Why so much trouble lately with....
rebuy
What do you mean Rebuy?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Well I am going to install BP's on my speaker wire and I want to make sure they fit.
I thought all Banana plugs were basically the same diameter.
I get the impression that some plugs are harder to work with than others.
I can either get plugs here on the net or go to RS and get some.
Any I should avoid? -
I'm not even going to ask what amp your using but all bananas are the same .. 4mm right ?
some tend to be more tight or snuck than others.. that's why my favoriate are the locking kind.. you can loosen or tighten to your satisfaction
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Don't forget to mention on some Yamaha AVR's that their binding posts are spaced closer than the normal. You'll never_ get those dual banana plugs to go in.(Unless you buy the special sized ones).
Pay better attention. It's not the banana plugs, it's the cheap a$$ binding posts.Political Correctness'.........defined
President of Club Polk -
Banana plugs vary between manufacturer and the standard is loose. Avoid dual plug style and if you buy a decent brand you shouldn't have any problems but that's not a perfect statement. Locking ones are a good choice and better quality than the RS brand.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
You just can't help yourself can you.
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
More like it's the dumba$$ operator. If your gonna be a smart a$$ at least get it right
Too much **** to list.... -
I like the idea of locking ones, know where I can get them? All for a wunderful price.
In memory of Lawrence Welk. -
I have the Nakamichi Plugs I bought from eBay and they're great. They have screws so they're not loose at all. I bought plugs from Monoprice first and I hated them. I never could get them tightened down to my satisfaction. I have a Yamaha receiver and the Nakamichis fit perfectly.
GLS makes a decent one that won't break the bank.
http://www.amazon.com/GLS-Audio-Locking-Generation-Connector/dp/B000O8AHLA/ref=sr_1_2?s=electronics&ie=UTF8&qid=1313722094&sr=1-27.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
I'm cheap so I spread the plugs with a small screwdriver to make them fit better. Locking type plugs and/or binding posts work best if you have the $$sTO ERR IS HUMAN. TO FORGIVE IS CANINE.
