Why so much trouble lately with....
rebuy
rebuy Posts: 694
edited September 2011 in Troubleshooting
Banana plugs?
Really Sincerely
Post edited by rebuy on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    What do you mean Rebuy?
  • rebuy
    rebuy Posts: 694
    edited August 2011
    Well I am going to install BP's on my speaker wire and I want to make sure they fit.
    I thought all Banana plugs were basically the same diameter.
    I get the impression that some plugs are harder to work with than others.
    I can either get plugs here on the net or go to RS and get some.
    Any I should avoid?
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2011
    I'm not even going to ask what amp your using but all bananas are the same .. 4mm right ?
  • punk-roc
    punk-roc Posts: 1,150
    edited August 2011
    some tend to be more tight or snuck than others.. that's why my favoriate are the locking kind.. you can loosen or tighten to your satisfaction
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2011
    Don't forget to mention on some Yamaha AVR's that their binding posts are spaced closer than the normal. You'll never_ get those dual banana plugs to go in.(Unless you buy the special sized ones).
    F1nut Posts: 52,011
    edited August 2011
    Pay better attention. It's not the banana plugs, it's the cheap a$$ binding posts.
  • dorokusai
    edited August 2011
    Banana plugs vary between manufacturer and the standard is loose. Avoid dual plug style and if you buy a decent brand you shouldn't have any problems but that's not a perfect statement. Locking ones are a good choice and better quality than the RS brand.
  • gimpod
    gimpod Posts: 1,793
    edited August 2011
    You just can't help yourself can you. :wink::tongue:
  • SDA1C
    SDA1C Posts: 2,072
    edited August 2011
    More like it's the dumba$$ operator. If your gonna be a smart a$$ at least get it right:tongue:
    Too much **** to list....
  • rebuy
    rebuy Posts: 694
    edited August 2011
    I like the idea of locking ones, know where I can get them? All for a wunderful price.
    In memory of Lawrence Welk.
  • MissEllie
    MissEllie Posts: 3
    edited August 2011
    I have the Nakamichi Plugs I bought from eBay and they're great. They have screws so they're not loose at all. I bought plugs from Monoprice first and I hated them. I never could get them tightened down to my satisfaction. I have a Yamaha receiver and the Nakamichis fit perfectly.
  • squeeb
    squeeb Posts: 426
    edited August 2011
    rebuy wrote: »
    GLS makes a decent one that won't break the bank.
    http://www.amazon.com/GLS-Audio-Locking-Generation-Connector/dp/B000O8AHLA/ref=sr_1_2?s=electronics&ie=UTF8&qid=1313722094&sr=1-2
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
  • DON73
    DON73 Posts: 516
    I'm cheap so I spread the plugs with a small screwdriver to make them fit better. Locking type plugs and/or binding posts work best if you have the $$s
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
