12AX7's for the audio and gain stages.
    Any thoughts on the two?
    I was also looking at the LS-1, LS-2, and LS-3B (solid state),as well as the LS-7 or 8, because they can be had cheaper, but the LS-15 and SP-16L look to be worth the extra coin.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2011
    I've not had a chance to compare the LS-15 and the SP-16L, however there are some differences between those two tube types that would have to impact the sound. I know the 12ax7 tube gets somewhat disparaged as a pre-amp tube, but I have to say that I preferred the 12ax7 tubes in my phono pre compared to a phono pre with the 6922 tubes in it.
    DKG999
    heiney9 Posts: 25,580
    edited August 2011
    The right vintage 12AX7's or even 5751's can sound marvelous.
    As always, YMMV
  • falconcry72
    edited August 2011
    dkg999 wrote: »
    It would be nice to be able to get my ears on both, but that's going to be virtually impossible aside from buying both.
    Also, the LS-15 has balanced inputs and outputs. Not a deal-sealer by any means, but a sonic consideration, nonetheless.
  • venomclan
    venomclan Posts: 2,467
    Modwright - tubes, remote and HT Bypass.
  • falconcry72
    Alright guys, thanks to all for the thoughtful suggestions. I love learning about new gear, and it seems at this price point there is A LOT of competition, which is good thing.
    I think have decided to go ARC. Not because I believe that an ARC piece will sound better than any of the others mentioned hear, but because ARC is so well known and well written about, that by getting to know an ARC product I will be able to judge other products better in comparison reviews etc. I want to own an ARC preamp at some point in my journey, so it might as well be sooner rather than later.
    I've got it narrowed down to the same two mentioned above for this price range:
    LS-15 and SP-16L
    Can anybody compare the two?
  • thsmith
    thsmith Posts: 6,082
    I would love to get my ears on a Joules Electra LA-150 only because Jesse has one and highly recommends it. They can be had in that price range used.
  • madmax
    Something to think about at this point is used or new. I suggest used. You can pick one up, try it and sell it for the same amount. This allows you to keep going until you find that perfect sound. The other option is new, obviously. Once you purchase it don't expect to get more than 60% of its value when you sell it. If it was the right choice then great. Some who insist on new equipment do the used thing and once they find the winner they sell it and buy a new one. Truthfully it doesn't really matter after it sits in your rack for a week.
  • thsmith
    +1 ^^^^^^^^^^
  • falconcry72
    The models I'm looking at are OOP, so new is out of the question.:wink:
    In my entire 2-channel system, which consists of about 13 pieces, the only ones I bought new were the V-Link and Signal Cable IC's.
  • falconcry72
    So about the ARC LS line:
    It looks like the LS-15 and 16 used (4) 6922's, then for the 16 mkii they switched to (2) 6H30's. The 17 also uses (2) 6H30's.
    Is there a big difference in sound quality between these two different tubes and designs?:confused:
    Is it worth the extra cheddar for a 16ii or 17 vs. a 15?
    A pair of Magnepan 3.6's just landed in my lap, so I feel the need now more than ever to upgrade my preamp; ironically, I now have less cash than ever to spend on one. :frown::smile:
  • vc69
    vc69 Posts: 2,500
    I cannot compare the LS15 to a SP16II per say, but I can compare the LS25 to a 26 and the difference was stunning. Frankly, When I had the 25 in house, I was never really "satisfied" and kept going back to my old VTL 2.5. I could never really put my finger on why 25 didn't cut it except to say that the VTL just sounded better. Better midrange and sparkle, a bit flubbier on the low end perhaps. The LS25 was just dry and lifeless. No dimensionality. The soundstage was wide but shallow.
    Lately I have had a LS26 in the rack and it is everything the 25 was not and more. The internals are very different. The sound is very smooth, silky and warm and tight. The soundstage is 3 dimensional and lifelike. The LS26 definitely peeled back another layer of the shroud. I have yet to miss the 2.5 in the mix.
    I don't know if that helps you any but there you go. I will say that for my personal taste, the VTL 2.5 is hard to beat fro twice the coin. It can be had for around 750 - 900 and would be a huge step up from your Parasound.
    /.02
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    6H30's tend to have a more solid state presentation rather than the typical tube presentation. They are little less 3D (euphoric) and more linear than say a 6922 or 12AX7, etc. If your other gear is already leaning on more of an SS presentation the 6H30's won't help you get a more tubey presentation.
    Of course I have never heard that particular pre-amp, just going on examples of BAT gear thay use the 6H30 and what other things I've read about its use.
    YMMV
  • falconcry72
    heiney9 wrote: »
    YMMV
    hmm. From your insight into the tube differences, and a few reviews I found elsewhere, it seems like the LS-15 will be tubier, warmer, and more liquid, while the LS-17 will be clearer and more transparent.
    I want tuby. I want warmth. I want liquidity. My 3.6's demand it, especially in my too-small, too-bright room. My amp is not particularly warm sounding either.
  • falconcry72
    TroyD wrote: »
    There's one on the 'gon for 1600. Comes with a stupid generic remote instead of the awesome wood remote that it should have.
    What else can you tell me about it?
  • falconcry72
    So I've got it narrowed to the ARC LS-15 (or 16 mk1) or SP-16.
    Again, the main difference appears to lie in the tubes:
    LS-15: (4) 6922's in the audio circuit, solid state power supply.
    SP-16: (3) 12Ax7's used for both the audio circuit and gain. If I got the non-"L" version, there would be an additional (3) 12Ax7's for the phono section.
    Having a phono section is not going to sway me one way or the other, so it's really about these preamps as linestages.
    I'm assuming that the SP-16 will sound tubier, based on it having tube-based gain, but I have no idea if that's a good thing or a bad thing.
    I have no experience with these or any other tubes.
    Any help here is appreciated.
    Thanks,
    Ben
    Be sure and do your research on 6922 tubes, it seems many out there don't think all that highly of them as an audio tube. Don't take my word for it however because that is one tube I have not done much research on.
    I think in the end you'll find a larger variety of 12AX7 and variant tubes, so you have more flexibility when tube rolling, more options and choices.
    just my .02c
