Gaskets for MW6XXX
brgman
brgman Posts: 2,859
edited October 2011 in Vintage Speakers
I deal with several industrial rubber suppliers for various items in my work and i was talking with one this week and gave him rough specs of a MW gasket.He can die cut these for us from several different materials and durometers.I have him sending me a few samples of the foam rubber he has to see what may match up.
I am looking to see if there is an interest in these.
They would not have the screw holes in them but a simple paper punch would remedy that in my opinion.
Anyway, it is a quantity sensitive deal.For instance 100 pcs would be about $1.50 each and 500 pcs down to about $1.23 and so on.
What was quoted was 1/16" thick x 5.70" ID x 6.375" OD.
Let me know if this is something we would want to follow up on please.
I have a couple more companies i deal with i may call next week as well.
The real cost is in the tooling of $75.00.Otherwise these would really be cheap.
Thoughts?
I’M OFFENDED!!!!
Post edited by brgman on
«134
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2011
    I would be in for 8.
  • DollarDave
    edited July 2011
  • brgman
    brgman Posts: 2,859
    edited July 2011
    DaveMuell wrote: »
    Tweeters?
    Let's tackle the MW's and if it works out and there is enough interest i am sure he can do the tweeter gaskets as well.
    If we don't have enough interest it won't be cost effective.
    I’M OFFENDED!!!!
  • 20hz
    20hz Posts: 636
    edited July 2011
    is this something you would do for yourself or are you going to try selling gaskets online?
    I just think that tooling charge will take forever to pay itself back .
  • brgman
    brgman Posts: 2,859
    edited July 2011
    This is not a profit venture.If we have enough folks interested we buy them and split the cost equally.Just looking for an alternative to mortite and window seal as much as we all may love it.
    I’M OFFENDED!!!!
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    I'm interested in 25-50 as I don't believe that anything but a soft seal is needed after installing Larry's rings.
    heiney9 Posts: 25,409
    edited July 2011
    I'd experiment with them so I'd be in for say 10-12 pieces.
  • Emlyn
    Emlyn Posts: 4,634
    edited July 2011
    I'd be in for 40. Don't really need that many off the bat, but even at $1.50 each they'd be inexpensive.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Now we're rolling.I have the sample coming to see what is closest to what we need.I'll let this run for probably a week longer and then total up what we can buy and what they will cost.
    I expect to get an approval drawing which i would post as well before signing off on it.
    Mike
    I’M OFFENDED!!!!
  • DaveHo
    DaveHo Posts: 3,583
    edited July 2011
    I'm in. I've only got a pair of RTA-12'c at the moment, but I'd take a dozen just to have some extra's for whatever else might come into my possesion.
    -Dave
  • aviator
    aviator Posts: 159
    edited July 2011
    In. How 'bout 2 dozen?
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited July 2011
    Put me in for 8 of those please. Thanks.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    edited July 2011
    Not trying to hikack this thread but since we are rta fans here I need a pair of mx 6501's if any one can help I'd be greatfull, thanks.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Um,why would you put that here?:confused:
    How about the Wanted section? More people would see it there i think.
    Just sayin'
    I’M OFFENDED!!!!
    Toolfan66 Posts: 17,994
    edited July 2011
    If we like them could we order more later??
    pitdogg2 Posts: 26,960
    edited July 2011
    I'd be in for some as well as passive radiators if you get to that point.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    i don't see why not
    I’M OFFENDED!!!!
    edited July 2011
    I would like to see this get to the point of ordering a complete set of gaskets Tweeters,Drivers,Passives,and Binding Post Cups!!! But one step at a time baby!! :-)
  • Tekkis
    Tekkis Posts: 120
    edited August 2011
    you can put me down for 6
    System Details:
    Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
    Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i
  • intangible
    intangible Posts: 262
    edited August 2011
    I will take a dozen if this goes anywhere.
  • brgman
    brgman Posts: 2,859
    edited August 2011
    Hope to get the sample this week and get an order together next week.
    I’M OFFENDED!!!!
  • xoaphexox
    xoaphexox Posts: 247
    edited August 2011
    I'm in for 16 if they work with 1.2tl's. Looks like they will...
    To 2nd what toolforlife said, tweeters, passives, crossover, and binding post cup seals would be the bomb!
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • brgman
    brgman Posts: 2,859
    edited August 2011
    If these fly i am going to send sample of the tweeter gasket and dimensions on the others and see if we cant get a solid source for well fitting 1/16 foam gaskets and get away from door seals!:wink:
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    edited August 2011
    xoaphexox wrote: »
    They will work wit any MW65XX if all goes as planned.
    I’M OFFENDED!!!!
  • ncbuckeye3
    ncbuckeye3 Posts: 38
    edited August 2011
  • cincycat13
    cincycat13 Posts: 888
    edited August 2011
    In for 20 please.
  • brgman
    brgman Posts: 2,859
    edited August 2011
    I received a sample of the material and it should work perfectly.I am sending a sample of the best gasket i can find to see what they will charge to have the holes punched at the same time they make them.
    We'll see if it is worth it for them to do the holes also.
    Either way final pricing should be in place by end of next week and final count taken for an order.
    I’M OFFENDED!!!!
  • headrott
    headrott Posts: 5,496
    edited August 2011
    Sorry, I don't know why I didn't look at this thread earlier.
    I would be interested in 25 to 30 of them please. Thanks for taking the time to work this out.
    Greg
  • brgman
    brgman Posts: 2,859
    edited August 2011
    Cool.Got it Greg.
    I’M OFFENDED!!!!
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited August 2011
    brgman wrote: »
    Put me down for 12 please?
    Matt:biggrin:
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
